How do you know if NOS parts are compatible?
ichthos
I admit I enjoy looking for NOS for my bugeye. I was thinking of trying to locate parts for a transmission rebuild. My question is is there a list of actual part numbers so that I know they are compatible for my car?
Kevin
jlaird
No
StarkM
I can upload a photo or two of the 1098-1275 2nd gear (oem # 22G1120) if that would help.
Billm
Matt
That would be great-
you are one of the few folks who have access to a new one that is not in a trans already!
BillM
Spridget64SC
There is a 22G2XX series of gearbox components that match up with the 22G11XX series. The .xls spreadsheet on the BCF doesn't list all of them, but does give a clue to their existence. Input shaft 22G229 is the clue. This is the input shaft part number from that series. Part 22G1117 is the actual input shaft number in the 22G11XX series. Don't see many of these out there, but they do exist. FWIW, here is a list of the usual suspect gears & part numbers that cross. This is from memory here at work, my list is at home, but I'll do my best.
22G229=22G1117 Input gear
22G240=22G1114 Reverse gear
22G232=22G1100 Laygear
22G239=22G1118 1/2/R Slide gear
22G236=22G1121 3rd gear
22G234=22G1120 2nd gear
22G95 Early 3/4 Slide Gear
22G410 Later 3/4 Slide Gear (fully interchangeable with the 22G95)
These apply to the ribcase gear boxes. If you are looking at smoothcase gear boxes, then there are some Morris Minor gear that can interchange, but these are very rare and depending upon which ones they are, may have co-dependencies. That is, to use the input gear, you have to use a certain laygear as well, but 1st, 2nd and 3rd will work with the different laygear.
HTH,
Mike Miller
I
ichthos
It is confusing to try and locat parts by part number. I have seen three identical shafts, all with different part numbers. My bugeye was made in August of 1959, although it is called a 1960 bugeye. The second gear listed is just what I need. My transmission is fine for now, but I can tell the built in syncro has some wear. The Ebay ad says it is for a 61, 62 bugeye. How do I know if it will work with mine?
Kevin
I
ichthos
What a bummer. I checked the number against the list Bill posted, and I think the ebay 2nd gear is for a Mk11. Thanks for the tip though. It seems like reproducing parts for the smooth case transmission would have a fairly large market. How come no one has put these into reproduction? I am not a machinest, but is it possible to find NOS and just cast new ones?
Kevin
BlueMax
If your commission number of you car is from 20330 then the second gear on EBay will fit you car, provided you know that your car has its original transmission. If this is an unknown, then it will have to disassemble and inspect the gear numbers for a proper match. The way I look at it you’re not ready to do anything unless you have all this information. So your options are drive it until it brakes or you can’t stand the issues and decide to pull the gear box and open it up and began your rebuild. Option number two, purchase a ribbed case, rebuild and install. And option number three purchase a 210 five speed or T-9 and a adaptor kit and have something that will perform like a modern day car.
Yes, someone could tool up spend several hundred thousand for this idea and reproduce gear set for the smooth case transmission, but for what reason? The smooth case transmission were the worst of all three generations of transmissions for Sprites and Midgets, The only people that would want a smooth case are the people showing their cars in concurs shows. Most of these people are taking the smooth cases and having the case alter to except the ribbed case gears so that they can have somthing that will work a whole lot better and still have the smooth case look.
I
ichthos
My commission number is 21339. I am confused - where does the commission number 20330 come from -is that the beginning of Mark 11? Bill's list shows the same parts for all Mark 1. The part on Ebay is listed under the Mark 11. Aren't all Bugeyes Mark 1? I think the transmission is original, but do the transmissions have a number on them to identify them further? If so, can you tell me where the number is located?
Kevin
BlueMax
Commission numbers are generated by BMC because BMC was the manufacture. As the cars are produce and being assemble the numbers change consecutively. All of this is happing while the engineering department is making changes in the next models. When they have a prototype tested and it’s successful, when manufacturing of the gear boxes are starting to be produced quickly enough to meet with production with the cars is when management makes the decision after production XXXX that the newer gear box is to be installed.
Gear box number will be stamped on top of the gearbox casting.
I
ichthos
I will try and get in there to look at the number. I will check my heritage certificate too when I get home to see if they listed the transmission number. Once I get the transmission number,and if it matches the heritage certificate, are you saying I should should be looking for parts off of the Mark 11 list? I am not ignoring advice on just getting a later model or different make transmission either. My wife wants her original restored and that is that. I don't get to drive the bugeye much - it is basically my job to keep things going. I am just trying to be prepared for the eventual transmission job.
