Well it's finally getting nicer here in Central Illinois so I'm getting out my '76 Midget. I have a brake fluid leak at the switch assembly(Moss #141-710)where the switch(Moss #181-955)is threaded into the body of it. I tried snugging up the switch but it seems to still be leaking. Does anyone have any experience with this? If I remove the switch is there a gasket? Or can I just remove the switch and wrap some teflon tape around the threads? The switch is nylon and the assembly body is brass.
I'm also wondering if brakes need to be bled? Is this loose fitting letting air into the lines or not?
Thanks everybody! Happy Spring!
Jeff
Jeff
