dklawson
Let's start by saying I made a serious mistake and now I'm looking for things to check.
I needed to get the the front pulley off our 1500. We couldn't break it loose with the car in gear and holding the brakes. So... I pulled the plug for #4 put a foot of rope in the bore and brought the piston up to TDC on the firing stroke (valves closed). We put a huge breaker bar and socket on the pulley with a cheater bar. Still nothing. Then my son and I pulled on the breaker bar together. Still no luck. We stopped when I saw nothing was loosening but the 3/4" breaker was bending. I was concerned I had damaged something when the rope came out with cuts.
To confirm my fears we did a leak down test. First we tested #1 as a control. It was acceptable. Moving the tester to #4 we couldn't get any reading on the gauge and air was pouring into/out of the block. There was no audible leak in the cooling jacket, intake, or exhaust. Yetch.
Tonight we took the head off and I was expecting to see a rope-knot sized hole in the top of the piston. We found nothing. No holes or cracks in the piston, no broken head studs, nothing. My plan at this point is to take the head to the machine shop and have it tested for cracks, leaks, and flatness. If it is OK I may have the seats recut anyway for a future application. Once I know the head is good I am planning on temporarily fitting it to the block with an o-ring at the top of the bore for #4 and repeat the leak down test as all I can figure is that somehow I lifted the head enough to unseat the gasket sealing ring for #4.
If you can think of other things for me to check or test please let me know. I don't want to pull the engine and tear it down if I don't have to.
Thanks in advance for your suggestions.
