The knob and the short rod going to the cable moves, but the cable itself is frozen. By the way, how far does the cable normally stick out past the cable sleeve at the end with the knob pushed in? I suspect the cable has been broken at the end. I put in some PB blaster, Jack, and will continue to add it over and over every week and see what happens. Since this switch/cable is not available, I am hoping to get a new cable itself made and installed once I get the old one removed. Has anyone ever tried to just repair the cable itself before? Do you have a source for a new cable? I have rebuilt most of this car myself, but I am perfectly fine with someone repairing this switch/cable. Have any of you sent your switch cable in to be repaired somewhere? Do you have the name of the company you could give me?
Kevin
