MGC up-date
(warning - cross-post)
After some coaching on how to wire the starter and solenoid got her starter to spin her over.
Compression results;
#6 – 90-100 +/- (but battery was almost dead)
#5 – 130 +/- (so-so battery, not really spinning it)
#4 – 105 (but battery was almost dead)
#3 – 145 ( freshest charge of the battery)
#2 – 120 (so-so battery)
#1 – 120 (so-so battery)
I'm not going to put too much weight into the numbers since the throttle wasn't wide open, the carb pistons are stuck closed, and the battery wasn't fully charged.
Good news is that there wasn't any knocking or rattling or other expensive sounding noises.
Hard to tell on oil pressure but but I definenatly have some. Better than none, right! Turns out the MGC has an electrical oil gauge and since the rest of the electrical sytem isn't working I don't know what sort of pressure. Oil is definatley flowing pretty well however, since when I pulled the filter as a sanity after the last round of compression checks there was enough oil in the housing to spill all over the driverway.
