100/6 Hood parts
Leew
Hi People...long time no speak
Time to try and fit a hood to my 58 100/6 Vin No 59375, so an early Abingdon car
I have a frame, but not much else apart from one hole either side
Anyone have a picture of what I have missing and how things should be or what I need?
many thanks....in anticipation
Lee
Kainopong
I have an early Abington car as well. You will want to check Derek's site at www.healeysix.net. You will need the Longbridge style top. The holes receive a two piece arched rod to support a tonneau cover but I believe that was for only cars from 68xxx on. Also, the wheel well arch should be fit with vinyl not carpet (https://www.john-skinner.co.uk/austin-healey/) and the trunk section should be painted body color- I don't believe that was covered in Carpet. You will also need the sliding rail and clip for the Top, available at British Car Specialists in Stockton CA or others as well as the bracket and rubber retaining slot for the top when its up (which is never with my car LOL) - David may be able to help you as he has a Longbridge car if I recall. https://www.healeysix.net/Longbridge Top.htm
Hope that helps!
bob hughes
Lee
If you have a camera, take it, and yourself, over to Bill Rawles, he has a load of Healeys kicking around and I am sure that he will have a BN4 in.
To make sure, give him a ring first, you will find him very helpful. You can never get exactly what you want from books.
:cheers:
L
Leew
Just back from Bill Rawles and at first I thought I would need an Abingdon style fixing. ( I did not take the car unfortunately ) Initially I thought given my car was built in March 1958 and is numbered 59375 I would need the Abingdon style hood . However it appears I could need the Longbridge sliding type mechanism as there are no hood mount panels in place with holes to accept the folding frame as well as the tonneau support bar. In speaking to bill he did say the mount panels were available and could be welded in ( see link ) https://ahead4healeys.co.uk/HOOD-MOUNT-PANEL---RH-id3096.aspx so I just assumed the car had been modified. However coming home and thinking about it, and after reading the Healey 100 six page I think it may be one of those crossover models with a Longbridge style hood fixing despite being an Abingdon built car. I must say, looking at my Heritage trust document the prefix for the chassis number is LO/59375 which surely makes it a Longbridge car whereas for some reason I thought it an early Abingdon car. Is that what the LO relates to?
Thanks fellas
Editor_Reid
Platinum
Thanks fellas
Without knowing the entire Car No. (VIN), I believe that the LO means Left Hand Drive and equipped with Overdrive. Is the entire Car No. BN4L-O-59375? Either way, your car was built at Abingdon. The highest-numbered 100-Six built at Longbridge was 54285.
L
Leew
Thank you Reid...absolutely correct. Sometimes old age gets in the way of memory. I did my research a few years ago when I bought the car and looked up all the VIN and it's meaning. Yes, it's an Abingdon car. How do I determine which type of hood it would have been fitted with ? I'm leaning towards Longbridge but how do you fix those sliding runners?
Kainopong
You should have a Longbridge style hood. The sliding bracket and spring nut are available but you will need to find the correct top, purchase and mount the retaining bracket and rubber. Derek's site should be a big help - check out the Longbridge top section. The runners just bolt on.
John Turney
If you have a hole on each side that the hood frame fits into, you have an Abingdon car. Your car number agrees with that. You will not have sliders.
healeyblue
If you pull back the carpet you will see the holes in the side wall for the slider brackets. There should also be holes for the toneau support brackets. On the left side there will also be holes for the bracket that holds the rubber block that the top secures into when in the up position. Here is a picture of what it will look like if you have the Longbridge style top.
L
Leew
Okay....I've done some research and it seems there were Abingdon cars that had Longbridge hoods fitted in the very early days of March 58, exactly when my car was built. So I am going with the Longbridge fixings which I will confirm tomorrow when I strip the carpet back
healeyblue....thanks for the image, that is really helpful
Kainopong
Yep - he is spot on. I have a feb 58 car and same deal- finished like a Longbridge. Except the side curtains which are flat bars but still need the star nuts.
L Wanted 100/6 Longbridge hood parts Austin Healey Classifieds 3
L 100/6 BN4 Hood fittings Austin Healey 5
bighealeysource Help - hood stuck on my 100-4 Austin Healey 17
Michael Oritt 100 M hood louvering info Austin Healey 4
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 6
A 100/6 BN4 Restoration Austin Healey 7
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
3 100 Clutch Freeplay Austin Healey 7
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
andrea 100-Six Photo Album Links Austin Healey 1
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 1
prb51 100-6 Drum Brakes Austin Healey 9
S 1958 100/6 Bumper Brackets Color Austin Healey 2
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Michael Oritt 100 Flywheel Weight Austin Healey 16
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
boxofparts 100-4 Engine Options Austin Healey 12
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
K 100-6 Interior Austin Healey 4
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
R 100 Motor and Gearbox Available Austin Healey 2
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
C For Sale Parts, Factory Manual, Restoration Guide for 1959 100-6 Austin Healey Classifieds 4
