I got interested in upper cylinder lubricants when one of our local club members had severe ring wear in his rebuilt TR4 motor after only a few thousand miles. Steve Hedke at British Pacific said he had seen the same thing on other old but rebuilt engines, including a flat-head Ford V8, and a "series" Land Rover. The theory is that the E10 is more likely to wash off the lubrication film, if you use a bit too much choke on a cold start (getting liquid fuel into the chamber). Well, my tail pipe is as black as the next one, so I went on-line to see if others had reported similar problems. Doesn't really prove anything, but I found a lot of believers on the "Bob is the oil guy" web site.
Personally, all I can report is that the idle rpm went up, and the engine does seem to run marginally smoother.
The TC-W3 standard is for water-cooled outboard motors and such; supposedly somewhat different than oil designed for use in air-cooled 2-strokes (which run much higher cylinder wall temperatures). I bought a gallon at Wally-mart, which I decant 4 oz at a time into some old pill bottles to carry in the car. When I fill up, I dump one of the bottles in first. At that ratio (around 300:1, depending on how empty the tank is), there is no smoke or smell. And I didn't notice any effect on octane.
Worth noting, perhaps, that Triumph recommended using an upper cylinder lubricant as well.
<span style="font-family: 'Comic Sans MS'">An upper cylinder lubricant may be used to advantage, during the running in
period of a new engine. The lubricant should be mixed with the fuel in the
proportions given on the container. Such lubricants may be used with
advantage throughout the life of the vehicle, particularly during wintry
weather,</span>
