Miata 02' steering wheel position
tao724
I had new brakes put on my 02' Miata (Sport package edition), last spring. Something 'broke' at the shop and they had to replace the right front caliper. Ever since , the steering wheel has been 'off center' a few degrees. It dosen't interfere with anything, the car is still absolutely perfect, it just bugs me. I took it back, they checked it out and told me it was like that before they worked on it, (it wasn't). I had the wheels balanced, and the alignment checked elsewhere, all ok.
Any ideas about what is doing this, and more importantly, what I can do to fix it? (if its too costly, I'll live with it.....(spare $ is for the Midge!). :confuse:
Roger
Bronze
Whoever did your alignment (toe) did not centre the steering wheel and make sure your tie-rods were of equal length after adjustment.
It's very easy to fix, but if you're not confident of doing it yourself, go to a good alignment shop. The guys you're talking to are pulling the wool over your eyes.
14dna
:iagree:
As a 30 year veteran of the auto industry, (read mechanic), I must say, it disappoints me that guys don't finish an alignment by centering the wheel.
This can cause larger problems down the road in regards to airbags, signals, and cruise control.
As Roger says,go find a reputable shop and stick with them, all these guys are doing is parts replacement.
Just my thoughts.
Dave :driving:
Platinum
Argh. That's annoying. Whoever did the alignment did it half-arsed. I'm another Cert'ed ASE Tech, wrench'd for nearly 30 years on all manner of EuroTrash... when someone gives that kind of "service" it reflects poorly on the industry as a whole, the guilty shop in particular, IMO.
It's likely about two turns of both tie-rods to correct. Just laziness on the part of the alignment person, mebbe tryin' to make 'rate'... but if it's cockeyed the service manager SHOULD have sent it back to the tech to correct. Enough 'come-back' jobs and he'll start to do it right the first time.
Two in a row like that (if it were our shop) I'd be lookin' for another alignment tech. Lots of folks outta work now. :wink:
Roger
Bronze
The worst thing is leaving it like that after you took it back, and then telling porkie-pies.
R
RonMacPherson
If the car tracks straight, doesn't pull or drift. It's an easy enough fix(problem is consistent with Hunter equipment for some reason or another).. Turn the tie rods in the direction that the wheel is turning.. You turn both tie rods the same amount in the same direction. So all you are doing is moving the rack a bit.
Usually, on a road test, I start with two flats. Tighten up the lock nut then road test again...
TR3driver Miata/MX5 Steering wheel repair Other Cars 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
mezy mazda MX5 / Miata gear stick relocation Other Cars 2
waltesefalcon Miata windows Other Cars 4
waltesefalcon NA Miata gauges Other Cars 16
waltesefalcon The Miata rides again Other Cars 11
R TR6 Mazda Miata ride, everything else TR6 Triumph 13
AngliaGT "Nice Miata!" Other Cars 13
jfarris TR2/3/3A Venture into the "dark side," Miata seats in a TR3 Triumph 9
Magyar For Sale Miata Seats, Tan Leather Spridgets Classified 2
F TR6 miata seats Triumph 12
AngliaGT Miata - ALMOST Made it Home Other Cars 7
TRMark TR4/4A Miata Battery Triumph 6
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
Raymond MGB Miata seats? MG 1
JPSmit Miata Coupe Other Cars 3
C A better sound for a Miata? Other Cars 0
R TR2/3/3A Miata Engine and transmission Triumph 12
John_Mc TR6 Floor pan to frame mount question/Miata seats Triumph 2
M MGB MX5/Miata seats for MGBGT MG 2
T TR4/4A Tr4a - 3 point seat belts with Miata seats Triumph 8
T TR4/4A Making Miata seats in a TR4a look more "right" Triumph 4
T TR2/3/3A Miata seats installed in my TR3A Triumph 14
T TR2/3/3A Will Miata seats fit in a TR3A? Triumph 7
DornTRoriginal Miata 1997 MX-5 Shock Absorber repalcement assistance Other Cars 2
G MGB Miata seats MG 4
NutmegCT MGA MGA/Miata MG 12
G 1994 MX5 Miata Other Cars 6
jhorton3 Replacecment Miata Seat Covers Spridgets 12
BobbyD Miata Seat Brackets..... a new approach Triumph 0
Sarastro A "bugged" Miata Spridgets 4
Brosky Wedge Miata seats now in TR8 Triumph 8
Darrell_Walker Wedge Miata seats in a TR8 Triumph 45
bash TR6 Adding Miata Seat Speakers to TR6 Triumph 2
CZ_Dave MGB Miata Seats in a MGB? MG 10
G TR6 TR6 with Miata seat recover Triumph 21
A TR6 TR-6 need Miata seat adaptors Triumph 2
RickB Need info about Miata seats in Spridget Spridgets 49
DART Need MIATA HELP!! Other Cars 8
R MGA Miata Battery in MGA MG 11
t_bush Miata seats and a rollbar? Triumph 9
DNK Miata Seats Triumph 16
philman Wedge Miata Seat installed in a TR7V8 Triumph 10
Brosky Miata seats 98% INSTALLED! Triumph 16
zedvictor1 Miata powered Sprite Spridgets 7
Brosky Miata Seat Up-date -- Progress!! Triumph 9
Brosky Miata Seat Up-date Triumph 0
A New Miata top, finally. Other Cars 8
Brosky Miata seat prep continues Triumph 48
