wanted- 2nd gear for 1275
zimmy
i need a new second gear....
my budget is less than $100..
anyone have an extra gear to
part with or a good resource?.........zimmy
regularman
Depends on how soon you need it. I have a whole transmission I want to sell. All the gears are good in it including a brand new laygear. I removed it to do the 5 speed conversion, but I will hang on to it until I see that everything works out ok
ChrisS
Zimmy,
Give me the numbers off the laygear and second gear. I may have a source for used parts.
Chris
zimmy
zimmy
22G100- layshaft.... 22G1121-2nd gear
is wear on the laygear a big deal?
mine has wear but im still not exactly
sure how it all works, so.....
kim,i already have a new 1st gear, and everything
for the rebuild, bearings, etc.....
i really just need the 2nd gear and possibly
the laygear if u wanna part out your tranny....
ChrisS
No, just wanted to be sure they fit, I had one box with an oddball laygear. Check the layshaft and bearings for wear, usually the laygear breaks teeth before it really wears too much. I'll let you know what I find.
Platinum
Always a good idea to just put in a new layshaft and bearings, Jimmy... it's a PITA to have to do it all again, IYSWIM. If the shaft shows ANY wear, put in a new one. Visual evidence of galling, or the "fingernail" check will tell. Drag a fingernail down the length of the shaft in four equidistant lines (think diameter quadrants)... if you feel a "hitch" ANYPLACE along the shaft it's time to replace it.
zimmy
zimmy
talkin bout the layGEAR Dr...........
the layshaft appears fine and i have new bearings
already.....my laygear has wear between the teeth
but none are broken....this tranny rebuild is starting
to get expensive! ; 0
guess ill REALLY enjoy it if i ever get done though ; )
still cheaper than a new car, and 3 times as cool!
jcatnite
I think I spent about 350 on my tranny rebuild. But I needed some gears as well. That's when it really starts to add up. Otherwise, you can do bearings, seals, and synchros for around $125.
JC
ChrisS
Check that part #, 22G1121 is 3rd, 22G1120 is 2nd. Let me know which you need.
Platinum
zimmy wrote: [ QUOTE ]
[/ QUOTE ]
I know that but didn't want ya to overlook the shaft. A kinda "forest/trees" thing. You covered it.
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
jehuie Wanted HS2 carburetor float chamber cover wanted Spridgets Classified 0
J BT7 Hardtop Crosspiece Wanted Austin Healey 5
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
D Wanted TR6 72 Spoke Wire Wheels (painted) Wanted Triumph Classifieds 0
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M Wanted WANTED: Hardtop (Factory) for BT7 Austin Healey Classifieds 6
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 1
K TR6 TR6 late rims wanted Triumph 0
B Stainless Steel Exhaust System Wanted Austin Healey 5
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
T Wanted Wanted : MGA rear deck cover MG Classifieds 0
T Wanted: Early BN1 Sidescreens Austin Healey 2
M Wanted WANTED...New TR6 piston set. Triumph Classifieds 2
M TR6 WANTED....Nural pistons for TR6 Triumph 1
volunteer Wanted: Brake Master Cyl. Repair Kit for Daimler DS420 Other British Cars 18
M Wanted Wanted: Inoperative J Type OD Solenoid! Triumph Classifieds 2
T TR6 Opinions wanted Triumph 29
S Wanted: AH Concours Registry Guide Austin Healey 2
H Wanted Wanted TR6 Hardtop Triumph Classifieds 3
shadowfever MGB MGB intake wanted MG 2
D Wanted Wanted Triumph Classifieds 0
Joel Lester Wanted Wanted - TR6 steel wheels Triumph Classifieds 6
D Wanted Wanted 80Spitfire hard top and seats Triumph Classifieds 0
M MGA RHD rack and pinion wanted MG 19
T TR2/3/3A Wanted - Picture of TR3A original firewall layout Triumph 5
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
J Wanted Help Wanted -SE WI Other British Classifieds 1
J Help Wanted - SE WI Racing 2
D Wanted: Austin Healey Classifieds 5
D Wanted: Austin Healey Classifieds 0
35 Siddeley MGB MGB Armstrong shock dimensions wanted MG 0
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
T Wanted Wanted - 1956 TR3 Crankshaft Triumph Classifieds 0
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
Obtong WANTED: TR7 (Olympia/Seattle Area) Triumph Classifieds 0
Pythias MKIII Springs WANTED Spridgets 8
J Bugeye seats wanted... Spridgets Classified 0
gbtr6 Wanted: '96 LHD Drivers side master window switch panel. Jaguar Classifieds 0
