Screen for warm air side
RestoreThemAll
I know that I shouldn't ask why with these cars...why does the cold air intake have a screen on the air hose (behind the grill) but the warm air side doesn't?
While I'm working on the body paint my son is fine tuning and tying up loose ends. Whats the best way to add a screen to the warm side, similar to the cold side?
Dale
Keoke
easy. Bugs have a straight shot on the cold air side, they get chewed up by the heater blower on the warm air side.
yep--Rick--lol
R
RestoreThemAll
So if I don't want critters of all sizes in my air ducts is there a best solution?
R
RestoreThemAll
That should work Rick.
I was also looking at the parts catalogs. The cold air flange air intake (screws to the firewall) with a wire mesh screen glued to it might work.
Rob Glasgow
Dale, if your worried about bugs entering the hot air duct then you're better off placing the screen at the intake at the front of the duct and not right before it enters the cockpit. It would be much harder to clean the collection of bugs from the flange on the firewall.
R
RestoreThemAll
Rob, I was planning on installing at the radiator opening, not the firewall.
Dale
R
RestoreThemAll
Steve, would mice or bugs get in during storage?
Dale
HealeyRick
Dale
My radio is installed on the bottom of the heater box:
Today, I had to drop the bottom plate of the heater box to get to the back of the radio to install an auxiliary cable that will allow me to play tunes from my iPhone through the car radio. As soon as I dropped it down, I saw a goodly supply of chewed acorns. I had cleaned the box out a few years ago and also at that time found mouse nests in the steel heater ducts running across the front of the car. So the little s.o.b.s are getting in there somehow, most probably through the hot air vent. Rather have them hanging out there than in the wiring or upholstery, though.
t
Rob Glasgow
Chewed acorns? I'll see that and raise you some bird seed. I think Donald Healey must have had a soft spot for little critters, so he designed a warm spot for them to gather.
R
RestoreThemAll
I ordered and received parts meant for the cold air at the fire wall. See attached pics. They are not attached to the car yet. I haven't decided how I'll install yet.
RDKeysor
Bronze
I have no screens on either hose and haven't had any issues with material blowing into the car. Since I am in North Florida and have my heater tap shut off, I chose to disconnect the hoses on both sides of the heater fan, telescoped them together, disconnected the hose where it enters the heater in the cockpit, and now get cool (that's relative, of course) air directed over the cargo shelf and toward the driver when underway. I probably should confess that one of the hoses at the heater want was already disconnected, and I was aware of the problems owners had reinstalling it. So what the heck. I have rarely had the top on this car since I drove it down from Virginia in a January five or six years ago, and the unused side curtains are stashed away in their case awaiting the day when this car might be sold to a buyer in colder climes. Haven't even had occasion to look at them. To date I haven't found any members expressing interest in the heater bypass I created.
R
RestoreThemAll
I did install the screen that I mentioned earlier in this thread. I decided to put the clamp on the outside of the frame so that it would have more area to clamp to. It doesn't look too bad given that it's completely out of sight.
Couldn't you just drill three (3) holes in that bulkhead, and bolt the flange onto the inside, sandwiching the screen in between? It would look far more like it was intended to be assembled that way, and the clamp would be inside (and more protected from the elements, at least direct road-spray) when the time comes to replace the hose...
attachment.php
While not 100% genuine, as hardly anything on my car is, instead or the paper & wire duct, I elected to use Neoprene rubber air duct, figuring it to be more durable and to last longer.
https://www.pegasusautoracing.com/productselection.asp?Product=3620
A bit of the cold-air duct is visible behind the air filter box.
And the other cold air duct on the opposite side.
(heater box resides in the attic of my SW Florida garage__where it does the most good)
R
RestoreThemAll
Hey Randy. Yes, I could drill and mount the flange the way that you describe. I might just do that.
I used a heavy rubber hose for air intake lines. It will outlast the car, and me too. I also pulled the squirrel cage fan apart and changed out the motor with a new AC Delco. With everything sealed up tight I really get some air movement.
T MGA Unknow side screen MG 6
S For Sale Side Screen Anchor Plates Triumph Classifieds 0
CharlesBN1 Side Screen latches[?] Austin Healey 2
D TR2/3/3A Side screen location. Triumph 28
healeyblue Longbridge side screen star shaped nuts Austin Healey 15
K Correct side screen nut for early 58 BN4 Austin Healey 14
K Overdrive Screen Replacement Order Question Austin Healey 4
K For Sale TR3 Side Screen for Sale Triumph Classifieds 0
S For Sale FOR SALE BN1 100-4 Healey Perspex Side Screen windows [California, USA] Austin Healey Classifieds 2
4tecdog Side screen rubber seals Spridgets 0
N Side screen's?? Spridgets 2
waltesefalcon Spitfire Spitfire on the big screen Triumph 0
Tinkerman TR2/3/3A Original wind screen 1960 TR3 A [free to a good home] Triumph 2
C Mk1 3000 screen/windshield fitting Austin Healey 7
T BN4 Hard Top rear screen seal Austin Healey 10
PC on road, on the [small] screen Spotted 0
D TR2/3/3A fitting windshield/frame to 1960 Tr3a & Brooklands screen removal Triumph 2
healeyblue Side screen wing nut Austin Healey 7
andrea BN6 SIDE SCREEN not compatible with the TOP Austin Healey 3
mgedit Side Screen Retaining Bracket Triumph 13
richberman Anyone have Longbridge side screen frames? Austin Healey 2
5 Longbridge screen washer button dimensions Austin Healey 8
tahoe healey BJ8 wind screen top weather strip Austin Healey 19
G Side screen top question Triumph 4
hondo402000 TR6 adjusting windows to Wind screen TR6 Triumph 2
JohnnyMead Another Screen Washer Question Triumph 10
B TR2/3/3A TR3 Windshield-[screen]? Holder on'r thingy remove Triumph 6
G Side screen project anyone? Triumph 3
Tinkerman Win Screen Wiper Motor Done Triumph 0
livinginthepast BE Screen Washer Pump mounting Spridgets 6
martx-5 Side Screen Repair Triumph 9
JPSmit odd screen in Mozilla FORUM Navigation Questions 5
L NOS Racing Screen Triumph 5
G Side screen trip prep? Triumph 10
drooartz Fuel tank screen removal Spridgets 17
longbridgehealey side screen seals Austin Healey 3
L aero screen Triumph 17
PeterK Fuel pump screen & gasket source Triumph 6
G Side screen windshield frame polish? Triumph 6
G Side screen owner input? Triumph 21
G Input from Side Screen owners appreciated! Triumph 6
jmwuva05 BE screen washer tubing? Spridgets 5
T Rear Wind Screen Triumph 11
J Gas pickup screen Triumph 12
B MGB screen material for fresh air vent on mgb? MG 12
A Overdrive drain magnet-above or below screen? Austin Healey 10
jlaird Tony - GarageMahal Screen Doors & Landscaping MG 1
W Front Vent Screen MG 14
PeterK TR2/3/3A TR3A side screen fitting Triumph 5
MGretired Coveland Motorsports Screen saver MG 1
