AMCO Wiper blade replacement
  • Thread starter Deleted member 7471
  • Start date
Deleted member 7471
My TR4-A is fitted with Amco wiper arms and 11" blades. Does anyone know if replacememt blades are available for Amco arms. I ordered a pair of blades from VB, naively assuming they would fit - not close. Can't even use the rubber insert to slide into the Amco frame - different widths. My web search wasn't any help.
Or, is the only option to get new arms. I would not like to do it, the ones I have are perfect.
Thanks
Glenn
bobh
Glen.
Bosch makes a wiper for the TR6. It includes the frame which is black.
I bought a set of VB frames and blades. the quality was pitiful. I ordered Bosch frames and blades through Advanced auto.
If you still have the inserts from the original arms you may want to look in an Amco catalog. In the back they have various inserts. You may be able to match the cross section and measured width to something. Their catalog may be online. You may also want to check other wiper manufacturers catalogs.
Someone else may know for sure, but I doubt the Amco wipers were factory installed. I'm guessing the TR4 arms and frame are silver or chrome. If you cannot find an insert you might consider stripping the black finish from a Bosch frame and polishing the metal. It's been awhile since I looked at my Bosch frames, I think they are all metal.
TR3driver
Great Pumpkin - R.I.P
FWIW, I've had pretty good luck buying wiper refills that were too long and cutting them to length. Take the blade to your local auto parts store and look for a refill that has the black plastic spine (with a groove for the blade to engage), and the right width.
Since I only need 7" refills, I can buy 14" and get two for one /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
Andrew Mace
Re: ANCO Wiper blade replacement
I'm assuming you both mean Anco, not AMCO. I'm pretty sure the Anco name derives from "Mary Anderson [who in 1903] devised a swinging arm that swept rain off the windshield when the driver moved a lever located inside the car. Anderson patented her invention of the mechanical windshield wiper in 1905..."
Original equipment was, I think, British Trico. Are you sure the arms are not original? Does one have the bend to clear the cowl vent, or are they both the same?
Deleted member 7471
Andrew,
Thanks for the clarification, I am recovering from a "D'oh" moment. Very interesting about Mary Anderson, and a good read in Wikipedia
(Had it not been for her, I guess we would not be able to drive in the rain (but there would be fewer rusted British automobiles)
Arms and blades are stamped Anco, don't know about the originality, now I just need to find an 11" stainless steel one.
Geo Hahn
As noted, easy to slice & dice your own refills from the plastic variety.
On the TR3A I use a pair of those funky original style blades (several layers of thin rubber make up the wiper edge) for appearance sake but carry my modern replacements (already mounted to spare carriers) in the boot if it ever rains.
Deleted member 7471
I just got back from Wally World and they carry Anco blades (not 11" with stainless frame though). Turns out today's rubber insert is the perfect match for what I need. I took everybody's advice, bought one 22" blade assembly ($4.44), removed the rubber wiper part, cut it in half and pushed into my existing stainless frames. It was so simple, didn't even need the Easy button.
Thanks for all the tips.
Glenn
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
N Wanted Amco Luggage Rack Triumph Classifieds 2
Rut TR4/4A Amco wind wing repair Triumph 7
zmarco TR2/3/3A Amco Scuff Plate Template needed Triumph 3
Kleykamp TR2/3/3A Amco seat covers Triumph 0
3 TR6 AMCO Console TR6 Triumph 2
R TR4/4A I will be selling my TR4 amco badge bar Triumph 0
R TR4/4A Amco tr4 badge bar ? Anyone want one? have one? Triumph 4
Gliderman8 Replacement Amco luggage rack Triumph 12
bt7tricarb AMCO part numbers... Austin Healey 5
RickB This is cool - AMCO accessories on a MKII Sprite Spridgets 21
Editor_Reid NOS MIB White AMCO Sprite Floor Mats Spridgets 10
J Proper AMCO Tonneau cover for BN2? Austin Healey 5
G Amco bumper bars Triumph 2
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
D TR2/3/3A wiper motor parking? Triumph 17
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
R TR2/3/3A TR3 Wiper motor Triumph 10
G Toyota Wiper Blade Inserts - Cheaper Option Other Cars 3
R TR2/3/3A Wiper Arms Triumph 8
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
R TR2/3/3A Windshield Wiper System Triumph 2
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
T TR2/3/3A wiper motor short Triumph 2
MGTF1250Dave T-Series TF Windscreen Wiper wiring MG 4
Sopwith_Camel mk2 windshield wiper nozzles Jaguar 4
nichola TR6 Rebuilder or replace wiper switch? Triumph 7
M TR6 Wiper washer knob Triumph 5
B TR4/4A Rubber wiper motor mounts Triumph 4
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
BoyRacer Windshield Wiper Wheelbox Austin Healey 4
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
W TR2/3/3A TR2 wiper motor mount Triumph 1
steveg TR6 Late Wiper/Washer Switch - What Happened? Triumph 3
RAC68 Wiper Motor and Arm Adjustment Austin Healey 8
P Wiper direction Austin Healey 9
R GT6 Wiper Motor problem and time capsule Triumph 4
N TR2/3/3A Wiper motor armature Triumph 11
T Windscreen wiper wheelbox rubber shaft seal Austin Healey 4
RCarr 1954 BN1 Wiper Wheelbox and Rack Austin Healey 3
Jim_Stevens TR2/3/3A Wiper motor hookup Triumph 4
M Wiper Motor Problem Not Working Spridgets 5
B TR2/3/3A Windshield Wiper mount rubber Triumph 3
J TR2/3/3A Wiper Motor bracket Triumph 5
