Healey Distributor Removal/Replacement
RDKeysor
Bronze
Having just replaced the plugs on my '60 BN7, I managed to swap a wire (well, actually two wires) during the replacement. I quickly found a picture of the distributor wire positions in one of my Healey book, and while it wasn't very helpful, I did detect that at least one of the wires leading to the distributor was not as found on my car. Ultimately I found AUSMHLY's excellent photo (10/31/12) of the correct distributor/wire/plug orientation. Mine is completely different, which tells me that my distributor is 180 degrees out. Is it worthwhile correcting this fault? I'm loathe to pull the distributor and could use some detailed instructions on how to do this correctly. I understand I may need to verify the timing once this is done. Thanks, and double thanks for the definitive photo mentioned earlier.
Keoke
Using the factory manual:
Get Section B:
Read and Follow Fig B4 & B5
If dizzy will not seat maybe driving dog has been replaced 180 Degrees out. ?
Option:
If car is running good label wires and mark dizzy location on the locking plate And let it alone.
steveg
I would argue for rotating the drive dog on the distributor. At TDC on the #1 cylinder, the rotor should point in the general direction of the #1 cylinder - the 2-o'clock position. If the rotor is in the 8 or 7-o'clock position it is 180 degrees out. If you have a punch of the correct size it's pretty easy to drift the pin out and rotate the dog to the correct position. From the pix below you can see the pin was inserted from one direction and pushed out from the opposite direction.
This is the side that was hammered in:
This is the side to push the pin out:
My backup distributor has a roll pin which can go in or out from either side:
steveg
Pulling the distributor is straightforward: undo the bolts on either side of the base plate and lift out. On reinstall, you'll jiggle the rotor from side to side until the off-center slot in the dog seats. Then push the distributor home and insert the bolts on either side. It helps to have an easy way to disconnect the primary wire. You can undo the cap and tie out of the way to the carbs with a piece of string.
R
RDKeysor
Bronze
Thanks for all of the help. Given that I had just completed installation of Putzke's Bilstein shock system and wanting to drive the car, I took the easy route and swapped crosses plug wires to restore the ignition system for now. I did make a sketch of the functional wire locations for my 180-degree out distributor installation, putting a copies in the car manual, shop manual and my onboard maintenance record. I will probably correct this sometime in the future, and I will make use of Keoke's suggestion to use the shop manual's perfectly good discussion of removing and replacing the distributor. My one tip on the Putzke installation instructions is to completely remove each the front shocks to reach the valves that must be removed and to make it easier refill them afterward. Simply unbolting the four bolts at the shock base as directed doesn't cut it. I found it easier and likely necessary to detach the upper A-arm or control arm connection to get the valves out.
ozhealey
Member
Steve, RDKeysor,
I could well be wrong here, however I am not sure there is a need to remove and "rotate" the drive dog on the distributor. Indeed I am not sure this will do anything to help. To my knowledge the BN7 distributor drive is the same as the BJ7 (my car). The dog on the end of the distributor which also drives the mechanical tachometer has the slot in the centre (not offset) and therefore rotating 180 degrees wont do anything. What I do think Steve was getting at is the drive beneath the distributor which mates with the gear on the camshaft has an offset slot and this could be 180 degrees out. This dog then drive the intermediate shaft in between the distributor and the cam drive. I think simply removing and rotating this cam driven dog 180 degrees should achieve the desired result of distributor alignment.
Cheers
Tony
steveg
Steve, RDKeysor,
Cheers
Tony
Tony - you're correct. I just went through this yesterday. Rather than driving out the pin on the upper dog, it's easier to undo the lower drive where it attaches to the block, then rotate the dog 180 degrees there - as that one's symmetrical. You can do this with the upper portion attached. You want the distributor rotor to be pointing in the general direction of cylinder #1.
The lower slot inside the block should be at the "twenty-to-two" position with the engine at TDC on #1 cylinder.
Lin Jaguar Distributor Cap for Healey Austin Healey 8
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
R Healey Distributor Cap, Phase 2 Austin Healey 2
R Healey 3000 Distributor Cap Austin Healey 20
P Healey BN2 Distributor Question Austin Healey 1
Martinld123 Austin Healey BN2 oil leak at base of distributor Austin Healey 7
busybrit Healey 3000 distributor drive gear spacer washer, end float! Austin Healey 2
P Distributor and coil BMW in my Austin Healey BJ8 Austin Healey 10
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
S Healey Will Not Start (a.k.a. "Failure to proceed") Austin Healey 3
dougie Jack & Bill Rawles attending The Healey World Challenge Road America September 13-15 Austin Healey 2
Editor_Reid New Edition of "Austin-Healey Quarterly" Available Austin Healey 1
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
dougie Healey Hardtop on BAT Austin Healey 8
dougie Austin Healey 4000 Austin Healey 3
Patrick67BJ8 Healey Mechanic Needed - El Paso, Texas Area Austin Healey 0
T Healey In An Ice Cube Austin Healey 6
dougie VSCDA Healey World Challenge Road America Austin Healey 0
dougie Healey World Challenge 2024 Road America Racing 0
R Healey 100 Dipstick Stuck Austin Healey 12
L For Sale Austin Healey Parts!!! Austin Healey Classifieds 0
tahoe healey Healey Video Austin Healey 0
W Nash Healey Austin Healey 5
dougie Celebration of Austin Healey Double Event September 2024 Austin Healey 2
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
nevets Letting the Healey go... Austin Healey 4
dougie Healey Racing Road America Fall 2024 Austin Healey 1
R Big Healey 100 Head Austin Healey 4
PAUL161 Photo: What Model of Healey? Austin Healey 7
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
Guido36 Webers on a Healey 100 Austin Healey 6
E For Sale Driver quality 1963 Healey 3000 mark 2 Austin Healey Classifieds 1
Editor_Reid Summer Edition of "Austin-Healey Quarterly" Austin Healey 4
dougie Healey Racing Austin Healey 13
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
red57 Alternative Healey Austin Healey 2
Dandare Healey Website Links Austin Healey 4
John Turney An Important Healey Up For Sale Austin Healey 1
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
V Opinions on 1953 Austin-Healey Austin Healey 26
dougie Did Big Healey Drivers Go Soft? Austin Healey 8
C What to do with my late father's Healey 100 Austin Healey 5
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
B Healey Won't Start - No Spark Austin Healey 38
Editor_Reid "Austin-Healey Quarterly" e-zine Spridgets 2
Editor_Reid "Austin-Healey Quarterly" e-zine Austin Healey 8
BoyRacer Silver Healey - Chassis Color? Austin Healey 17
HealeyRick Perfect Healey Floor Jack Austin Healey 14
