Twin Cam Timing Chain Adjustment
RobT
So here's another silly beginner question from a new owner of a TCS Lotus Europa.
I have only had the car a couple of monts so am still finding my way around and de-bugging odds and ends. Well I have noticed that at idle(900rpm or there abouts)there is quite a bit of clatter comming from the engine. Reve it up a bit (say 2,000rpm) and the clatter goes away.
So I conclude it could be a loose timing chain. Now I do the right thing, and read the workshop manual - which indicates there is an adjustable timing chain tensioner (yipee!). The manual goes on to say that the tensioner should be adjusted till any noise is eliminated (yipee #2).
Well I backed -off the lock nut and gave the tension adjustor a couple of turns, and indeed it does seem quieter.
But my question is, is there a more specific technique to adjusting the chain tensioner? How much should I adjust it, and do I risk over-tensioning the chain? And how much exposed thread on the tension adjuster is considered "normal"?
As usual, I am most appreciative of any advice.
Rob.
coldplugs
Platinum
I always just went by feel - tight enough to be quiet but not much more than that, just a little tension. I'm not sure what's considered "normal" - as long as there's enough thread visible to indicate there's some adjustment left I wouldn't worry if there are no symptoms of a loose chain.
Platinum
I'm such a fuss... Remove the cam cover, tension the chain to allow no more than a half inch of deflection between the cam cogs, no less... And look for evidence of "scarring" on the inside top of the cover. If you've not been under there yet you may want to have a cover gasket in-hand. No tellin' if the one on it was glued or not. That would also be a good time to run some feeler gauges between the cams and buckets.
RobT
RobT
Yes - I know. I should really pull the valve cover off and do it properly. Was just hoping there was a "lazy man's" technique for adjusting the tension without going to the trouble of pulling a bunch of (so far leak-free) parts off. But guess I should know better.
Rob.
Platinum
They can be made/kept free of leaks. Attention to detail is the only "secret."
You've not posted engine bay pix... are the "crossover pipes" still in place? They can be shed shelf items with no detriment to the running of the engine. Blanking plates to cover the ports (aluminum & Nylok nuts look good). That way the NEXT time the cover needs removing it's a LOT less messin': eight nuts and away.
RobT
RobT
I'm more used to the TR250 cover which has just two bolts and always leaks (although mine dosen't any more thanks to a silicone gasket!) But the Lotus cover looks a lot stiffer and easier to torque down so as not to leak. Lots of cork and gasket goop to scrape off though!
I don't have the cross-over tubes - the car has extractors in place of the stock exhaust manifold. There are blanking plates on the intake manifold - home made jobs that look real ugly. I do have the "catch tank" still installed though. What the heck is the use of that?
Rob.
Platinum
meh... umm... "esthetics"? /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
The cover is cast alloy so it'll keep its seal well if done right. There are some rubber coated washers under each nut to seal those well, too. The li'l "half-moon" rubber blanks are the "usual suspects" for leaks. The other culprit is a short, squat rubber 'downtube' between head and block... we don't wanna even go there just now, tho. /bcforum/images/%%GRAEMLIN_URL%%/smirk.gif
You can read more on that thing in the thread Curtis started, below.
RobT
RobT
Thanks Doc.
Read the Curtis thread - and indeed hope I don't have to go there!
Rob.
Platinum
"YEAH, but it's a SLOW leak." /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
Platinum
Yup. You're correct!
What's my percentage? :jester:
A real "quick-n-dirty" way to ascertain rotation direction is to see where the chain tensioner is located. The side it's on will be the "slack" side of the chain. :wink:
RobT
RobT
Well since I started this thread - thought it time for an update.
I pulled the cam cover, and tensioned the chain per the book, also checked the valve clearances - all good.
Also reinstalled a mechanical fuel pump, had the carbs and dizzy rebuilt, brakes rebuilt, all new lines, rear end rebuilt with AVO shocks, starter motor rebuilt, etc, etc, etc.
Now the car goes like a bomb!
I did have oil leaking from the down-tube between the head and the block. Through ignorance (and there not being anything in the book about it), I just pulled the tube out (its pretty easy to get to on the Europa) put HT RTV silicone around the top and base, and reinstalled. Seems good.
