Fixing the Hood of my BN6
BN6_2197
Has anybody of you thought about a third/centered fixing point or hook of the hood of a BN6? When driving in the rain, water enters my car in the middle of the front screen since the hood is not tight at the frame there. Thus I am thinking about a mechanism in the middle of the front screento tighten the hood. Any ideas?
Volker
John Turney
The aluminum trim piece on the front of the hood is suppose to hook over the lip at the top of the windshield frame. With that and the rubber molding on the bottom of the front bow, mine keeps the rain out from there.
Are you certain that you have the correct 2-seater front bow?
The bow for the BN4/BT7 cants rearward opening up a gap most pronounced in the middle of the windshield.
steveg
Mine must be incorrect as it has a slight gab in the center. I use a strip of 1/2" square foam tape across the top of the windshield in rainy weather. Works well.
BN6_2197
BN6_2197
Gents, I use the duck tape work-around, too ;-) But I asked me if there is a better solution for that the aluminium trim peace hooks tighter in the middle of the front screen as it does on the left and right end. For wahtever reason the trim peace of the hood does not fiit tightly in the middle of the front screen. Volker
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
steveg TR6 Fixing the intake manifold Triumph 8
steveg TR6 Fixing Twisted Sway Bar Bracket Triumph 2
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
Got_All_4 TR6 Is this head toast or worth fixing Triumph 3
S TR4/4A Fixing dash support Triumph 11
T 100 4 Seat Base Fixing Hole Centers? Austin Healey 0
M BJ7 back panel fixing method Austin Healey 5
Tinkerman TR2/3/3A Rear wing fixing clamp Stan Part # 602167 Triumph 5
Jeepster Seat belt fixing Austin Healey 4
P BJ8 wing and panel fixing help? Austin Healey 3
Jeepster Front wing flash fixing holes Austin Healey 5
JamesWilson Fixing Fiberglass Flaws?? Restoration & Tools 9
T ideas on fixing - one carb keeps "rusting" Triumph 4
Hap Waldrop TR6 Fixing a TR6 engine Triumph 6
T Tips for locating/fixing foam rings under gas tank Triumph 4
T Ideas on fixing this? Triumph 19
regularman Found one problem while fixing another Spridgets 9
B Fixing crack in rubber bumper MG 1
bcliff Fixing a bad spot in the paint MG 3
germanmichel Fixing outer tube in steering box Austin Healey 11
G I my engine fixing to blow........................ Triumph 9
glemon "Fixing" Zenith Stromberg Emission Control Carbs MG 4
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
roscoe I'm fixing my overdrive with a saws-all Austin Healey 10
jhorton3 Fixing Things Spridgets 27
drooartz Leaking hubs, parts for fixing Spridgets 11
T Fixing Rust Triumph 16
bluemiata90 Fixing turn signals at head Triumph 3
69MGC Any tips for fixing a bent boot lid MG 7
cjm lightened flywheel,best fixing? Triumph 3
sparkydave Fixing Zenith-Stromberg needle adjuster Spridgets 5
S Fixing Dime sized chip Triumph 3
M Wedge tr7 turn signal switch fixing? Triumph 1
Slider748 TR6 Need help on fixing TR6 odometer Triumph 5
B Will fixing Healey Shake negatively affect Resale? Austin Healey 6
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
S TR2/3/3A 59 TR 3 hood emblem Triumph 2
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
R New Hood for BJ7 Austin Healey 3
KVH General Tech Fitting the Hood (Bonnet) Triumph 7
S TR2/3/3A Hood Stick Cover Triumph 3
dripdripdrip TR2/3/3A Best place for tonneau & hood stick covers? Triumph 2
B BJ8 Hood Bow and Seal Austin Healey 5
B Hood Woodwork Austin Healey 2
Papajack TR2/3/3A TR3 Hood and Sidescreen Colors Triumph 6
