TR2/3/3A Long Door anyone
2long
The car is gorgeous for sure. But I hate to break it to the guy that the engine is very likely a replacement.
Dan
Mickey Richaud
Don't know that I've ever seen a green that dark! The British Racing Green was much lighter. And I'm pretty sure that "Fawn" interior was more brown than that.
However, it does present fairly well. And there are eight days left to bid. Might be fun to watch.
mgf
Not much bidding so far and I imagine the reserve is quite high. Any thoughts?
https://www.ebay.com/itm/Triumph-TR...65568031:g:OBIAAOSwxp9W8C5l&item=152024023089
Tom
Tom, Your post is a good motivation for me to do some amateur estimating.
My 1st WAG is somewhere between $27.6K & $35.7 & probably closer to $35.7K. I used Hagerty's Evaluation FMV's.
Obviously, there may be adjustments required after an actual "hands-on" inspection.
Maybe this will spurn more speculation?
mgf
TomMull
TomMull
Dan
Perhaps a bit more information, Dan. Owner admits to modified intake and exhaust. I am not all that familiar with early engines but I see nothing obviously wrong with this one. Wat am I missing?
Tom
2long
Hi Tom:
My comment is purely my own opinion. TR2 engine numbers ran quite consistently a bit higher than the TS number due to a certain number of engines going to other cars, like Dorettis or Morgans or whatever. For example, my car is less than 10 away from this one in TS number (mine is TS 1911 LO, this one is TS 1920 L), and my engine is TS 2067E. That pattern does not fit this car, as the seller claims the engine # of TS1721E is original to the car. OF COURSE nothing Standard Triumph did was perfectly sequential, and I agree it is possible the engine was original to the car. But consider this - a fairly inexpensive Heritage trace on the TS number would confirm if the engine is original. The car was owned by an avid TRA club member who would have known how to verify, and the car is obviously a great car with a high dollar value, so why not verify? Again, just my opinion.
Dan
Kleykamp
Sorry, I'm not buying the koolaid. Survivor?...New interior, a/m steering wheel, older not even good quality repaint. My opinion is that its just another "restore as you drive" project that would need a lot to make it worth anywhere near 20k. I live in Lexington, one hour from there, hard pressed not to go look at it out of curiousity. My '61 is far more original that it is and probably closer to being a survivor. A bad, old respray does not a survivor make. I'm curious as to what about this car makes it special.
TomMull
TomMull
Hi Tom:
Dan
Thanks for the clarification, Dan. There is certainly some confusion with the numbers cited in the ad. The Trace, if available, would be extremely important.
Tom
CJD
I understand it's crazy... But this is a long door. It's not a 3A that there are 10s of thousands made. 20 k is way low.
Kleykamp
Actually I did a Hagerty search on both the TR2 and TR3 and the 3 runs slightly higher in value than the 2...For whatever reason. I don't frankly put a whole lot of stock in the Hagerty guide as they typically seem high. My opinion is that this particular car's description fits best at a Level 3 condition..certainly not a (1) concourse and arguably not (2) excellent. That would have it between 12,800 and 23,100. It will bring what it brings anyway.My point though is more that the seller, because he has a little history on the vehicle, is over selling the "survivor" aspect as it definitely is not a survivor with all the work that has been done to it. It's an old restoration with new interior. I might be being a little tough on it but an old orange peel,wrong color, flaking paint job is not a survivor with original paint. And we don't even know what the underside looks like. No disrespect but if someone pays 35K for this car thinking it has any value due to being a survivor, they got fooled.
Andrew Mace
Hi Tom:
Dan
I would "argue" that it's extremely likely this is the original engine. The seller does state that the car is titled by engine number, which was common at the time in CA, as well as NY and some other states. It would be very unlikely, IMO, to have seen the rest of the car replaced around the engine whose number matches what is on the title. And it could be a simple case that this particular engine was pulled off the assembly line to rectify some minor fault and then put "back in the queue" later, or it could literally have been misplaced or somehow shuffled to the wrong end of a large batch of engines, getting it well "out of numerical order," which as everyone understands didn't mean all that much to begin with. Sure, a BMIHT certificate would clear up the confusion, but I'd be very suprised if that certificate does not have the numbers quoted by the seller.
