Results 1 to 8 of 8
Thread: Door check installation
  1. #1
    Darth Vader Michael Oritt's Avatar
    Join Date
    Jun 2001
    Location
    Lusby, MD, USA
    Posts
    2,894
    Thanks Thanks Given
    Thanks Thanks Received
    6
    Thanked in
    I need to replace the driver's side door check.
    Can I do this without having to remove the fender?
    Best--Michael Oritt
    1954 Austin-Healey 100 Lemans
    1958 Elva Courier (FOR SALE)
    1959 Elva MK IV Sports Racer
    1961 Ginetta G4
  2. #2
    Jedi Warrior pan's Avatar
    Join Date
    Nov 2005
    Location
    Ipswich, Australia
    Posts
    607
    Thanks Thanks Given
    2
    Thanked in
    Re: Door check installation
    G'day Michael, I installed mine with the mudguards (wing, fender) already mounted. But the engine was out at the time which I recall made it easier to get my hand into the gap.
    Cheers,
    Alwyn
    Forty nine years in one 100, still going strong!
  3. #3
    Join Date
    Dec 2009
    Location
    brockville ont canada
    Posts
    26
    Thanks Thanks Given
    Thanked in
    get a strong magnet from old speaker ect. place on face of panel use long handle magnet if you cant get your hand in there
    that is how i did mine a fiddly job but saves taking off fender
    good luck
  4. #4
    Luke Skywalker RAC68's Avatar
    Join Date
    May 2010
    Location
    NJ Shore
    Posts
    1,652
    Thanks Thanks Given
    5
    Thanked in
    Hi Michael,
    As I remember (although not confidently), I undid the lower fender bolts and a few of the in-jam screws to allow the bottom of the fender to be separated enough to squeeze my arm up in place. Although my door-checks are in place, I have only had them perform properly for a very short time and found them useless.
    Have a great Holiday,
    Ray(64BJ8P1)
  5. #5
    Join Date
    Jun 2001
    Location
    Lusby, MD, USA
    Posts
    2,894
    Thanks Thanks Given
    6
    Thanked in
    Thanks fellas and I am going to try to avoid dealing with fender connectors if at all possible.
    DH100--I have a now-disused speaker in the left kick panel and not only would its removal give me the strong magnet you suggest but it also may allow me to reach the rear of the jamb to R&R the present check.
    Ray--At this point I will settle for a mere 20 or so years of use from the new check.
    Best--Michael Oritt
    1961 Ginetta G4
  6. #6
    Jedi Warrior roscoe's Avatar
    Join Date
    Jun 2004
    Location
    Esparto, CA
    Posts
    625
    Thanks Thanks Given
    1
    4
    Thanked in
    Posted under the wrong thread, dang!
    Jon Robbins
    1956BN-2 (do it all yourself, you'll be glad you did)
  7. #7
    Join Date
    May 2010
    Location
    NJ Shore
    Posts
    1,652
    Thanks Thanks Given
    5
    Thanked in
    Hi Michael,
    The failure I previously referred to involving the door check was the resistance-pad in the check that kept the door from closing. I changed it a number of times and, if you can tell me how to keep it working for 20 years, I would be grateful.
    Enjoy,
    Ray(64BJ8P1)
  8. #8
    Join Date
    Jun 2001
    Location
    Lusby, MD, USA
    Posts
    2,894
    Thanks Thanks Given
    6
    Thanked in
    Today I installed the new door check I got from Moss.
    After first detaching the old check from the door I was able to open it--the door--far enough that I could get at the two screws attaching the check to the A pillar. In examining the new piece it looked to me that the old one could somehow be manipulated to come out of the hole in the pillar and the new one installed in the same way, but no matter how I turned and twisted the check it would not come out and while manipulating it while holding it with a big hemostat I ultimately wound up dropping it and it fell into the void behind the pillar!
    As I posted yesterday there are some disused speakers in the outer footwell panels and by removing the speaker I was able to reach into the void, extract the old check and then hold the new one in place so I could get the mounting screws in place, and I then attached the arm of the check to the door. All of this took about an hour.
    I must say that I am not at all happy with the new check: Whereas the plate of the old--no doubt original--check had a bead pressed around its perimeter to stiffen it the new one did not and though the plate is firmly attached to the inside of the pillar it flexes a bit when the door is closed. (Perhaps this will go away as the check wears a bit).
    If I had to do this job again I would probably enlarge the hole just a bit to allow the check to pass through it, making its R & R a much easier job. Alternatively, I might install the check on the rear face of the A pillar, as the face of the pillar would serve to keep the check's plate from flexing and once it is painted out it would not be very noticeable.
    Anyway, taking my age into consideration and given how long the old check lasted, even with the new unit's weaker construction I am hopeful I will not have to do this job again.
    Best--Michael Oritt
    1961 Ginetta G4
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
