TR4/4A Interior Install Steps
ghawk16
I was reading thru one of the other interior install posts and someone had posted a rough procedure of steps to put everything back in. Anyone have any tips of what to do or not to do first? My thinking is:
1. Pedals (installed already)
2. Wiring Harness (Installed already)
3. Dash Pad (light glue)/Use windshield to hold down
4. Floor plugs/sound deadening/etc.
5. Heater
6. Steering thru firewall
7. Install Crash Pads on dash and then install dash
8. Tunnel Cover
9. Carpet Kit (follow those instructions)
10. Center dash support
11. Glove box
12. Speedo/Tach
13. Center gauges
14. Seats
15. Door hardware/panels
Hopefully don't mess anything up! Look right? I took A LOT of pictures as I disassembled over 2.5 years ago, but I'm sure a certain bracket may need to go in before some certain item. Also, can anyone confirm on the interior windshield surround trim whether the outer pieces overlap the upper and lower center pieces or do the center pieces over lap the right and left edge pieces when gluing them down? Getting ready to do mine. Thanks!
glemon
Not a big deal as they are pretty easy to rrmove of needed, but I would do the big guages last, as those holes give handy access to areas you otherwise might have to lay on your back for. Assume the windshield wiper cable and boxes are already in, otherwise move to the top of the list.
Popeye
Bronze
I'm still not there, but am putting together my own list. Will post below, in a separate post. A few questions on your list:
1. Is it better to install the transmission tunnel first, given it seems to be a pain to install?
2. Is it better to install the heater earlier in the process, given it is buried behind lots of other bits? (My heater was already removed when I bought the car, so I'm not sure what is required to install.)
Popeye
Bronze
My list - it is a work in process (the list, not the car!), so please take this with a grain of salt:
1Mount motor (include motor grounding strap)
2Install clutch and transmission
3Install hydraulics from slave to transmission
4Install driveshaft
5Fuel line routing from pump to frame, to rear tank area
6Install exhaust
7Install accelerator assembly in body
8Place body on frame
9Install pedal assembly
10Brake line routing to M/C
11Clutch hydraulic routing to slave
12Mount body VIN plate
13Install electrical harness
14Install million grommets
15Inistall gas tank
16Install trunk internals
17Install horns
18Install heater core
19Install windshield wipers
20Install dashboard
21Top crash pad first (under windshield)
22Metal dashboard panel (i.e. part without wood dash)
23Crash handles (below glovebox)
24Crash pad on driver side
25wood panel
26instrumentation
27Wiring
28Install steering wheel
29Install carpet
30Install seats
31Install hood, including gaskets
32Install windshield frame including gaskets
33Install windshield glass including gaskets
34Install doors
35Rebuild doors
36Install trunk including gaskets
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
G TR4/4A Interior Install...and other random questions. Triumph 11
Zitch TR4/4A Tr4 Carpet Install and interior install Triumph 2
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
Popeye TR4/4A Attaching convertible top to bows - interior Triumph 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
KVH General Tech Reinstalling TR4A Interior Triumph 13
Mickey Richaud Wanted Interior Austin Healey Classifieds 2
W TR2/3/3A Interior and Body Colours Triumph 14
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
K 100-6 Interior Austin Healey 4
MGTF1250Dave T-Series Interior Trim Panel installation MG 12
Csarneson BN4 Interior Assembly - Unidentified Holes Purpose Austin Healey 2
H 100-6 Interior Installation Austin Healey 4
nichola TR6 Interior panels Triumph 5
F Interior Door Handle Removal Austin Healey 2
S TR2/3/3A carpet kit and the interior done Triumph 8
B BJ7 Interior Finishing Details Austin Healey 2
rjc157 Wanted 76 interior Triumph Classifieds 1
77MidgetMkIV New top and interior-that escalated quickly! Spridgets 9
C XK120 Interior... and Interiors in General Jaguar 17
B TR4/4A Midnight blue interior Triumph 6
T Interior Door Panel and Top Rail Austin Healey 3
Y For Sale MK V DHC interior wood for Left Hand Drive Jaguar Classifieds 2
S TR2/3/3A copied an old original interior piece and carpet pad Triumph 6
EWD TR6 ā€˜74 TR6 Interior - Padded dash and heat/sound material Triumph 4
S TR4/4A Vinal interior trim piece eaten by rodent Triumph 3
F Wanted Used leather interior for BT wanted Austin Healey Classifieds 5
R Wanted TR6 Interior Door panels Triumph Classifieds 0
AUSMHLY BJ8 Leather interior - what pieces were leather/vinyl Austin Healey 13
D Interior Finished Austin Healey 3
G For Sale TR6 Matador Red Interior and Boot Triumph Classifieds 0
F Bug eye interior Austin Healey 2
D BT7 interior purchase Austin Healey 5
D Prepping Floors Before Installing Interior Restoration & Tools 6
HealeyRick 100 Interior Trim Austin Healey 1
D T-Series Trying to find out an interior dimension MG 7
S For Sale Austin Healey 100-4 Carpet Kit and Interior Panel and Trim Kit Austin Healey Classifieds 0
D interior on a budget... Austin Healey 6
R Paint first or interior Austin Healey 10
ckeithjordan TR2/3/3A New Interior Trim Re-Use Triumph 6
C For Sale 1965 TR4 Red - Black Interior Triumph Classifieds 4
T Colorado Red Vinyl Interior Austin Healey 6
CessnaTPA New Interior Recommendations Austin Healey 8
D BJ8 Interior Austin Healey 6
Rut TR4/4A Rimmer interior Triumph 17
J 100-4 interior kit Austin Healey 3
K BJ7 interior back panel difference Austin Healey 4
Rut TR4/4A Good interior source Triumph 29
