Aston-Style Gas Caps
Healey Nut
So I have a dilemma. Went to fill up, took off my regular cap, filled up, go to put the cap on and the cap seal is gone ... not on the ground under the car, etc., etc. I suspect it went down the neck and now resides in the bowels of my tank.
So it's upgrade time. I like the look of the Aston caps, but my question is, How does the adaptor collar fit onto the filler tube?
Does it lock onto the existing twist lock tabs?
Will that not make it sit way too high above the body line?
Anybody got pics of their Aston caps on their Healeys and how they fit? :encouragement::encouragement:
gonzo
Denis Welch Motosports U.K website has some good pics of Aston and Monza - Style Filler caps. This is a two-part/piece installation where caps screw on to a brass threaded collar that's brazed or glued to the business end of filler neck. It's a flush fit. However; IMHO the Aston Filler Cap is too large and somewhat detracts from the body lines of the Healey, so I decided on the smaller Monza style. Gonzo
Healey Nut
Healey Nut
So the Monza cap is less bulky but still 2 1/2” . I can handle the brazing/soldering of the collar onto the filler neck no problem but I dont want some big ugly cap stuck up like a big pimple on a skinny guys butt if you get my drift .
dcarlg
I didn't like how the Aston gas cap looked too tall, so got a chrome locking cap instead.
You wanna buy a barely used Aston gas cap?
Or just get a new seal.
Regards. Douglas
Healey Nut
Healey Nut
It seems that the Aston Caps are very bulky and The Monza caps are lower profile sleeker looking .
A quick search on flea bay finds lots of Monza caps and collars at way way less than the usual suspects . And dollars to donuts they will be the same .
John Turney
This is the one I got from Denis Welch. The collar fits around the filler tube. I epoxied mine in place, then drilled and threaded through the collar and tube for a couple of set screws. The cap is threaded on the collar and the set screws are installed from the inside so the cap can't be easily unthreaded. It sits down on the rubber grommet.
Healey Nut
Healey Nut
I have ordered a Monza cap of flea bay from India . It was 40$CAN free shipping . Thats actually less than a direct replacement with shipping from any of the usual suspects .
Will post pics when it arrives so you can see quality .
Healey Nut
Healey Nut
Ok it arrived from India , took just over two weeks so not bad shipping for free .
Quality of part I will give it 7 out of 10 .
Considering it was only 40$ CAN I thinks its ok .
Now the issue . It was listed as a 2 1/2” cap and I took that to be the ID of the collar so it would fit directly over the filler neck tube once the old adapter part was cut off ......Wrong .....the 2 1/2” is the ID of the threaded section that the cap screws onto .
Anyways the actual size of the cap is very similar to the old flat originals so it doesnt look bulky so I think I can make it work by cutting off the old cap adapter off the filler neck and then using a second rubber hose connector under the body ,the new collar will fit inside the rubber and then the rubber will connect to a shortened filler tube to the fuel tank .
On second thoughts Im going to get a piece of 2 1/2” tube from somewhere , exhaust pipe or stainless tube etc and use that instead of cutting my original .
Stay tuned .
HealeyRick
The one I put on my bugeye many years ago attached with a threaded brass collar that went over the filler tube opening after being expanded by heat. You then screwed the new cap onto the collar. Any chance the threaded portion of your adapter might work the same way if you cut off the portion below the threads?
Healey Nut
Healey Nut
Not a hope its 2” bore on the ID of the adapter, fill tube is 2 1/2” OD .
John Turney
If the threaded portion of the adapter is 2 1/2" ID, can you cut off the non-threaded portion and slip the threaded portion over the filler tube and secure?
Healey Nut
Healey Nut
Ok I Will try this again .
The collar (adapter) has a 2” ID ie inside diameter ....all the way through so there aint no way its going to “slip over “ a 2 1/2” pipe .
I did take photos with a tape measure in the pics .
dougie
They do look great when done right....
steveg
Healey Nut - you evidently have the weld-in adapter and need a different adapter to fit your stock filler pipe; your cap is the correct 2.5" size.
The importers of British Aston and Monza caps have a pdf with all the dimensions, including the collars. They also sell the brass ring you can install on the outside of your Healey filler. Download here:
https://mocalusa.com/aston.htm
Healey Nut
Healey Nut
Tks Steve it appears I need COL25 which is brass so easily soldered or silver soldered onto the end if my stock fill pipe .
I have a 16tpi 2 1/2” cap .
