the wonders of tinkering - and youtube
JPSmit
Got up this morning and the microwave was dead - no power no lights, no nothing. Spent five minutes on Youtube - diagnosed a burnt out fuse, $2.00 later and all is well with the world.
I really appreciate that for the sake of a couple of bucks there is a little less landfill and I REALLY appreciate people taking the time to post their experiences and other lessons on Youtube!
Administrator
Boss
When the LCD display on my Epson ink jet printed went dark, I thought I was going to have to send it to never never land. But I did some searching on the net and ran across a description on some blog of how to fix this exact issue (which was apparently common). It involved taking the display apart and putting a tiny dab of solder across a tiny fuse link (non replaceable). Basically I shorted the fuse-link which had burned out, but it worked and the printer provided several more years of service until I finally gave it away to charity. Wasn't Youtube, but someone went to a lot of trouble to write up detailed instructions for how to take the display apart and locate the blown fuse link and effect a repair that worked.
JPSmit
JPSmit
I may have spoken too soon - fuse blew again, seems the enxt step is a new capacitor or the interlock switch.
AngliaGT
Flux Capacitor? - if so,send it back.
GregW
The old penny in the fuse box trick.
Popeye
Bronze
Did that once to fix a car radio while on a road trip. 100 miles from home the electrics quit - first the alternator, then the battery was flat... Caveat emptor!
Deleted member 8987
I usually do all my own stuff. However, one time we bought extended warranty on the new refrigerator (current).
Door switch for lights went bad. Obvious. Flick the switch and they come on, but not when you just open the door.
Called it in, they sent the switch, service showed up this morning....the "bill" claims $296 to fix it....took 2 minutes and a putty knife.
Had them order another switch under warranty (dies this summer anyway) so I'll have a spare.
Platinum
Yup. Down here in the Lightning Capitol of the World, many a fuseable link got "repaired" with a soldered in link. Replaced magnatrons in microwave ovens and went on for years. Can't see discarding a tool or appliance unless it is more expensive for the parts than a replacement unit. Have repaired washing machine pump bodies with fiberglass, cracked toilet tank with Epoxo-88, pesky ridge vent self-tapping screw, rain dripping RIGHT ON MY HEAD as I typed on the garage computer, using Rustoleum "rubberized" aerosol spray... long list of bodges. MacGyver's got nuttin' on us LBC owners! "Adapt. Innovate. Overcome!"
JPSmit
JPSmit
oops maybe got a bit carried away - BTW current state of play is one of the microswitches in the door which apparently will blow the fuse if the door doesn't close properly.
JPSmit
JPSmit
well so far no good - OTOH the microswitch I thought it was - was only $3.00 at the electronic supply store (instead of the $20 the appliance repair store wanted)
onward...
Administrator
Boss
You are lucky to have an electronic supply store. Our Radio Shack closed a couple of years ago.
David
We have 2 Radio Shacks in Albuquerque. I stop by from time to time when in need of some small electronic bits, solder, etc.
JPSmit
JPSmit
David
I know!
this is my main go to
https://secure.sayal.com/zinc/index.asp but, there at least three other stores literally in the same strip plaza - each slightly specialized - one stereo/ one TV etc. - just found one closer - not self serve and honestly, imagine an electronics version of the junkyard Anniken Skywalker worked at - I was there this week and there was a '30's radio on the counter with a pile of '70's test equipment - all next to all the "modern" stuff. hysterical.
Platinum
These are my "go-to" guys: ADI
