TR4/4A 67 TR4A Generator Paint Colour
JDstr4a
Since I removed the exhaust and started to clean up the block a little,
I removed the generator and am continuing clean up of surface rust and mouse lefovers
and was wondering if the body of the generator was black and the ends ala natural? Would you recommend high temp paint?
and last, any thing to be aware of if I decide to remove the starter and clean it up?
Thanks
JD
TR3driver
Great Pumpkin - R.I.P
I believe that is right, black paint for the (iron) body and natural for the (aluminum alloy) end plates. Ditto for the starter.
Engine paint, yes.
Not sure if this is true on the later cars, but it's something to watch for: the electrical stud on the starter (and possibly the solenoid as well) does not use standard SAE threads, nor is the nut a standard size. You'll need a Whitworth socket or adjustable wrench to turn them without damage. And be sure not to lose the nuts!
Geo Hahn
Since you've got that side of the block exposed, you might think about adding back original style engine markings. I assume these were used on 4As as they were certainly used on 3s & 4s.
Typical markings:
J
JDstr4a
Thanks guys. :bow: I don't see any markings, unless they are behind the starter. I also don't have the stamped numbers. I think I'll go ahead and pull the starter and get everything painted before my brother comes up next weekend, so maybe I can convince him to help me put the new exhaust on. :whistle:
bobhustead
I recall the generators to have been black, althought my TR4 memory is dim. Having come this far, I assume you will do a full service/testing on the part. R&R starter is straightforward.
Bob
J
JDstr4a
Thanks Bob. It tested good during my electrical issues, which were resolved by replacing the control module, right after I picked her up.The generator was in pretty bad shape cosmetically, as is the starter, so as long as I had the manifolds off I decided to degrease and clean. The starter is right below where the nest was,
so i need to get it off as it seems to have filled up the gap between it and the block. Still picking out bits of straw and corn husks here and there.
G TR4/4A TR4A generator to alternator conversion Triumph 2
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale TR4A Grille with Embedded Fog Lights Triumph Classifieds 0
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR4A Live axle frame Triumph Classifieds 0
D TR4/4A Tackling the biggest problem with my TR4A.... Frame Damage :[ Triumph 70