Kevin
BlueMax
Not what I say, but what BMC factory manual says. If your car is from commission number 20330 and it has the original gear box, then part number AEA3033 is the second gear that they say goes in that transmission. I really don’t look at MK1 or MKII regarding this issue. I look at what they say it’s supposed to be compared to what reality really is. Then make a decision base on the reality to correct the problem.
jlaird
All Bugeyes are Mark I, however the Mark II is a bugeye with differnet metal on the front and rear. 1098 eng from 1963. All else is the same. Someone jump on me if I am wrong.
Billm
They did change the gearbox (around the time of the MkII) to a closer ratio set of gears so they are not quite the same.
BillM
AngliaGT Looking for NOS Parts for our '74 Midget Spridgets 2
BobbyD Warehouse Full of NOS Parts Triumph 6
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
M For Sale NOS Champon NA-10 Spark Plugs Jaguar Classifieds 2
S TR2/3/3A 187 NOS sleeved type thermostat Triumph 16
angelfj1 Wanted '59 TR3A Clutch Master Cylinder - USED, RE-BUILDABLE, NOS Triumph Classifieds 4
T For Sale GT6 Mark II Right Front Fender - NOS Triumph Classifieds 0
T Wanted TR6 NOS Backup Lens Triumph Classifieds 0
T Wanted TR6 NOS Backup Lens Triumph Classifieds 1
I Wanted TR6 OEM or NOS aluminum trim rings Triumph Classifieds 9
T General Tech NOS Paper Air Filters, Shelf Life Triumph 2
PeterK TR4/4A Here's what my NOS 511695 cylinder head looks like, unboxed Triumph 10
PeterK TR4/4A NOS TR4A cyllinder head Triumph 5
S Question regarding NOS vs New rear leaf spring bushings Austin Healey 3
Jim_Gruber NOS 10 Post BE Windscreen on E-Bay right now - NFI Spridgets 3
angelfj1 TR2/3/3A NOS Luggage Rack Triumph 3
J WTB: NOS bugeye horn button, and MkII Sprite Hood Emblem Spridgets 1
PAUL161 Nial, NOS Offy for sale! Racing 3
M Healey 100-4 NOS Main Bearing Concerns Austin Healey 3
brgrmyster GT6 NOS Lucas heater fan switch 35560 - 67/68 GT6 Mk1 Triumph 2
R Excited to find NOS 1965 manual with Carb book Triumph 6
I What is your definition of NOS? Spridgets 12
Parker TR2/3/3A TR3A Lamp lenses: NOS / "Lucas" repro differences? Triumph 9
W So you've always wanted a NOS BE steering wheel... Spridgets 13
RickB Sebring/ Lemans Sprite NOS Injected Eng & 5-Speed Spridgets 17
nissanite Speedo & Tach for sale ... NIB NOS Rare .... Triumph 11
W NOS Lucas Sports coil on eBay Spridgets 3
W NOS BE top radiator hose Spridgets 8
M TR6 ??TR6 steering wheel NOS or Aftermarket on ebay?? Triumph 7
T Slightly OT - how long NOS brake cylinders good? Triumph 5
L NOS Racing Screen Triumph 5
W NOS e-brake cable Spridgets 3
W Lucas NOS out the yazoo!! Spridgets 3
angelfj1 AC Fuel Pump Diaphram - NOS Diaphram Triumph 11
A TR2/3/3A NOS TR3 Temperature Gauge Triumph 8
newmexTR3 Name this id plate / NOS badge Triumph 6
Editor_Reid NOS MIB White AMCO Sprite Floor Mats Spridgets 10
RickB MGB NOS left rear bumper for 70 MGB - GONE for $62 MG 0
angelfj1 NOS Lucas listing on Ebay Triumph 6
RickB NOS right side 1970 bumper on Ebay MG 1
W NOS BE front overriders Spridgets 6
RickB Got a NOS "grille finisher" - how does it attach? Spridgets 13
tosoutherncars NOS Smiths gauges: Bugeye? Spridgets 4
RickB NOS SU's on ebay - look a bit different to me... MG 27
J NOS Clutch master Triumph 6
D NOS 1622 Engine on E-bay MG 6
W NOS Brake light switch Triumph 9
boxofparts MGA NOS-MGA Judson Supercharger kit-what is it worth? MG 12
rick_ingram MGB NOS Front Rubber Bumper - MGB MG 0
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
