I am redoing a 1955 TR3 and one of the things that is not ligning up is the hand crank.
It will fit but not if I use the guide that is in behind the grille.
I removed the guide and the hand crank goes in but does not sit square in one of the grille openings but rather to one side.
I can do some metal cutting and reposition the guide. Solves the problem but then it will not sit in the center in the grille opening.
Anybody run in to this before?
Thanks
Dorien
Thanks
Dorien
