boeingpilot
Okay, this has me stumped (not hard to do). I have stripped the engine of my '69 GT6+ down for overhaul. I was in the shop today making sure the bores, crank journals, etc. are within specs. Everything is as it should be except the main bearing journals on the crank. Both of my GT6 rebuild guides list main bearing journal diameter at 2.0005 to 2.001. My measurements are (1) 2.296 (2) 2.289 (3) 2.292 (4) 2.293.
After some head scratching I pulled my TR6 rebuild guide and found the main bearing journal limits to be 2.3110 to 2.3315.
Has this car had a TR6 crank installed somewhere in it's past? Is that even possible?
It appears that this is a TR6 crank that has had the main bearing journals ground .020 under.
Of course these things always seem to happen on Sunday when the shop is closed!
