TR6 73 TR6 windscreen removal
ecutr6
The scuttle on my 73 TR6 is badly pitted, and I need to remove the windscreen frame to begin restoration. I have removed the hold-down nuts from the windscreen, and have loosened the holding bracket nuts, however the frame will not come loose. Any suggestions?
Banjo
Yank like h*ll!
Really, open the door and stand in the footwell while you pull and wiggle on the uprights. It's tough but it'll come.
(note) I've always done this with the glass out. You get a better grip, and dont risk breaking the glass.
G
You are going to have to actually loosen the holding brackets themselves. This can be accomplished by gripping the brackets with a pair of vice grips pliers and working the brackets back and forth in a circular motion around the long threaded bolt that is part of the windshield frame. Try to do this without #1 overgripping the bracket and crushing it, and #2 screwing up the threads on the bolt. Some of the gripping can be done on the wings of the bracket, again without destroying it. Penetrating oil will help. The rod tends to rust (bad) or freeze (normal) into the brackets after being cranked down for 30+ years. It's doable, just have to be patient. There won't be a whole lot of back-and-forth play in this bracket so don't expect to see it move a lot. As stated above, might be better to take out glass and change all rubber (and maybe glass) anyway. (Point to remember, replace glass as very last step in frame restoration.)
Bill
jerrybny
I removed my 73 TR6 windshield twice. Both times all I did was as Banjo said. I kept working each side until the 30+ years of crud loosened and I was able to pull it out. Hsve faith. It will come out. Both times my windshield was still installed. Just be careful. Hope this helps
DougF
Also try a good penetrant and let it soak over night.. Be very careful if you loosen the bracket from the body. It can pull up with your frame and put a nice dent in the body. The result of which is an increased vocabulary and more work. Light tapping on the top of the frame above the brackets with a rubber mallet or dead blow hammer could loosen the rust. Be careful as it could also loosen the molecular structure of the glass and cause even more work.
It just doesn't make sense. These cars should be called "work vehicles", those other things are just commuter cars.
DougF
Run a nut up on threads of the frame. If you can access the area, tap on it to loosen the rust or paint. Tapping on the top of the frame will only cause problems. Do not loosen the brackets from the body.
E
ecutr6
Many thanks for the suggestions. Will try over the holidays and let you know which one worked.
BTW, just found this site, and it is paying off already. Three of us at work have LBC's, and are all logged on.
Eric_C
Get a bunch of buddies around one day and they can help! Serve up a cold one or two and you will get the job done. Anything British will do!
2wrench TR6 Need help on '74 TR6 windscreen frame removal Triumph 6
ez_pa_6 TR6 TR6 windscreen assembly removal Triumph 5
E TR6 Windscreen removal Restoration & Tools 2
hondo402000 TR6 TR6 Windscreen remove and now windows dont fit Triumph 3
P For Sale tr6 windscreen Triumph Classifieds 0
I TR6 TR6 windscreen rubber seal help Triumph 2
TR6oldtimer TR6 TR6 windscreen and rear flat black Triumph 4
tr6nitjulius TR6 '72 TR6 Windscreen Washer Switch Triumph 0
R TR6 '71 TR6 Windscreen Vin Tag Rivets Triumph 1
R TR6 '71 TR6 Windscreen Restoration Triumph 1
I TR6 Windscreen adjustment help for TR6 Triumph 8
2wrench TR6 Need help removing glass from '74 TR6 windscreen. Triumph 13
TR6oldtimer TR6 TR6 Windscreen washer reservoir location Triumph 2
AltaKnight TR6 TR6 windscreen wipers Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
AngliaGT ANOTHER TR6,& an MGB Spotted 0
A For Sale 1974 TR6 Triumph Classifieds 1
