Inline Fuses [ and Fuse Theory & Application ]
In another post, Stever mentioned inline fused being added. I have some I've added. But I am curious what systems you all have added fuses to and what amperage they each are.
Dave Russell
Yoda - R.I.P
Re: inline fuses
The most commonly added & most useful fuse addition is in the wiring going to the side marker, tail, & number plate lamp. Due to the long distances & proximity to the car ends these circuits are particularly vulnerable to minor collisions & wire chafing. The easiest location to fuse this circuit is at the red wires on the back of the lighting switch. Use an inline holder with a 15 amp fuse.
Another popular circuit to fuse is the overdrive circuit. This is easily done by inserting an inline 15 amp fuse in the white wire at the fuse block terminal 3, to the OD circuits.
Another is the fuel pump feed. Another inline fuse in the white wire at fuse terminal 3 with a 15 amp fuse.
You can put 20 amp fuses in the separte high & low beam headlights at the dip switch, if desired, but most people don't like the idea of blowing a headlight fuse.
Lastly, for overall protection, some folks put a 35 amp self resetting circuit breaker in the brown wire from hot starter solenion terminal to the voltage regulator. This is the main feed for all electrical circuits.
Keoke
Re: inline fuses
/ubbthreads/images/graemlins/savewave.gif
Just curious, why do we need these high amperage fuses. Properly fused a DC circuit fuse should be rated at 1&1/2 times the steady state load current.---Keoke
Dave Russell
Yoda - R.I.P
Re: inline fuses
Gee, I don't know. I think we are more concerned with protecting the wiring from disaster than protecting a single device. Some of the Healey wiring is rather small & a short at the end of longer runs can melt the wire insulation without ever blowing the source fuse which is arranged to handle several different circuits at the same time.
With the small & rather mechanically fragile in line fuses that are generally used, the lighter fuses are noticeably weaker mechanically & more subject to vibration fatigue, thermal fatigue, & failure. A single mechanical shock can fracture the small wire in a one amp fuse.
I doubt if the steady state load current is of much concern in rating a device such as a pulsating inductive load of a fuel pump on which the repetitive peak currents can be considerably higher than the theoretical steady state. A fuse that is subjected to its maximum load rating loses a bit of it's minimum melt rating on each occurance.
The overdrive solenoid can draw something like 20 amps until the pull in coil switches out, then drop to around one amp on it's holding coil. We are really fusing it against the failure of the pull in coil contact to open as can happen if the solenoid doesn't make a full stroke.
Circuits that are under fused only create more reliability problems.
On the other hand, WHY NOT high ratings?
Keoke
Re: inline fuses
/ubbthreads/images/graemlins/savewave.gif the circuits being discussed are long and the wiring will current limit the fuse. In the case of the overdrive the 19 amp current lasts for 3 milliseconds so why the big fuse given its steady state running current is less thn 2 amps???---Keok amps>???Keole /ubbthreads/images/graemlins/confused.gif
Dave Russell
Yoda - R.I.P
Re: inline fuses
Keoke,
I don't think the wiring current limits the fuse as much as you think.
The typical British wire for side marker & other light duty circuits consists of 14 strands of .03mm diameter wire. It is rated at 8 amps & is equivilent to 18 gage US wire. It has a resistance of about .019 ohms per meter. At a worst case of 20 ft of wire or 6.14 meters, shorted at the far end, this is .117 ohms. At 12 volts, there would be 103 amps flowing.
Since this represents 1240 watts dissipated in the wire which is tightly bundled with others & reduces heat dissipation, the insulation can melt in spots. As I said, we are protecting the wiring, not the device that it feeds. If the short happens at a critical location & the sparks create an arc near the exposed gas tank with it's inevitable small vapor leaks, there is a potential bang. this is most likely in the event of a minor rearend impact. If a device shorts solid, it is gone anyway, save the wiring but don't sacrifice reliability by using fuses that are too small. You havent addressed the shorter mechanical fatigue life & thermal rating reduction of using light fuses. Do you not believe it or just consider it trivial?
As far as the OD solenoid the most frequent problem is the contacts don't shut off the 19 amps, due to a mis adjusted solenoid or defective switching contact in the solenoid, & the 19 amps remains on continuously. this fries the solenoid when only a small adjustment is really needed to prevent it.
The fuel pump protection is mainly because the pump end of the feed wire is vulnerable & sometimes gets grounded by pinching or coming loose.
I only gave some of the reasons that folks add extra fuses. Not wishing to start an extended debate on the pros & cons of the practice. We can do this off line if you wish. Or maybe you are just trying to draw me out?
