Captive seat track mounting thread repair - ideas?
tdskip
So I cut out a spare captive fitting from the TR7 parts car to try and fix this;
My question is if I "simply" need to open up the sheet metal here to gani access to the captive assembly retraining metal and weld in the replacement metal?
Other ideas?
TR4
Do you not have access from below to use a longer bolt with a nut and washer?
T
tdskip
Re: Captive seat track mounting thread repair - id
Unfortunately not on that captive section, there is a body panel under it...
philman
try this....tack weld a nut to a large fender washer and then weld the fender washer to the body.
DougF
The rivet nuts are a wonderful item. I sell them in my product line. I only question their strength in case of an accident in this application.
dklawson
I have used Phil's method before and it works quite well for this type of repair.
philman
I thought of another idea; weld your captive nuts (or you could use bolts in this case) to some bar stock and welt the bar stock to the flooring. This would give you some additional structural rigidity and allow you to lay in deeper soundproofing.
H Windshield Post to Body - Captive nut needs to be replaced - Pillar to Body Spridgets 2
W TR2/3/3A Why a PO cut these holes in rear floor? Also, question re dealing with captive nuts Triumph 6
AHS TR2/3/3A TR3 kick panel captive nuts? Triumph 3
PatGalvin Captive nuts?? quick question Triumph 7
W Radiator captive nuts Spridgets 10
P Captive Nut Replacement Triumph 15
G TR2/3/3A TR3A rear fender captive bolts Triumph 7
C MGB Re strapping a MGB seat bottom MG 2
T TR4/4A TR4 seat buffer problem Triumph 5
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
A MGB Seat Cover Installation MG 1
tr6nitjulius For Sale 4$ale: 3 Point Seat Belts Red Triumph Classifieds 0
D TR2/3/3A layout for lap type seat belt Triumph 5
R Vixen 2500 Seat Buckets TVR 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Celtic 77 MGB Seat webbing replacement. MG 1
B BJ8 Seat Sliders Austin Healey 4
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
TomMull MGA Rumble seat MGA MG 3
T Three-Point Seat Belts Austin Healey 8
B Seat Inserts Austin Healey 6
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
Celtic 77 MGB Seat Diaphragm replacement MG 0
D New seat covers Spridgets 11
Celtic 77 MGB 1977 seat webbing replacement. MG 1
shadowfever Seat runner with lever Spridgets 2
F TR4/4A Seat rail extension Triumph 4
KVH General Tech Seat Upholstered Panel Triumph 2
shadowfever Midget seat nuts and bolts Spridgets 2
shadowfever Moss Motors MG Midget seat covers Spridgets 6
shadowfever 65-69 Spridget seat Diaphragms Spridgets 5
Challenger TR4/4A Seat Retainers Triumph 1
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
D Rear Seat Side Panels, BT7 Austin Healey 3
M For Sale vintage 3-point retractable seat belts MG Classifieds 0
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
A For Sale '74 TR6 original seat frames Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
C Seat Slide Bearings Austin Healey 3
F Wanted TR3A rear seat peg and clip Triumph Classifieds 2
EricJNewman MGB Modern Seat Tracks in MGB Solution MG 8
crispy BJ8 Rear Seat Back Upholstery Hardware Austin Healey 7
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
J BJ8 Rear Seat Changes, 1964 to Later Austin Healey 9
mrv8q TR2/3/3A TR3A TRF vinyl seat reupholstery kit Triumph 7
J TR4/4A TR4A seat retaining clip Triumph 5
