For Sale Large selection of TR4 - TR6 parts
tdskip
Time to clear parts acquired when I had several Triumph TR4, TR4a and TR6 cars. Here is a partial list;
New rear brake drums
Front brake pads
Spare transmission
TR 4/tr6 IRS OEM rear springs
Rear lens is in very good condition
Rear lighting assemblies in very good condition
Aftermarket battery box
Rear axles, blasted, painted need new grease
Wiring harness
Misc carb rebuild kits
TR3-TR4a wire wheels that have been sand blasted, painted and have unused tires on them (about 3 yrs old)
Brand new j-type Overdrive solenoid
Brand new overdrive steering column switch
Coolant overflow tank
Believed to be good Lucas alternator
OEM black driver side rear view bullet style mirror
Pair '74 model year Stromberg carbs for rebuild
New Moss Motors TR4 seat kit, never installed
Newly recovered TR4-TR4a front seats, Moss Motors kit was used, new foam, black with white piping
Email me what you need.
Can ship via USPS flat rate shipping if need be
Mar-Taaay
I'm looking for a TR4A or TR250 passenger side front fender. Would you have one or know of one?
Thanks in advance for any info. ...
Marty
TuffTR250
Do you have a working early TR4 electric temperature gauge for sale? full view of needle, temp from 110 to 250 F. Thanks!
T
tdskip
Hi Dan - I have one in very good condition. I am away on family vacation until next Friday but can send pictures then.
shoopal
Have one. Picture available
S TR2/3/3A the large Philips headed field screws Triumph 12
K TR2/3/3A Front wheel bearing felt seals too large? Triumph 9
G TR6 Engine Cutout, Black Smoke, Large Backfire Triumph 7
S Large capacity fuel tank Spridgets 1
A Spitfire British Invasion 2018 - Stowe Vermont - Large photo album Triumph 2
Alfred E. Neuman General TR Large cache of TRs and other Brits for sale Triumph 2
T TR2/3/3A Is there a reason for this large pointed piece on front suspension? Triumph 14
S TR2/3/3A Torque specification on large pitman arm nut Triumph 1
steveg BJ8 Alternator - small belt in large pulley Austin Healey 4
A General TR The British Motorcar Festival Bristol RI - 2018 - Large Photo Album Triumph 8
T TR2/3/3A Drive end of speedo inner cable to large for pinion Triumph 2
TRMark TR4/4A Seal too large for Surrey backlight Triumph 8
A General MG One large lot of MGB parts for sale MG 0
A For Sale One large lot of MGB parts for sale MG Classifieds 0
tr3guy TR2/3/3A New Wheel Cylinder too large Triumph 7
Jim_Gruber Bullet Connectors are too large to fit Tail Lamps on BE Spridgets 8
J How to sell a LARGE Compressor?? Restoration & Tools 8
Jim_Gruber What is this for, 3 holes + 1 Large hole on rear License Plate Indent on BE Spridgets 17
S TR2/3/3A torque of the large pulley bolt Triumph 4
S TR2/3/3A large water jacket Triumph 6
2billydavies TR2/3/3A tr3a large manifold clamps: where the heck do they go?? Triumph 5
DNK Got an extra 100 Large? Lotus 3
M Healey 3000 a large of oil fumes fro rocker cover Austin Healey 14
Jim_Gruber It's amazing how large a deer is from 5' away Spridgets 4
S TR2/3/3A large /main dash on 61 tr3 Triumph 0
Simon TR4a Cleaning large assemblies. Triumph 5
Patton Rocker Arm Clearances too Large Symptoms Austin Healey 5
B Wheels and Tires Selection Austin Healey 10
G SU HS6 Carburetors Needle Jets Selection Austin Healey 3
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
C Spitfire gear selection Triumph 10
Hamish Racing General Tech Wheel and tyre selection Triumph 11
Got_All_4 TR6 Cam selection decision time could use your thoughts Triumph 2
RAC68 Alternate Trans/OD Oil Selection Austin Healey 17
D TR6 Soft Top Selection 1976 Triumph TR6 Triumph 5
Lutz Kramer Reverse Gear Selection Austin Healey 2
G TR2/3/3A TR3/TR4 Cylinder Head Gasket SElection Triumph 2
Patrick67BJ8 Monza & Falcon Exhaust Selection Austin Healey 19
Rut 1275 selection Spridgets 3
martx-5 SU carb needle selection program. Triumph 0
H TR6 TR6 HS6 Needle selection Triumph 0
Rut Carb selection Spridgets 8
Nelson SU needle selection Spridgets 2
M Vendor selection Spridgets 4
M Question on oil selection for new master & slave Spridgets 13
bill_powell Fuel Pump Selection Spridgets 48
B Tire Selection / LSD and Axles. Racing 10
bill_powell HIF6/Hif44 Needle Selection Spridgets 2
I Tire selection help for Bugeye Spridgets 12
vping Choke cable selection MG 11