TomMull
TomMull
That car has been removed from eBay after showing very little interest. There were no bids over 12k, which is way too low, imo. Perhaps it has been sold locally or more hopefully, will show up somewhere soon again.
Tom
CJD
And...
....we'll never know!
The auction ended early, as the car is "no longer available. Guess it sold locally and we'll never see how much. Bummer. I doubt it was lack of interest, as no auctions really take off until the last day...usually the last 30 minutes.
Geo Hahn
...as no auctions really take off until the last day...usually the last 30 minutes.
Which is why, when I bought my most recent car on eBay, I called the seller, agreed on a price and had him add a 'Buy It Now' to the listing. Late evening the day before the auction was to end and it was all over.
Somehow it doesn't seem fair to encourage a seller to simply end an auction early but if a Buy It Now is added then it all stays w/I the eBay framework.
TomMull
TomMull
I'm sure this was in your best interest and maybe that of the seller too, but by removing the highest bid option, it limits value setting to two people, rather than to all of the bidders and potential bidders (some of whom might wait until the last second.) Would anyone have bid over the "buy it now" figure.
This is particularly significant when trends are being set on rare cars. One or two sales can determine the value. I guess one conclusion is that eBay is not the place for trend setting.
I am lately keeping a much closer eye toward "Bring a Trailer". Much better format but as yet quite limited selections.
Tom
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 6
R TR2/3/3A Restoring a 54 TR-2 Long Door Triumph 10
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 22
M_Pied_Lourd TR2/3/3A Long Door Project Triumph 7
D TR2/3/3A 1954 TR2 long door for sale Triumph 0
G Long door...for a brave dude! Triumph 14
Tr3aguy TR2/3/3A TR2 Long door Triumph 6
angelfj1 TR-2 Long Door on eBay Triumph 13
B TR6 Crankshaft long seal surface Triumph 5
jfarris Message too long error FORUM Navigation Questions 8
L My 1951 Triumph long ago British Motorbikes 0
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
W Generator and Starter Long Bolts Spridgets 0
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
A Land Rover V8 3.9L long block core for sale Rover / Land Rover 1
Jayplum For Sale SU HS6 for sale along with a long intake Triumph Classifieds 3
Zitch Engine Oil Leak After Long Drive Austin Healey 19
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
G TR2/3/3A Finding a long lost TR3 Triumph 4
R The long road home Spridgets 1
Y MGB An odd (and probable long-shot) request... MG 5
roscoe Rear end crown and pinion gear swap. 4.11:1 to 3.54:1 [long read] Austin Healey 12
T BT7 throttle relay levers short and long Austin Healey 2
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
Michael Oritt Post- Open Roads 2002: Tahoe to MD the long way Austin Healey 19
boxofparts TR2/3/3A My long term 30 yr project Triumph 5
K For Sale Long and short TR3 and 4A Intake manifolds Triumph Classifieds 0
Joe Schlosser Thoughts on a long traffic Light Spridgets 11
D Long Lost Midget Spridgets 0
E Long lost Sprite Spridgets 10
roscoe Leakdown test [long read] Austin Healey 11
aero3113 Healey Shop on Long Island Austin Healey 9
britlover Wanted TR4 Hood long bubble Triumph Classifieds 0
D MGB Painted rubber bumpers. How long will they hold up? MG 1
T C42 BJ8 generator long screw needed Austin Healey 2
PeterK General TR Time for a long ride Triumph 3
D After a long break.... Spridgets 6
Lotus Club SoCal Ballast Point Long Beach Social Lotus 2
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
GTP1960 Not the "best car ever made" by a long shot Other Cars 14
L TR6 need help on long dead TR6 Triumph 16
Sarastro Morris Minor in Long Beach, CA Spotted 1
D TR4/4A extra long oil filter attachment stud Triumph 9
D TR4/4A flywheel bolts maybe too long Triumph 15
Sarastro Red TR3 in Long Beach, CA Spotted 0
Jim_Gruber I woke up Bugsy this afternoon after about a month long nap and he was cranky Spridgets 7
TomMull Post-War Other Herald: Holy Moly! [Why it took me so long to make the accelerator bracket] Triumph 2
Marla TR4/4A Take the long way home Triumph 11
K TR2/3/3A How long should an SU damper top up last? Triumph 22
