another 1500 question
regularman
Today was shakedown day. I took a lot of things off the new midget and did a lot of scrubbing and cleaning in the cockpit and trunk area. I basically got things ready so I can start sanding, welding, painting in those areas. When I removed the shifter boot, I found a big glob of foam rubber. It was covering an opening right into the shifter linkage of the 1500 transmission. I don't know if this was a plastic plug or a large welsh plug that is missing but I know this is not right. Does anyone know what goes there? With that done. I need to remove the front fenders next and see how bad that is. There was not any rust through on the inside. Oh, and after sitting a week, it fired right up. Engine seems good except for a smooth idle. I need to read up on zenith carbs and see how I can get rid of all the smog junk so it can run.
JPSmit
Likely the bushing. In terms of the idle, very few get the ZS running right and sometimes taking off the smog stuff makes it harder as it was designed to have it all attached. They also had the water choke. On mine the metal sensor was broken so I went to a manual choke, this after the rebuild but before the SU. (Could have bought the SU with what I invested in the ZS)
dklawson
Kim, give serious consideration to the SU HS4 swap that was mentioned in one of your previous threads. You won't be sorry.
I can't picture where the foam piece you found is located. Can you post a picture of it?
regularman
regularman
What is missing is the cap on the back end of the shift module there. Its not on the moss listing. There is something on the back because I can look right in and see the shifter moving the levers and dirt can get right into the gearbox here. I will try and take a picture later. The plan today is to take the front end off it today and see what bad stuff is under there.
jlaird
Broken? That PDO repair fixed it?
+10 on the su swap....
luv it.
m
regularman
regularman
I am exhausted. Front end is off and many other pieces. I cut out the old battery box in prep for a new one and beat my hands up chiseling off the driver side sill so I can weld a new one on(already have that). The whole engine bay area is now ready to be hit with a coat of naval jelly and then a coat of por-15 and a top coat. I want a light color because it makes it easier to see in there and see if there is a leak. I scraped out all of the old abbington sticky pad that they put in there and found mostly clean metal in the floor pans but I did find one rusted hole area that I will have to weld in a patch for. I have it down so I can see every last wort. I don't know if I will start putting it back tomorrow or not. I am just tired.
I think I will go pick out a color of rustoleum to paint the under hood area with while the por15 is still tacky. I will take pictures tomorrow as well.
Oh and just to let everyone know, I got a lead on a weber dgv carb and cannon intake for this one for $125. I think I might go for that.
bthompson
Cool! Lotsa progress. Take pics as you go, I'd love to see this "in process."
The Weber will get it drivable fast, but be sure to save the original intake for when you upgrade to an HIF4. :wink:
bwm1974
Member
The end cap was also missing on my 1500's transmission. I looked through my emails and found that I ordered it from Little British Car Company in February of this year. Part number is: 848-595 and it cost $1.96. It is shown in Moss online as #58 in the picture linked here: Moss Gearbox Parts
but some reason, it looks like a seal in their picture, even though it really is a metal plug.
Anyway, I recall being able to fit it without removing the transmission from the car. It fits like a freeze plug, so I just tapped it into place.
regularman
regularman
ah, ha I looked at at than and thought it was the rear transmission seal for the output shaft, Thnaks!
dklawson
The cap is also available from VB. I posted the part number in your other thread.
J another 1500 engine question Spridgets 4
mgblue79 Another thought on the 1500 5spd... Spridgets 6
jcatnite Another 1500 at parade rest Spridgets 5
Y MGB Time for another puzzle piece.... MG 5
P Another beautiful Sunday Spotted 0
L T-Series Another brake prob. ? MG 12
T I added another TVR to the fleet. TVR 10
Rut MGB Another sad day! MG 10
T General TR Another trans popping out of 2nd Triumph 14
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
JPSmit you won't likely see another Spridgets 4
D TR2/3/3A Another mystery part(s) Triumph 2
Hamish Racing Another 3 sisters spring with commentary Racing 0
K TR2/3/3A Another brake bleed question....... Triumph 17
Sarastro Another SoCal TR3 Spotted 1
7 Wedge Got another one! Triumph 3
Sarastro TR4/4A Another 50K TR4A Triumph 5
D TR2/3/3A Another mystery part Triumph 8
HealeyRick GT6 Another Satisfied Customer Triumph 3
nichola TR6 Another TR6 back on the road Triumph 1
Sherlock Another cruise night, more interesting British iron Spotted 2
D TR2/3/3A Another Carb question. Triumph 22
Healey Nut Another Use for J-B Weld Austin Healey 5
D TR2/3/3A Have exchanged one leak for another. Triumph 10
dbenichou289 TR2/3/3A Another exhausting thread Triumph 10
D TR2/3/3A Another mystery part..or two Triumph 14
John Turney Another Article to Criticize Austin Healey 5
tr6nitjulius TR6 TR6 made another list! Triumph 5
Lin Another Trafficator/Control Head Question Austin Healey 10
Rob Glasgow Can I find Another one as Good? Austin Healey 4
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
Editor_Reid Bought Another One Austin Healey 14
tr6nitjulius General TR Triumphest 2019 another one bites the dust! Triumph 2
pkmh Yet Another Oil Question! Austin Healey 8
P TR2/3/3A Another Differential Question Triumph 22
Bob Claffie Spotted another AH Spotted 0
SherpaPilot TR6 Just Another TR6 Column Question Triumph 4
TomMull Post-War Other HERALD Simple Task turns into another project. Triumph 11
jackq Another building full of cars available. Other Cars 0
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
Lin Another trafficator issue Austin Healey 8
B Another OD question Austin Healey 32
Elva164 Finally did another onboard video! Racing 4
Sarastro TR4/4A Another milestone: first engine start Triumph 8
RAC68 Another Discussion of Trans/OD Fluid Austin Healey 14
Y MGB Another question - this time on seatbelts.... MG 2
PC another one bites the dust... Restoration & Tools 0
AngliaGT Another MGB Spotted 0
