It's a Small World
T
TRDejaVu
As well as owning a TR4, I have just found out that the engine in my daily driver also has some Triumph blood in it.
I recently bought a used Saab 9-5 Aero, which has the 2.3 liter 250 BHP turbocharged 4 banger engine. Apparently good for 155MPH, but more importantly I can vouch for its awesome mid range overtaking times that put a lot of much more capable cars to shame. My B235R engine is evolved, through a number of iterations, from the Dolomite engine, which was originally used in the Saab 99. 2009 will be the last year of this engine line.
jjw
Well... no relation to the TR4 engine, but your Saab engine can trace its roots right to the Standard-Triumph Slant 4 (as used in the TR7 and Dolomite) and the related Stag V8.
Always found it interesting that the first car to use S-T's OHC Slant 4 was not even a Triumph, but the Saab 99.
Both my and my wife's daily drivers are Saabs with that same basic engine...
tdskip
It makes them fun to drive, no? I miss my 9-3 for that same urge.
martx-5
I worked for a Saab dealer when the 99's came out with the Triumph engine. There were alot of problems (mostly head gaskets) with that engine. Within a few years, Saab totally redesigned it. Although the new engine had similarities to the Triumph version, it was essentially a different engine. We called that one the "King Kong" because of it's reliability compared to the Triumph lump. :hammer:
Platinum
:lol:
I worked at an independent shop and fixing Saab 99's head gaskets was a "groaner" job. I recall thermostat housing issues, too.
...and the beast was mounted bass-ackwards, IIRC. :shocked:
HerronScott
DrEntropy said:
:lol:
It was definitely backwards! In-line 4 with front wheel drive but the clutch was at the front and the timing chain at the back. We had a timing chain tensioner break on a free Saab 99 that someone gave us (the great orange pumpkin) and I was amazed at how easy it was to pull the engine/transmission to fix it. Very few things that had to be disconnected to get it out.
Scott
martx-5
There were some definite advantages having the engine in backwards. The clutch was right in the front behind the radiator, and could be changed in less then an hour.
Deleted member 8987
Unless one of the pivot arms on the pressure plate had broken.
Then, you were in for HOURS with a cutting torch.
Did that.....once.
Andrew Mace
Well, we're getting a bit off-topic here, but the later Saab 99 with the 2.0 liter had a clutch that was a positive pain in the wrench to swap out. Oh, and having the engine in backwards was fine...so long as you weren't sold the wrong water pump by mistake and ruined the jackshaft that ran it, meaning you had to pull the engine to change that shaft, which went in the front (which faced to the rear) of the engine! And I don't even want to TALK about the water pump covered, which inevitably corroded in place, meaning the only method of removal was total destruction! (I once had the engine actually hanging only by the water pump cover; it lasted a good hour or more like that before it snapped! TRUE STORY!)
At least Triumph knew enough to mount the engine facing the correct direction!
Now if Saab had developed the engine the same way Triumph did, say, by joining two of them in a Vee and making an eight-cylinder, and then adding the four-valve heads....hmmmm.... ;-)
Deleted member 8987
That's why, whenever one came into the shop for repair, it was called a "Saab Story".
T
TRDejaVu
While mine has 250 BHP, the latest ones have 260. Couple that with its mid range torque and you don't need a V8.
Michael Oritt Small world Austin Healey 15
aeronca65t Small world...literally Other Cars 5
AUSMHLY Small world or what are the odds? Austin Healey 14
tinman58 General TR Small world Triumph 3
Gundy It's a small world Spridgets 24
TR4 Small World Triumph 15
P A small group outing. Spotted 2
H For Sale 1956 Small Mouth TR3 Kit Triumph Classifieds 0
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
M TR2/3/3A TR3 Small Mouth Inner Fender Holes Triumph 3
S TR2/3/3A lower small brass bushing Triumph 13
JPSmit Small gathering of club members today Spotted 6
K TR2/3/3A A couple of small distributor tech questions..... Triumph 10
7 General TR Small parts Triumph 2
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
B For Sale 57TR3 Small Mouth with OD Project. 12 yeqrs running. I'm not going to finish Triumph Classifieds 14
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
D TR2/3/3A More small nuts [ and studs!] Triumph 2
nevets Small Healey-related tidbit Austin Healey 2
S Rear axle - small leak .....? Austin Healey 7
steveg BJ8 Alternator - small belt in large pulley Austin Healey 4
R For Sale 1956 Early small mouth TR3 Triumph Classifieds 1
M TR2/3/3A Late 57 Production with a Small Mouth Apron Triumph 16
R TR2/3/3A Removal of Small Mouth Front Apron Triumph 4
jfarris TR2/3/3A Small Manifold Clamp Locations? Triumph 5
P TR6 Small pigtail wire Triumph 3
K TR2/3/3A Windshield frame Tenax fastners with small nylon spacers? Triumph 10
B BJ7 Drain Channel and Small Waist Trim piece question Austin Healey 13
Tinkerman TR2/3/3A Installing small body stone guard Triumph 9
Jim_Gruber Source for Small U Bolts on 1/4 Elliptic Springs- Spridgets 11
B Another small step for the 100-6 Austin Healey 27
toysrrus TR2/3/3A "WANTED": TR3 Small Mouth Front Apron Medallian Triumph 14
P TR6 Small tear in convertible top Triumph 6
R water pump small hole does line up Austin Healey 7
A Project Small Axe Racing: Big Healey restoration/vintage racer build Racing 30
Martinld123 Small Puff of Black Smoke When I Blip Throttle Austin Healey 6
B Replacement of Small Black Wire inside Distributor Austin Healey 15
S TR2/3/3A small woodruff key Triumph 5
DanLewis And I thought the Bugeye was small... Spridgets 6
S TR2/3/3A small spring pan question Triumph 5
drooartz MGB-GT Other small progress MG 3
T TR4/4A TR4 Humps Big and Small Triumph 9
mailbox Air line for small shop Restoration & Tools 9
PC on road, on the [small] screen Spotted 0
L Engineering of "Big" healeys compared to "small" healeys Austin Healey 11
M TR2/3/3A It's the small stuff Triumph 11
Rob Glasgow Sometimes it's just the small things.... Austin Healey 3
jlaird Looking for a zinc plater for a small job Spridgets 11
T small site issue - geeks please help Triumph 4
