Bugeye antisway bar advice
ichthos
I am getting very close to the end of my total restoration on a 60 Bugeye. I have kept it as stock as possible. The front suspension is currently off the car and totally dismantled. I am considering putting in an antisway bar in the front. I have a number of questions: 1) Did these cars come with an option for an antisway bar, and if so, what was the thickness of the bar? 2) Does the antisway bar make much of a difference in the ride in these cars? 3) Is it possible to fit an antisway bar while the front suspension/steering is still in pieces? 4) Is this something that should be attempted by an amatuer? 5) What, if any, are the problems with having an antisway bar? 6) Does anyone have a recommendation for a source for an antisway bar? Answers to any of these questions would greatly be appreciated.
Kevin
Hairyone
Re: Bugeye antisway bar advice
Hi Kevin, I had the same question a while ago. I've hot driven the car yet with it, as I started on the front & am nearing completion on the back.
Check out my posting "anti-roll bar"
GrahamP
Member
Hi Kevin, I'm not sure if the anti sway bar was offered as a factory option but it was certainly a common after market addition.
If you look underneath the two chassis rails, and you are lucky, you will find tapped holes designed to take the mounts for the bar. Also assuming you have fitted recon wishbones you should find holes already in position for the end mounts.
As for, does it make much difference? Yes, thats why they were/are so popular! Regarding amatuer fitting, if the holes are present then it shouldn't be a problem. Otherwise captive nuts need to be fitted into the chassis rails and the wishbones will need drilling in the correct position to take the end mounts.
Hope that helps a little,
Graham.
I
ichthos
I did have the wishbones reconditioned by Apple a while ago. There are no holes in the wishbones, and I wasn't even thinking about that at the time. Would I be better off to just put in the antisway bar after I put the suspension and steering back together? My car is bolted to the top of a 2x4 right where the tapped holes might be. I seemed to remember holes being there and couldn't figure out what they were for at the time.
Kevin
bugimike
IMHO the only way to mount a sway-bar is with the suspension installed! I have a '59 that has the mounting holes already there, so they should be there on a '60. The improvement is well worth it!!
Bugzy59
I have the sway bar from a later midget but the A arms have the holes.
There was a sway bar option for the bug. If I recall correctly, the early sprite option used a sway bar and drop links from a Big Healey. Two holes are drilled in the A arms. I have seen them a few times.
The bug drives better with a sway bar.
mrsprite
Yes it does! My BE came with an aftermarket front sway bar fromthe Winners Circle and when one of the mounts broke I removed the bar to quiet the clunking. The handling and driveability went waaaay downhill and I hurried up and fixed the mount.....it drives so nice now. :smile:
Pythias
My A arms didn't have the holes in them. I drilled them out, but made backing plates to put up inside to keep from weakening them. The ones that come with pre drilled holes have strengthening plates welded in. I made a template out of cardstock then cut and ground them to fit. I did it with the suspension ON the car. With the Arms in hand the backing plates will be easy to fit.
The idea of the sway bar is to help control the tendency of the cars to oversteer, (loose in nascar parlance). Too big a bar and you'll wind up with understeer. I've hears that the ideal size for stock suspensions is the 9 16" bar. just enough to control it. too big and you'll want a rear bar as well to get the "balance" back. It doesn't really affect the ride, but it does affect the handling and directional stability.
I AM an amateur. YOU can do this.
I Original Bugeye antisway bar? Spridgets 5
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
I Bugeye valve rebuild suggestions Spridgets 8
jfarris Immaculate 1958 Bugeye Spotted 4
drooartz Leno's Bugeye Spridgets 12
R BUGEYE SOFT TOP FIT Spridgets 2
R Bugeye splined wheels Spridgets 0
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Basil For you Bugeye/ Frogeye fans Spridgets 5
B Bugeye Electrical Diagram with additions Spridgets 6
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
