4.2 series 1 e-type throwing coolant
Jim_Newman
So, I pull into my garage after a nice run and the header tank overflow pipe is expelling coolant at an alarming rate. The engine had not shown signs of overheating and the fan had not come on. The bonnet did seem really hot to the touch though. Suspected problem - blown head gasket. Pulled head, found it to be slightly warped (0.005in), had it milled, replaced gaskets and all cooling system hoses, put it all back together and took it for a drive. When I pulled into my garage, coolant again started exiting from the overflow. Again engine did not appear to overheat when driving. Could this be a sign of a cracked block? Tell me it isn't so and that some simple problem is the culprit.
Thanks for the help.
Jim
toysrrus
Hi Jim,
I`m typ. on the Spridget & Triumph forums. I`ve owned 4 E-Types (Series I & II). I`ve never had that problem but overheating was always a problem especially in stop & go traffic.
What I would check first (Cheap Check) is the "Overflow Cap". I used to drive around with the cap loosely fitted so It can vent. Whats the PSI reading on your cap? What you may also want to check is to see if the Hoses are collapsing or not. Of course the other thing; "Thermostat" but you say the engine is "NOT" overheating? Find yourself one of those "Digital Heat Guns" (Most Service Stations etc have one) & check the temps at all points (Engine, Radiator, Thermostat, Overflow, Exhaust etc). That should tell you if your "Guage" is reading correctly! With the Bonnet hot to the touch; You just may be "Overheating"!
"Cracked Block"? These loveyl engines are virtually "Bullet Proof" so that is most likely "NOT" the problem (I would hope so anyway)!
My $.02 worth. I`m sure there are some folks here who could dwell on that further.
Best Wishes,
Russ
mikespain
Try changing the cap first,it might be blowing off at a low pressure as it is not showing overheatng,the early 3.8 used a 4lb cap later used 7lb cap series 1 4.2 uses 7 lb cap later S2 non AC uses 7lb and with AC and the S3 use a 13lb cap.The temp always rises slightly when you first stop as there is no water flow or air flow to cool the engine so the water expands some and creates slightly more pressure.As Russ says unlikely to be a cracked block
Administrator
Boss
I would concur with checking the cap first. Back in the day before I took my Series I apart for restoration, I had a similar problem due to a bad cap.
Jim_Newman
Jim_Newman
Thanks all for the advice. I'll let you know if it works.
Just a follow up question - Is there a valve somewhere on the head that permits one to bleed air from the cooling system?
Thanks again
Jim
Jim_Newman
Jim_Newman
Installed new 7lb. cap and went for quick drive. Came home, coolant stayed put. No puking this time. But it was a cold day. I won't know for sure till the hot weather driving comes back - but I'm hopeful.
Thanks for the advice.
Jim
Administrator
Boss
Thanks again
Jim
No, I don't think so. There is a spigot on the block but that's for draining the block. Any air should naturally aspirate out as the fluid is circulated. If not, then you may be sucking in air, which could point to a bad head gasket.
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
M E-type series 1 plastic dash vents Jaguar 1
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
D Series II E-Type tire size Jaguar 9
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
Q Series 1 E Type Clutch Jaguar 2
D Series III E-Type Overider Rubber Installation Jaguar 2
H Joan Baez flat floor series I e-type roadster: what did the authorities dump it for? Jaguar 0
Simmo Series 3 E Type Brake Bleeding Jaguar 2
J Question about Series III XJ6 Motor in E Type? Jaguar 2
krswen Anybody own Series 1 E-type coupe 1E 32257? Jaguar 2
weewillie Red series 1 or 2 E type Spotted 0
glemon Series 1.5-2 E type, flat towed Spotted 0
glemon Series I E type project Jaguar 17
HEALEYJAG series 2 E-type eyebrow chrome "clips" Jaguar 0
B Series 1 E-Type fuel pump question Jaguar 2
S E-Type 4.2 Series II Performance Exhaust Jaguar 1
jjbunn E-type Series 2 PRNDL shifter ID plate and parts Jaguar 0
rovernut 1970 series 2 e type serial number location Jaguar 6
T Series 2 E-Type Diff Oil Leak... Jaguar 5
Steve Red Series 1&1/2 E-Type.... Spotted 0
Bruce Bowker Series III E Type Jaguar 9
Basil Drool Series I E-Type Jaguar 10
HEALEYJAG series 2 e-type bonnet Jaguar 14
HEALEYJAG e-type series two oil filter Jaguar 6
Jagboy69 E-type Series II Power Steering Pump Jaguar 0
M Looking for a E Type Series III Bell Housing Jaguar 1
S Performance Exhaust for E-Type 4.2 Series II Jaguar 3
C Series II E Type Clock Battery Jaguar 2
Rick60 E-Type Series 3 V12 distributor Jaguar 5
S E-Type Series II OTS Exhaust Jaguar 0
S E-Type Series II OTS Sound System Upgrade Jaguar 0
D Series 2 E-Type won't rev. Jaguar 6
B 69 Series II E-type Hardtop window Jaguar 0
S Bouncing Tach on Series III E-Type Jaguar 4
R Radiator -Series 1 E-Type Jaguar 0
L E-Type Series II vacuum connections Jaguar 0
G Series III E-Type problem to look out for Jaguar 1
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
sim A-series Engine Block Search Spridgets 2
Deanrobert Xke series lll cooling issues Jaguar 5
zoohow TR2/3/3A lights in series Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
PAUL161 T-Series T Series Starters MG 0
PAUL161 T-Series T series tierod ends MG 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
A Making an A-series engine stand adaptor fitting Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
L BMC A-series: Oil in coolant British Motor Corp 6