Each person will have to decide for themselves wheter extra fuses are needed & what size.
Keoke
Re: inline fuses
Thats great if the overdrive circuit fault causes 19 amps of steady state curent to flow it sure will blow a 5 amp fuse presto don't you agree??---Keoke---The minute that wire starts drawing heavy currebt its resistasnce also begins to rise the current in the circuit decreases and the voltage drop accours across the wire. the total power dissapated in the circuit is essentially constant.Bundling wires in the harness adds to the themal problem due to proximity effect. Good Night All.
fordhealey
Re: inline fuses
regrounded all of the gauges. solved the problem. noted
some blistered spots in wire running from the dash to ground.thought it was easier just to replace it all.
thanks
gregg
Dave Russell
Yoda - R.I.P
Re: inline fuses
Keoke,
For the third time, unnecessarily light fuses present their own reliability problems. Maybe this can be demonstrared to you by the following quote;
"If, however, the fuse is subjected repetitive high current overloads, the temperature in the fusible link will fluctuate causing two types of fatigue - mechanical fatigue and thermal fatigue.
Mechanical fatigue is precipitated by overloads of longer duration while the current stays below the fuse current rating. The periodic heating and cooling of the fusible link will weaken it and the mechanical stresses will eventually cause the link to open. Thermal fatigue is more likely the result when switched higher temperatures in the fusible link caused by the short duration, high energy pulses will lead to grain growth within the molecular structure of the fusible link. This grain growth, which is permanent, weakens the element and will ultimately cause premature opening of the fuse and unnecessary equipment down time."
This would be the case witht the OD fuse if it were set at 5 amps. note the last two sentences.
Keoke
Re: inline fuses
Come on Dave ,Watt Seconds of energy would not produce enough Heat to kill a fly must less heat the fuse.---Keoke
piman
Re: inline fuses
Hello all,
I'm with Dave Russell on the fuse sizing. However, one thing concerns me and that is putting something like a 35 amp fuse or circuit breaker in the main brown feed. Unless ALL the sub circuits are suitably fused, then a short in a minor circuit could shut down the car; not very nice in busy traffic and multi lane roads, not to mention if it happens at night.
Certainly the electrical system of cars of the era we are interested in is pretty basic, but given routine maintenace is reliable. (Less so in cars that are driven only on rare occasions.) Fuse rating were selected to give reliability, hence seemingly high ratings but sufficient to protect in the event of a short circuit.
Alec
mvanderploeg
Re: inline fuses
Keoke, I'm not sure if you're being serious about a wire's ability to limit current flow during a fault, but if so, I've disproven your electrical theories on several occasions through inadvertant experimentation in my garage. Fault current will melt the wires in a Healey or on a 230kV Transmission line running along the highway. I've seen both happen on a variety of occasions. High current will not increase a conductor's resistance nearly enough to have an impact on the current flowing to a fault. Heat will result (current squared times resistance) and the wire will most definitely melt unless protected by an appropriately size circuit breaker or fuse. Fuses in Healeys are sized from the factory to protect multiple circuits, not individual wires, thus the need to add in-line fuses. I guess you could size the fuse anywhere from just above continuous load current to just below the ampacity of the wire, but, as Dave mentioned, the fuse is typically there to protect the wire in the event of a fault, not to protect the load.
Keoke
Re: inline fuses
Mick ,This is time related if the wire resistance increases where does the fuse get it current to blow???-Yes I am serious and garrage experiments can be missleading.-Regerds ---Keoke
Dave Russell
Yoda - R.I.P
Re: inline fuses
[ QUOTE ]
Mick ,This is time related if the wire resistance increases where does the fuse get it current to blow???-Yes I am serious and garage experiments can be missleading.-Regards ---Keoke
[/ QUOTE ]
Keoke,
The energy contained in a short circuit follows the rule of current squared times time. Or I^2 T seconds. The fuse element follows the same rule. Thus a 10 amp fault lasting for .5 seconds has the same energy as a 100 amp fault lasting for .005 seconds. the fuse heat increases much faster with current increase than it does with time increase. Further, the wire resistance only increases by about 0.4% per degree C increase in wire temperature.
Alec,
The typical 35 amp self resetting circuit breaker actuall requires about twice this current to trip. It is only a last ditch device to prevent complete wiring harness burn out.
mvanderploeg
Re: inline fuses
Keoke, you had argued that the wire resistance increases, not me. See your quote below:
[ QUOTE ]
[/ QUOTE ]
My point was that wire resistance doesn't increase, it doesn't limit the fault current, and therefore, the fuse has plenty of current available to blow or the wire has plenty of current to melt if there's no in-line fuse installed. Your last post now seems to argue this same point, which is contrary to your quote above.