HealeyRick
If you get lucky as on my Bugeye, the collar will be a slight interference fit and you can pop it in boiling water for a few minutes to expand it and put it over the filler pipe. Once it cools, soldering will not be necessary
steveg
Wondering if it would be possible to screw the collar into the cap and boil the whole assembly per above. Then when installing you could have the cap oriented as you wanted it, rather than arbitrarily where it screwed onto the installed collar.
Addendum: Duh, of course it would be relatively easy to loosen the hose between the tank and filler and rotate the cap to the desired position. However, the rubber could be petrified and one would have to order another one.
Healey Nut
Healey Nut
So I went to my local auto store and got a 18” length of 2 1/4” exhaust pipe that is swaged at one end ,the original filler pipe fits inside the swaged end snuggly . The collar (aluminum) that came with the cap is slightly loose in the swaged end .
Im going to reduce it with some careful hammer work then epoxy the collar into it .
I will then cut it to length and install it to orient the cap where I want it so it doesn’t hit the body etc when open .
Stay tuned .
If this fails I will get the brass collar that fits exactly etc .
S For Sale Aston Martin DB6 Factory Parts Manual on CD/ROM – 1965 - 1971 Models. Other British Classifieds 0
S For Sale Aston Martin DBS V8 Factory Workshop Manual – 1967 - 1972 Models. Other British Classifieds 0
S For Sale Aston Martin DB6 Factory Workshop Manual on CD/ROM – 1965 - 1971 Models. Other British Classifieds 0
M Aston Martin DB11 on the Autobahn Other British Cars 0
Editor_Reid 2011 Aston Martin V8 Vantage N420 Goes Full Lockdown Other British Cars 54
M For Sale 2006 Aston Martin DB9 - Get in Touch with your Inner James Bond Other British Classifieds 2
M For Sale Aston Martin wheels for Sale - $1600 - Full set in the original boxes Other British Classifieds 1
69MGC Newest Digital Painting Aston Martin Other British Cars 0
69MGC 1959 Aston Martin DBR1 Other British Cars 1
bugedd Aston filler cap Spridgets 8
busybrit Electrical tach issue on Aston Martin DB5 Other British Cars 2
H Aston Martin DB4 converible found in UK awhile back--what was paid for it? Other British Cars 0
catfood Aston Martin V8/DBS Spotted 9
HealeyRick Aston Martin Mini Bugeye Spridgets 11
P Aston Martin Feltham Club FORUM Navigation Questions 0
J Racing Aston-Martin - Barcelone [Spain] Spotted 11
drooartz Aston and Impala Spotted 2
T Type of Wood in the new Aston Martins Other British Cars 0
paulgraham Aston Martin vintage vs. new: thoughts? Other British Cars 13
PAUL161 MGB The MG EX234, The MG ADO21 & The Aston MGB MG 1
KLUTZ Aston Martin to revive Lagonda Other British Cars 0
aeronca65t Winning Aston-LeMans Racing 4
Steve Big News! Aston Martin........ Other British Cars 10
weewillie aston Other British Cars 20
S Aston Martin DB9 Sighting! Other British Cars 8
P '37 Aston Other British Cars 7
Steve James Bond Aston Martin sold! Other British Cars 6
C aston martin racing autographs ! Other British Cars 0
D Aston Martin 1991 Virage???????????? HELP Other British Cars 4
G Mr. Bonds Aston on the block! Other Cars 4
aeronca65t Aston-Martin WIns Sebring! Other British Cars 6
D Aston DBR 1 back in production.... Other British Cars 1
CDK V.B.D. Aston Martin Other British Cars 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
D MGB Older style door pulls MG 0
K TR2/3/3A "Clip on" style side mirror? Triumph 9
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
F For Sale: Minilite Style Knockoff Wheels, 15" x 5.5" Austin Healey Classifieds 2
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
Pythias Bugeye [style] gauges in a Box Sprite? Spridgets 13
S Wanted Original Style Positive Ground Radio Austin Healey Classifieds 0
G For Sale Morgan Folding Windshield Posts, Original 1960s-70s “Small Quadrant” Style, $600 Other British Classifieds 0
L TR2/3/3A helmet style battery terminals Triumph 7
jfarris Wanted Mag style knockoff wheels for TR3 Triumph Classifieds 1
Answerman Restoration of OLD [pre WWII style] leather seats Restoration & Tools 5
C Wanted Wanted - Ford Cortina "bullet" style gearbox Other British Classifieds 1
C For Sale BN1 Lemans style hood Austin Healey Classifieds 0
CJD TR2/3/3A Original Style Coach Key? Triumph 24
BlueMax The F1 Boys Are Riding In Style!!! Spridgets 5