There is still some oil leaking - looks like its going up the dizzy shaft and out the weep hole. Would this indicate a bad seal, or just too much crankcase pressure. Wondering if a PCV valve/hook-up would cure this (and any other) leaks.
Rob.
Platinum
You should have a tube at the rear of the head which goes into the air filter box to create a slight "draw" on the crankcase. The seals for it may be allowing less than optimum vacuum? As for the dizzy, it should have an O-ring seal, maybe a smaller (ill-fitting) one was fitted when it was redone?
Both are WAG's at what you describe, but it's a starting point.
I'm impressed you could get that drain tube back in place and sealed. Must be a relatively new one. They usually go to pieces when wrestled out of there. :thumbsup:
RobT
RobT
Yes, the dizzy has an o-ring in the recessed groove on the shaft where it goes into the block - actually I added a second at the top of the shaft just below the clamp to add some extra "sealing power". But the leak seems to be from inside the dizzy - I think the oil is finding its way up inside the body of the distributor.
Also the tube from the head to the air box is installed and seems fine. Was thinking this may not give enough -ve pressure to the crank case though. Hence the PCV idea.
I guess I was lucky with the drain tube! But rather be lucky than smart any day :yesnod:
M MGA RHD twin cam steering pinion MG 0
B Anyone have a Europa Twin Cam for sale? Lotus 6
B Twin OH Cam for the BIG Healeys Austin Healey 15
M MGA MGA Deluxe / Twin Cam brakes MG 2
David Townsend MGA Rocket Ralphie's Twin Cam MG 4
glemon MGA Twin Cam MG 4
David Townsend MGA MGA Twin Cam Illustration MG 0
T Twin Cam Healey Austin Healey 20
Brinkerhoff MGA MGA Twin Cam handbrake parts MG 3
P MGA Where is my Twin-Cam? MG 15
P MGA MGA Twin Cam owners manual. MG 1
aeronca65t MGA MGA Deluxe/Twin Cam? MG 9
Marvin Gruber MGA Pulled the trigger. Bought a MGA Twin Cam MG 12
Marvin Gruber MGA MGA Twin Cam MG 11
PAUL161 MGA STOLEN MGA TWIN CAM!!! MG 0
glemon MGA MGA Twin Cam MG 5
eschneider Twin cam crankcase pressure low, VC pressure high Lotus 21
S MGA 1959 MGA Twin Cam on eBay...?? MG 17
glemon Is this a Twin Cam MG 8
B MGA Pic .of my old MGA twin cam MG 10
GeeBee1 Twin Cam - not much time left MG 34
aeronca65t "Real" Escort Twin Cam Other British Cars 18
C Europa Twin Cam Autocross Car Lotus 3
poolboy Twin Cam MG 3
S 59 MG A Twin-cam MG 8
curtis Twin Cam engine question Lotus 41
aeronca65t Escort Twin-Cam Racing 7
curtis Escort Twin Cam Rev Counter Other British Cars 13
curtis Escort Twin Cam Lotus 25
beaulieu MGA MGA twin cam head on non twin cam motor ? MG 9
jackq Twin Cam MG 5
Simon TR4a MGB MGB Twin cam? MG 3
Sherlock MGA Help locate an MGA Twin Cam MG 1
D HRG twin cam Other British Cars 13
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
G Twin HS4 Su's leaking fuel Spridgets 18
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
AH67 For Sale CARBURETOR REBUILD KIT, genuine SU, twin HD6 Austin Healey Classifieds 0
T For Sale Group 44 Replica TR7 V8 Twin Turbo Project - $25,000 Triumph Classifieds 0
D Experience with Mallory twin point distributor. Austin Healey 5
johnrip Wedge TR7 fuel in carbon canister-twin carb model Triumph 10
Foura TR4/4A TR4A Exhaust - Twin or single? Triumph 8
vette Twin Reservoirs Austin Healey 2
S TR6 twin dgvs on a tr6 Triumph 26
theleisure twin-engined-4x4-1966-twini-cooper-s British Motor Corp 1
T Twin barn finds-one is a Jag. Jaguar 3
S Ford Crossflow on twin 40s. Help needed! Other British Cars 3
G Wedge TR7 with twin webers Triumph 1
