Gliderman8
OK, I'm just about done installing new thrust washers.
Since I dropped the pan, I will be filling it back up with oil and getting ready to start it (TR6).
What's the proper procedure to start after refilling the sump?
Do I remove the coil wire and crank it until I get oil pressure, then start it?
Any advice gladly accepted!
And one more question... This will be the third oil change since a total rebuild... can I or should I consider synthetic oil or just stick with regular oil?
