Rebound Strap - What is its' purpose?
G
Hi - I have restored many 1950s & 1960s Fords and helped a friend restore 55 thru 57 Chevies and I have never seen any rebound straps on a rear axle. What is the purpose of the rebound strap? I have just replaced the rear leaf spring shackles, shackle rubber bushings, & leaf spring rubber seating pads. I saw the rebound straps and wondered why MG installed them on the Midget. I would be interested to learn what they are designed to do. Thanks.
GB1
When you jack the car up it holds the axle up.
Patrick
tony barnhill
Great Pumpkin - R.I.P
Also keeps the rear end from springing too far down during movement/at speed.
BWillis
Its nothing mystical. The main purpose as Tony tated is to limit the travel of the rear end during extreme travel without impacting or modifying the suspension geometry. Its a simple cheap alternative to a torsion bar configuration.
HTH
JerryB
I'll throw out my thoughts here and hazard a guess that with the lever shocks there could be shock damage in severe droop(rear end raising) so as to damage the casting or the shock link. I have noticed with the lever shocks at full travel (bump or droop), that there is a binding and a knot caused by no stops in the shock internally.
Idea "B" might be that the Managing Director at the factory had a relative that owned the Birmingham Strap Company.
PeterC
Idea "C" is that the propshaft in the tunnel can hit the bottom of the tunnel without a restraint. Ever see that dent?
But, I do like "B"
Peter
D) keeps your rear axle attached when all the springs break..
mark
Baz
[ QUOTE ]
[/ QUOTE ]
Every time I look underneath, wished I had a strap....
Rhodyspit75 Rebound strap Spridgets 5
R Bugeye rebound strap bolt broke Spridgets 2
boxfullofyertoys Rebound strap/rear axle problem Spridgets 5
R rebound strap mounting bolt sheared off by me! MG 2
G Rebound strap stud MG 3
K For Sale TR3 rear rebound brackets Triumph Classifieds 0
D TR4/4A rebound stop clearance issue Triumph 13
G Wanted Packing pieces on rebound rubber engine mount Austin Healey Classifieds 0
G Packing pieces on rebound rubber engine mount Austin Healey 5
TulsaFred Rebound Straps Spridgets 10
K TR2/3/3A Leaf Spring "rebound clip" thickness .... Triumph 16
Boggsy64 MGB Rear Rebound straps and shocks MG 5
J Rear axle rebound buffers Austin Healey 9
X Rebound Straps MG 0
Jim_Gruber Spring Rebound Buffers- Big Rubber Things Spridgets 5
D Rebound straps and electronic ignition MG 2
N Rear axle rebound buffer Austin Healey 7
PeterK TR4/4A TR3-TR4 rebound bracket part needed Triumph 2
martx-5 TR2/3/3A TR3 Rebound Rubber & Bracket Triumph 5
A Rebound Buffer Set MG 6
J Rear Suspension - Rebound Straps Spridgets 27
B Rebound Straps for CBB MG 9
Rob Glasgow Check Strap Assembly Austin Healey 5
K TR2/3/3A The engine ground strap? Triumph 6
F TR2/3/3A Check strap alignment Triumph 11
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
B TR4/4A Engine ground strap Triumph 5
R TR2/3/3A Pic of installation of ground strap-TR-2 Triumph 2
S Securing the jack with strap in BJ8 boot Austin Healey 11
HealeyRick Leather Strap Chafing Austin Healey 12
S Door Check Strap Austin Healey 5
M TR6 Tonneau cover strap lift-the-dot stud location Triumph 8
S TR4/4A Horn ground strap Triumph 6
catfood Engine earthing strap Austin Healey 3
D TR4/4A Ground strap, ammeter Triumph 3
Rut Bugeye original hood storage strap Spridgets 23
MGTF1250Dave T-Series TD/TF Engine Ground Strap MG 4
Gerald_Gordon TR4/4A Failure of new door-check strap on an early 1961 TR4 Triumph 6
S TR2/3/3A ground strap on a tr3 Triumph 21
B Leather Bonnet Strap Austin Healey 5
MikeAH100M Treatment for Leather Bonnet Strap - 100M Austin Healey 9
sundown TR6 Door check strap Triumph 3
T TR2/3/3A TR3 top/bows fitment and added strap Triumph 2
I TR6 Washer bottle strap Triumph 20
B BJ8 Ground strap Austin Healey 3
F Proper location of chrome loop for spare tire strap? Austin Healey 2
bugedd Ground Strap Spridgets 2
P Engine ground strap Austin Healey 2
RJS Steering Column Ground Strap Triumph 3
M Earth strap Austin Healey 3
