Bonnet 'channel'
Rut
Where can I find a replacement channel that mounts to the firewall that holds the rubber strip the rear of the bonnet rests on?
Thanks, Rut
Jim_Gruber
McGregor in Canada. He's got the one that fits. He advertises in the back of Classic Motor Sports. Someone will have his number. He doesn't respond to EMail very well but his rubber parts fit. The one from usual suspects is a PITA and does not fit well.
Rut
Rut
Jim,
I'm looking for the metal channel that holds the rubber strip and can't find it anywhere. Thoughts?
Thanks, Rut
rkep01
I think Rut's talking about the channel itself, Jim, not the rubber. You are right, though, about the rubber. the stuff from the usual suspects is way to thick. Had to trim mine by almost 50% to get the bonnet even close to closing. Even then it's too short by about 3". :wall:
Edit: Rut, you beat me to it while I was typing!
rkep01
Rut, check out #4 on this page . It doesn't mention whether or not it includes the channel, but it may be worth a call. Good Luck. :thumbsup:
Rut
Rut
I'm not to the rubber replacement part yet, but will keep this in mind. There is a lot of old rust damage along the rear edge and I would like to clean it up with a new piece. Since I'm going with a front tilt I'm also trying to find a trunk style latch with inside release for the rear hold down.
Thanks, Rut
Millrat
"I'm not to the rubber replacement part yet, but will keep this in mind."
When you do get to this stage, call Mr Macgregor. I hesitated on my door seals against all advice. Wound up calling and having a nice chat as well as getting the right parts. Really pleasant guy to deal with.
rkep01
:iagree: wholeheartedly.
The_architect
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]The one from usual suspects is a PITA and does not fit well.[/QUOTE]
I'm so dumb I have TWO that don't fit--one I bought from someplace in the UK and another from the company whose name begins with M and ends with S. :madder:
JPSmit
I'm so dumb I have TWO that don't fit--one I bought from someplace in the UK and another from the company whose name begins with M and ends with S. :madder: [/QUOTE]
Serves you right shopping McDonalds for LBC parts! :crazyeyes:
JPSmit
and from what I have heard call, don't email.
Rut
Rut
Well I guess I know where I have to order my rubber parts! Now all I need is a metal channel to put it in. I wonder if the part is even available?
Thanks, Rut
nomad
Thanks, Rut
I would doubt it, unfortunatly. How did it ever come to be lost? That is not a part that needs replacing often. I imagine you could fab one that would do the job fairly easily.
Kurt.
Rut
Rut
Kurt,
It's not lost...well, I guess it's lost to the tin worm. The top edge that fits against the firewall is pretty ate up and was covered with bondo.
Thanks, Rut
markberry
I'm pretty sure that piece could be reproduced with a brake and shrinker. It might take a couple of attempts to figure out how to get a bench top shrinker to fit in that tight of a channel. Maybe a production metal fabrication shop would have a tool that could knock it out.
nomad
If the ends are there fabbing a piece that doesn't have to make much of a bend would'nt be to difficult. I've made a lot of pieces by clamping various shapes to my metal welding table and just having at it.
Kurt.
paulsherman
A few years ago, I made a plywood template for the shape of the channel, then found some aluminum channel and bent it to fit. Looks OK and holds the rubber fine.
racingenglishcars
https://www.frogeyespares.co.uk/CatalogueApril2011.pdf
Price list summary, page 2, part number BP042, £29.50, plus shipping of course.
It's a little steep, I would just make a copy of the one you have from 1mm steel plate. (hand formed properly of course)
Jayne at frogeyespares is quite knowledgeable regarding parts supplies for these cars. She's not one of the big suppliers and doesn't have a fabrication facility of her own. But she uses some standard outlets or has several local metal facilities produce some very high quality stuff.
It looks like it's the same that AH Spares sells, also for the same money.
https://www.ahspares.co.uk/products/productdetail.aspx?GUID=7c9b6830-8ea6-4277-83ba-ee8b15e91a8a
here- https://www.ahspares.co.uk/info/en/default.aspx
choose "Online Catalogues", "Sprite", "Inner Body Panels"
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
CARSINC Sprite bonnet emblems Spridgets 4
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
E TR6 TR6 flip-up bonnet question Triumph 4
KVH General Tech Fitting the Hood (Bonnet) Triumph 7
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
Bayless Help please installing bonnet release cable Spridgets 8
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
LAW75 Bonnet Excessive Sway Austin Healey 6
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
K TR2/3/3A The Louvered Bonnet? Triumph 2
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
J Wanted Austin Healey Sprite Bonnet Austin Healey Classifieds 4
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
mch979 1967 MGB GT bonnet issue MG 25
P MG TD Bonnet Upper Sections MG Classifieds 0
longbridgehealey Bonnet stay Spridgets 3
J Bonnet rubbing Spridgets 12
S Forward opening hood / bonnet Spridgets 10
R Mark III Bonnet Badge Austin Healey 9
F TR2/3/3A Bonnet safety hook Triumph 10
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
B Bonnet hinge gasket Spridgets 10
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
GeorgetheTR3 TR2/3/3A Bonnet popper, or something like that. Triumph 5
B Under bonnet fuel Austin Healey 15
charleyf TR2/3/3A Bonnet safety catch Triumph 0
Jim_Stevens TR2/3/3A Bonnet Stay rod safety latch differences Triumph 5
4tecdog Fibreglass bonnet washer fittings Spridgets 5
D 1962 3000 Hood/Bonnet Grille Austin Healey 5
T Bruce Uchida Front Tilting Bonnet, 2008 Spridgets 10
Lin Bonnet Striker Pin Assembly Austin Healey 5
R bonnet hinge R or L Austin Healey 2
longbridgehealey Bonnet belt Austin Healey 16
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Bonnet Latch/Release Adjustment Austin Healey 3
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
fmichaels Bonnet hinge holes Spridgets 4
Rhodyspit75 Bonnet gas struts Spridgets 5
L TR2/3/3A Hood / bonnet plinths Triumph 12
C Under boot and under bonnet paint? Austin Healey 7
D TR2/3/3A bonnet safety catch Triumph 4
N For Sale 1971 to 1980 Triumph Spitfire Bonnet Triumph Classifieds 0
Rhodyspit75 Bugeye bonnet prop rod Spridgets 2
W Electrics, fuel system, under bonnet temp. Austin Healey 3
H TR4/4A question on TR 4 a chrome bonnet letters Triumph 8
anarchy99 Bonnet / hood fit question... Spridgets 2
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
