T-Series MGA pressure plate verses MGTF pressure plate?
PAUL161
When installing High Gears T9 5 speed I installed a different pressure plate, which I think is from an MGA. Does the MGA pressure plate have stronger springs? Is it the same configuration as a XPEG plate? Everything is new including the throwout bearing. The pedal pressure is stronger than the original that I replaced. If the engine is idling pushing on the clutch the rpms will drop 150 rpms. The pedal and linkage is adjusted properly but I have to push the pedal further down to get it to compleatly disengage. The original was very easy and smooth, the replacement is hard! I'm thinking of pulling the new one out and putting the original back in! :unsure: PJ
Doc??
NutmegCT
Paul - while waiting for an expert opinion, you might be discovering that the "old" springs had lost some tension over the years, and could compress with less pressure than a new set of springs. So the new hardware takes more effort compared to the old hardware.
Just a thought.
Tom M.
PAUL161
PAUL161
Just a thought.
Tom M.
Yes I considered that Tom, thanks. Found out that the MGA uses a hydraulic system same as the MGB which might make a manuel system harder to push if the pressure plate for the hydraulic system has stronger springs, hopefully someone who has been down this road will chime in. :rolleyes2:
PAUL161
PAUL161
Well I might have found the problem! MGTF pressure plate is supposed to have 150/160 spring pressure, the MGA pressure plate has 165/175 lb spring pressure, which the MGA has a hydraulic clutch to compensate. That being the case, I have the wrong p plate on my flywheel! :rolleyes2:
Just because a part looks the same and fits perfectally, dosen't mean it's correct! I wonder how many other times this mistake was made over the years.
PAUL161
PAUL161
Problem solved! I replaced the MGA pressure plate with the original and new retainer springs. My original plate was/is in fine condition but I though I would go with a newer pressure plate. Found that there two differences, the MGA plate has stronger springs and the face where the throw-out bearing rides on, stands more proud and forces the throw-out bearing back further in the bell housing causing the forks not to be centered vertically and creating an uneven throw against the bearing. Or something like that! :rolleyes2: :thumbsup2:
Platinum
Profuse apologies for not seeing this before now, Paul! :oops:
We would only replace a T-Series P-Plate with the specified-for-application one. Never went the five-speed conversion route, either. Grantura would likely have had better insight/experience with the T-Series.
PAUL161
PAUL161
Everything is cool now Doc, just waiting for some hardware to rebuild the center floorboard angles. Threads striped on a couple square nuts which I'll re-weld new ones in place and chase a couple buggered threads the rest. Have nuts coming and 3 BSF taps.
B MGA MGA vs MGB Pressure Plate MG 6
O MGA MGA Oil Pressure MG 4
Editor_Reid General MG GT-49, national annual meeting of the North American MGA Register MG 0
C For Sale MGA MG Classifieds 0
Editor_Reid MGA Seeking Items for MGA 1600 Mark II Tool Kit MG 0
TomMull MGA Rumble seat MGA MG 3
P For Sale MGA factory hardtop for sale. MG Classifieds 0
T MGA MGA MG 6
J Wanted MGA Coupe rear window glass center section MG Classifieds 0
M MGA MGA Engine Rattle MG 10
DocDup1 MGA Wire Wheel Hubs For MGA MG 6
T Wanted Wanted : MGA rear deck cover MG Classifieds 0
M MGA RHD MGA dash finisher MG 0
BritFullHouse For Sale 56 MGA engine parts for free!! MG Classifieds 2
R MGA MGA Headrest fairing for R/H side MG 0
D MGA with T9 gearbox on a tow dolly MG 9
C MGA MGA Thoughts MG 20
C For Sale MGA wiring harness MG Classifieds 3
S For Sale MGA Factory Workshop Manuals on CD/ROM - All Models 1955 - 1962 MG Classifieds 0
Rut MGA MGA in Tuscaloosa, AL MG 3
P mga mint decklid 55to 63 MG Classifieds 1
K MGA 1960 MGA Vin MG 3
B MGA Mystery MGA chassis part MG 3
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
HealeyRick MGA Interesting MGA Fastback MG 9
H MGA MGA engine weight? MG 3
D MGA MGA turn signals MG 3
doc50 MGA Decipher MGA engine Code MG 4
doc50 Nash Metro w/MGA 1500 discrepancy... Other British Cars 2
Alfred E. Neuman Red MGA MkII Spotted 1
JPSmit MGA - on a journey Spotted 9
A MGA MGA valance fastener MG 2
3798j MGA Coupe Spotted 1
glemon MGA MGA extravaganza MG 4
AngliaGT MGA Coupe Spotted 1
DrEntropy For Sale MGA carbs: AUC 784 MG Classifieds 0
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
oxford Healey vs MGA Austin Healey 31
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
NutmegCT MGA MGA front grilles MG 4
NutmegCT MGA MGA opinions? MG 23
AngliaGT MGA Anyone Looking for an MGA Project? MG 8
Alfred E. Neuman MGA Question for the MGA coupe owners - will I fit? MG 8
S MGA 1956 MGA negative ground, True Spark Ignition distributor MG 3
S MGA 56 - early mga 1500drum brake car MG 5
S MGA MGA Wiring diagram MG 1
R MGA Experience buying an MGA from a US Vendor - Vendor Review forum? MG 8
RickB MGA Looks like a nice MGA grille, $50 on Seattle Craigslist MG 1
S MGA mga top and side curtains MG 4
M MGA MGA Swivel Pin Replacement MG 7
