100 Choke Modification
TodE
Has anybody done or know of somebody that has modified or replaced the choke assembly on a 100-4? It does not work very well. For those who have not seem one, basicaly you have the cable that pulls up on a "stirup" setup that then pulls the choke levers up.
The problem is that, sometimes it will only pull up one choke lever, if any at all. So to adjust the choke you need to pull up on the choke levers (both), pull down on the choke cable, and tighten a tiny screw that holds the choke cable in place. All in a very tight spot.
There has to be a better way!!
andrewss
I have just finished a modification for a client for the very same problem on a BN1 100/4. I will upload some photos tonight and a description of the solution I came up with.
Andrew
MikeAH100M
I am having the same problem. I addition, it is difficult to get the choke to stay in a set position. Pictures would be very helpful.
andrewss
The pictures probably don't do the design justice but the drawing makes things a little clearer. First of all you need to go to a bicycle shop and buy a brake cable with a nipple and an adjuster (which fits normally on the brake lever and allows you to adjust the cable). The brake cable has a soldered nipple that you will use instead of the awkward screw that normally allows you to adjust the choke cable. The brake cable is the same size as choke inner cable so slips in place of the original cable. You need to solder the cable at the choke Knob after having heated the old cable up with a small blow torch so you can change it. Make sure that the cable length (when you cut and solder) allows you to adjust the tension of the cable. I made a 'V' shaped bracket (bought from a hardware store) to which I added a nut and bolt (filed flat on the top side) and then drilled a pilot hole for the cable (2/3mm) followed by a second (6mm) in the same hole but only half the depth to accept the adjuster. The inverted 'V' bracket for the two choke arms is made from aluminium with small screws located to attach the arms. None of this required welding although this is an option..
steveg
Another method would be to adapt your setup to a BJ8-style two-cable solution. I did that with teflon-lined bicycle cable sheaths and setscrews at the cable housing ends to hold everything tightly in place and it positively opens and fully closes the two carbs. I believe a setup like this deals positively with one carb choke lever which was sticker than the other.
See:
https://www.pbase.com/stevegerow/image/109657958
and succeeding photos.
BLU_HLY
Member
The 'wishbone' wire was removed and replaced with a clevis arrangement that allows the choke to move more easily.
attachment.php
L Choke Mechanism 100/6 Austin Healey 26
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 3
A 100/6 BN4 Restoration Austin Healey 7
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
andrea 100-Six Photo Album Links Austin Healey 1
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 1
prb51 100-6 Drum Brakes Austin Healey 9
S 1958 100/6 Bumper Brackets Color Austin Healey 2
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Michael Oritt 100 Flywheel Weight Austin Healey 16
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
boxofparts 100-4 Engine Options Austin Healey 12
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
K 100-6 Interior Austin Healey 4
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
R 100 Motor and Gearbox Available Austin Healey 2
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
C For Sale Parts, Factory Manual, Restoration Guide for 1959 100-6 Austin Healey Classifieds 4
T 100-Six Clutch Recommendations Austin Healey 5
J Owners of my 100-4 Austin Healey 1
andrea AH 100/6 1957 Longbridge Photo Albums Austin Healey 5