We're making this a lot more complicated than it is. A fault will draw current depending on the resistance (impedance in an AC circuit) of the fault. The increased current will either cause the wire to melt, a fuse to blow (melt), or a circuit breaker to interrupt the current. Size the fuse less than the continuous current rating of the wire, & the fuse will melt first. How much less is up to you, but Dave makes some good points for not going too small. If the fuse (or circuit breaker) is sized appropriately, time will be irrelavent. Yes, low fault current will take longer to melt a fuse than high fault current and a fuse rated at lower amperage will blow quicker than a fuse rated at higher amperage for the same fault current, but either way, if it's sized correctly, it'll always melt sooner than the wire it's protecting.
ThomP
Re: inline fuses
Fuse values are often selected by expereience. Keoke, if your experience shows 5 amps is good; enjoy.
As for the wires being self limiting; you just need to check the spot in my boot where the D.P.O. nearley burned the car to the ground to know that the wire isn't safely self limiting.... If that isn't enough "experience", you can also observe the left over bits of red vinyl under my dash to add to the knowledge base. Yes, the wires heat, turn cherry red, decompose the vinyl and open; the resistance is then significantly higher! Unfortunately, that sequence doesn't always occur fast enough to prevent fire.
Keoke
Re: inline fuses
Maybe you select fuses based on experience I do not -To each his own if that makes you happy im tickled to death.---Keoke
Keoke
Re: inline fuses
/ubbthreads/images/graemlins/iagree.gif---Keoke
ThomP
Re: inline fuses
As a matter of fact, I do! (I'm an Electrical Engineer!)
So, if you don't select fuses from experience, how did you arrive at 5 amps for the value for the overdirive solenoid?
B Using inline fuses? Austin Healey 65
S License plate light - inline fuse, BJ8 Austin Healey 7
D Harbor Freight Inline Air shears Restoration & Tools 14
K TR2/3/3A 5/16 inline fuel filter? Triumph 2
P Inline Fuel Filter Austin Healey 10
ChrisS Inline / transverse engine differences British Motor Corp 12
ChrisS Inline / transverse engine differences Spridgets 5
R Installing a block or inline heater in a v8 SD1 Rover / Land Rover 7
V great deal on a rebuilt inline six Triumph 0
TNMGB Stubborn inline fuseholder... MG 6
R Bugeye fuses Spridgets 14
K TR2/3/3A Fuses Triumph 3
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
W Fuses Blowing Austin Healey 11
K TR2/3/3A 30 AMP Fuses Triumph 2
longbridgehealey In line fuses Austin Healey 25
M Fuses Austin Healey 7
M Additional Fuses Austin Healey 3
F TR2/3/3A Fuses Triumph 10
Jim_Gruber Blowing 15A Fuses as soon as I apply the brakes Spridgets 6
K TR2/3/3A TR3 Fuses Again Triumph 1
S TR6 TR6 blowing fuses Triumph 4
T TR6 Blown Fuses Triumph 1
B Fuses for 1960 BT-7 Austin Healey 3
RickB All 4 parking lights dead, fuses all good? Spridgets 6
W Glass fuses Jaguar 3
I TR6 TR6 correct fuses? Triumph 8
H Tr 3 fuses Triumph 10
C AH 100-6 Fuses/wiring...what did I do? Austin Healey 6
Dudly Spitfire Blowing fuses in my 79 spit Triumph 10
af3683 35A Fuses Triumph 14
M Still con-fused about fuses Triumph 22
A Midget Fuses Spridgets 7
A TR2/3/3A TR3A FUSES Triumph 4
longbridgehealey Bugeye fuses Spridgets 5
Thor lights on without any fuses- Any suggestions Spridgets 6
J Additional fuses Austin Healey 1
Paulus MGB 69 MGB fuses MG 8
D Fuses? Triumph 9
Tinkerman TR2/3/3A TR3A fuses Triumph 9
Tronch Adding Fuses Austin Healey 4
19_again Fuses in'66 B MG 12
B fuses Brit vs US Triumph 5
G Question on fuses Spridgets 9
T "British" Fuses Triumph 4
Michael Oritt Switches and fuses Racing 13
Tinkerman British fuses vs American fuses Triumph 17
G British Fuses vs American Fuses...big difference Triumph 17
C Of turn singals & fuses Spridgets 10
G No More Blown Heater Fuses!!!! Triumph 3
