TR2/3/3A 70/90 Gearbox oil and Synchros degrading?
karls59tr
Bronze
I drained the oil from the TR6 box in my TR3. There seemed to be lot of tiny brass like flakes in the old oil which I assume are from the synchros. Is it normal to have some synchro swarf in old oil or are the properties of the 70/90 gear oil degrading the brass synchros.?
I've heard that GL4 gear oil does not affect the synchros but that it is difficult to find.....up here anyway. Apparently Redline makes a GL4 70/90 gear oil. Anyone using the Redline and did they find any difference in the way the gears shifted? I've also heard that in older gearboxes the Redline tends to leak somewhat?
3798j
Bronze
I use and like Redline's MT90 (https://www.redlineoil.com/product.aspx?pid=46). Makes both my Triumph boxes, a Muncie, and a Top Loader shift smoothly (up and down and even when cold). I've read (here) that some find that it leaks past seals more easily than what they previously used. I really don't think it does.
Geo Hahn
I use the Redline & have some small leaks -- but I doubt I can blame to oil for that.
Some 'gold dust' in the oil is not unusual in my experience. How much is 'a lot' I couldn't say.
TR3driver
Great Pumpkin - R.I.P
The "gold flakes" are not caused by the oil degrading yellow metal; because the degraded metal is black and powdered very finely.
IMO they are also more likely to be from the thrust washers than the synchro rings. Hopefully, you are just seeing some early "bedding in" that will stop.
I likewise use Redline MT90, and found that, for me, it significantly improved the synchro action. No evidence that it increased leakage, but I also changed the input and output seals (an easy task with the box out of the car) when I converted.
Another good option is Valvoline 20W50 Racing oil. Certainly a lot cheaper than the Redline, and worked well for me for many years. That's what I used before switching.
RJS
I doubt you have much to be concerned about. My gearbox (OD unit) was rebuilt about 14 years/ 11K miles ago. For unrelated reasons, I have probably changed my gearbox oil 3 times in the last 4 years Went from GL4 to SAE30 oil, to Redline MT90, to 20W-50, finally back to GL4. Each time I noticed a gold metallic shimmer in the drained oil. Honestly, for all I know, oil off the self may have the same characteristic.
So far, gearbox still performs flawlessly and I've had no catastrophic failures. So, I while I was initially concerned, by this point I am satisfied nothing is wrong.
Bob
C Gearbox oil British Motor Corp 3
S Add ZDDP to gearbox oil? Austin Healey 29
Lin Gearbox Oil Austin Healey 4
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
R Gearbox and Overdrive Oil Level Austin Healey 18
ckeithjordan TR2/3/3A Gearbox Oil Improvement Triumph 7
D gearbox and OD oil drips Austin Healey 23
B TR2/3/3A Gearbox/OD oil Triumph 12
S TR2/3/3A TR3 Gearbox Dipstick Question on oil level Triumph 18
G Gearbox and overdrive oil change Austin Healey 15
S TR4/4A What kind of oil in overdrive gearbox? Triumph 5
gbtr6 General Tech What oil to use in the gearbox, not rebuilt. Triumph 9
C 3000 gearbox oil Austin Healey 4
Lukens Best gearbox oil... with overdrive? Triumph 16
P Engine & Gearbox Oil Austin Healey 3
memphis Gearbox Oil Seal Austin Healey 9
memphis Gearbox Oil Austin Healey 15
MadRiver Multi-grade oil in gearbox? Austin Healey 2
mgnewbie Speedi-sleeve for the gearbox rear oil seal MG 7
mgnewbie Oil dripping from gearbox MG 5
nicko oil in gearbox Austin Healey 10
V Oil capacity of Datsun gearbox Spridgets 1
V Datsun gearbox: what kind of oil do you use? Spridgets 10
A Vexing gearbox oil leak Austin Healey 5
C Need info on gearbox and rear end oil for midget Spridgets 5
dklawson Spitfire Spitfire - Gearbox & Oil Pressure? Triumph 17
R Gearbox oil 100/6 Austin Healey 5
H MGB-GT Where is the gearbox oil filler plug on a 67 GT? MG 3
D Gearbox Oil Lotus 7
OregonTR4A Adding gear oil to the gearbox? Triumph 8
R gearbox identification help & required gearbox oil Spridgets 4
HEALEYJAG BN1 Gearbox oil Austin Healey 9
J Gearbox front oil seal Spridgets 8
Wana Gearbox and differential oil change Austin Healey 8
B gearbox oil Triumph 8
mylillooker Gearbox Oil/Fluid/Grease Spridgets 6
S Oil change in Gearbox & overdrive - extra parts ? Austin Healey 4
Woodie gearbox oil Spridgets 13
C Gearbox Oil leak? MG 10
G Gearbox oil leak? MG 3
dkj313 76 gearbox oil MG 3
DerekJ Gearbox oil level and over-filling Austin Healey 11
Z Gearbox oil and other notes by chris dimmock Austin Healey 2
B Wedge TR8 Gearbox Oil Triumph 5
sparkydave Gearbox oil question Spridgets 4
S MG Midget 1275 Gearbox Oil - Help Needed MG 3
TNMGB Checking/adding gearbox oil?? MG 34
Geo Hahn TR6 How to change gearbox oil in TR6 Triumph 11
S gearbox oil Spridgets 5
J Gearbox Oil Fill? MG 16
