Hi,
Personally, I like to use a little dielectric grease on many types of electrical connections, to help prevent future problems. Most auto parts stores sell little packets of "spark plug boot" grease, which will work. I've also found "light bulb" grease in small tubes at hardware stores. Yes, I use it on light fixtures around the house, too. Wherever it's used, you don't need much. Just a light coating.
What really brought me around to using dielectric grease was working on cameras, many of which have ultra low voltage, battery powered circuits. In addition, many rely upon alkaline batteries which can be very corrosive. The grease really helps protect the contacts and insure consistent power flow.
Often contacts in these and all sorts of applications were originally coated with some sort of anti-corrosive - perhaps zinc plating, chrome or some other coating - that helps maintain good electrical contact. Over time, as corrosion builds up and is cleaned off repeatedly, the protective coatings are removed. The bare brass or steel underneath is much faster to corrode. This won't happen nearly as quickly if a light coating of dielectric grease is used.
Dielectric grease works well on all levels of voltage: cameras running at 3V and less, automotive 12V circuits, household 110V and 220V (ever have a light bulb frozen in a socket?), even high voltage 40,000V (and up) automotive high energy ignition circuits. In broad terms, the higher the voltage the more likely corrosion is between contacts in the circuit. On the other hand, really low voltage and delicate circuits are more easily effected by almost invisible amounts of corrosion.
So, IMHO, dielectric grease is worth a try and will also help keep spark plug boots from adhering to the plugs, helps seal out moisture that can really accelerate corrosion with many types of connections and will delay electrical connections from "welding" themselves together.
