Mini Hub Failure
aeronca65t
I was two cars behind Tom Chisholm in his Mini-Cooper at the Pittsburgh Vintage last Saturday when his hub failed. The car in front of me is an MGA and the car closest to Tom is an Elva Courier. Interestingly, another driver (Jim A.) had left his Mini home this year because he was having doubts about one of his front hubs. Anyway, here's the video:
dklawson
There is a thread at Mini Mania which I presume concerns the same car. From the photos posted there it apears that the right front hub came apart with the CV joint nut coming off and releasing the bearing. Again, if it's the same car, the body is distorted and the team is looking for a shell to replace it.
EDIT: New photos at Mini Mania (7/24/13) show the car to be #8 and the right front hub definitely came apart. The photographer went on to say that the driver credits the cage for protecting him. The shell is definitely twisted beyond use.
aeronca65t
aeronca65t
Yep......and I think the cage was an FIA aluminum cage (the car is an ex-rally car). Anyway, one of the other Mini drivers (Mack M.) made this comment on our VRG e-mail list and others seemed to agree, including the owner (Tom C.)-----------> Both Mini front hubs (really part of the outboard CV joint) have right hand threads onto which the "big nut" is threaded (see diagram at link Ian posted). Rotational forces on the RF tend to tighten that nut. But on the LF tend to loosen it. That nut goes on with 150 lbs.ft of torque but if the spacer in the tapered bearing assembly gets pounded down the whole assembly can loosen. I have also had the conical washer (aka tapered collar) break into several pieces. There are hardened versions of both the conical washer and the bearing spacer (EN40B material) available because of these issues. I have switched to both. I torque mine to 150 lbs/ft and just a little more with the cotter pin biased in the castellated big nut such that I know, by visual check, if that big nut has backed off by even less than a mm. I check that after EVERY session. I have seen that cotter pin partially sheared by the big nut beginning to back off. It is always on the LF.
I would suggest that Tom's bearing assembly loosened, the LF big nut started backing off and sheared through the cotter pin. After that it was just a matter of time before nut spun off and the LF drive flange and attached wheel came off. The failure in the brake rotor was secondary as the disc portion was held in the caliper. This is the common area for these rotors to fail, and I suppose it is possible that the rotor failed under braking and that preceded the events mentioned above.
The important thing is that Tom is OK. As many have remarked...it could have been much worse.
Mack
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
C For Sale Rover Mini Blue Star Tribute Other British Classifieds 0
TomMull For Sale 10 inch Mini Rims (2) Other British Classifieds 1
Basil Mini Pick Up Spotted 8
BobHaskell Mini Cooper rear subframe replacement British Motor Corp 3
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
pbraun Alex Moulton's special Mini Moke for sale Other British Cars 0
C Autocrossing a classic Mini problems Other British Cars 2
Sherlock Mini Cooper patina Spotted 0
Basil The Queen in a Mini! Spotted 3
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
GB1 Classic Mini Mayfair Auto Other British Cars 1
Baz 2012 Mini CEL - Now it begins........ British Motor Corp 0
J 2006 Mini Cooper S British Motor Corp 6
N Classic Mini Engine Identification British Motor Corp 6
P Classic Mini advise British Motor Corp 1
D Possible Mini Gauges? British Motor Corp 6
S For Sale Austin and Morris MINI Factory Workshop Manual on CD/ROM - All Models 1959 - 1967 Other British Classifieds 0
HighAltitudeTR3 TR2/3/3A Mini Pulses at Idle Triumph 6
tr6nitjulius Mini @CCBCC All British Meet 7/14/19 British Motor Corp 0
JPSmit Green Mini - with halo headlights Spotted 0
Alfred E. Neuman Austin Mini Breadvan Spotted 0
AngliaGT Real Mini Spotted 0
S TR2/3/3A Tr3/Mini Girl Triumph 0
T Will Mini Spin on Adaptor work on Bug Eye? Spridgets 10
Bob Claffie Ultimate Mini British Motor Corp 3
coldplugs Jensen Interceptor & a Mini Spotted 8
pbraun Mini Meet East 2017 British Motor Corp 4
bcliff For Sale 1972 Austin Mini for sale Other British Classifieds 0
Basil Mini? Spotted 5
hutten Wheel sizes for Rover Mini Mark VII British Motor Corp 1
JPSmit Mini + iphone question Other Cars 3
Chuck9482912 Mini Spare Tire Austin Healey 9
B Mini Windscreen Wiper Parking British Motor Corp 3
3798j AACA Museum's Micro & Mini Exhibit Other Cars 1
J Motorcycle oil for Mini, based on shared oil British Motor Corp 4
DrEntropy Mini brake conundrum British Motor Corp 12
Boink 1973 Marcos MINI Spotted 1
bugedd Mini Metro Turbo setup Spridgets 12
6 Mini in Groveport Spotted 0
Steve Mini photos... British Motor Corp 6
H 1961 Mini MKI speedometer Housing pod & dashboard British Motor Corp 0
H 1958-1961 Austin Mini 850 speedometer housing pod British Motor Corp 3
J Funny noise in my mini British Motor Corp 12
Steve A Mini that is not what they are saying it is British Motor Corp 18
Mickey Richaud Mini Midas? British Motor Corp 1
Mickey Richaud Mini Midas? Other British Cars 4
R Tyres for Mini Cooper British Motor Corp 7
J Seaching for former owner of my Mini British Motor Corp 0
Boink Split Mini British Motor Corp 0
