Fixing outer tube in steering box
germanmichel
Hello @ all,
like written in the subject line,does anyone know,how is the outer tube end(around of the steering shaft)fix in the steering box ?
I talk about a steering unit of a 1960/BT7. For me it looks like it was... a tight fit. But now it have play and it is easy to remove. On the outside diameter of the tube it is tin lead solder, i think it is not original. So what is the original best solution to get it fix and sealed ? No manual show this area. I mean the area under the item bubble 5
https://www.limora.com/index/lang-1/lkz-1...oesserungtop=30
I think about different solutions : hard soldering , tight fit with expanding and turning the tube end, but what was the original solution ?
Thank you all from good old and cold Germany
Michel
Are you saying the wheel goes in and out or it has play when stationary? For in and out it has been suggested to use aluminum shims (piece of soda can)between the inner and outer tubes. For left to right wiggle there is a tightening adjustment on the steering box.
Dougal
Hi Michael, The fixed joint between the outer column tube and the Aluminum steering box is riveted in place. At least thats the case with my 55 BN1 (I also remember reading this somewhere!). The rivets are difficult to see on the outside but stick out proud on the inside (with clearance for the inner column). I found this out when trying to clean up the inside of the outer column. I was pushing a cloth through with a rod and it got jammed on the rivets. It took me a while to work out what the obstruction was as they are difficult to see.
Dougal
germanmichel
germanmichel
Hello,
thank you for your input.
But if I will fix it with a rivet, the outer column tube is not sealed in the housing. I think the connection has to fullfill the requirements of a torque and it has to be sealed.
J-B weld mh... good..I also think about bonding,it has to be absolutely clean (free of grease and oil) but it is solution with no heat influence. I think it can be a solution in combination with the rivet.
Bye Michel
Dougal
Hello Michael,
Just to make it clear the rivets on my steering tube are original. You are right in that it needs to be sealed in some way as it has to keep the oil in... My guess is that it would have originally been an interference fit (tight fit) then riveted and sealed with solder.
Your problem will be that hand rivets will stick out too far into the tube and touch the inner column. The original rivets only stick into the tube 2-3 millimeters (my guess as its not possible to measure without taking it apart). One way to get around this would be to drill and tap some threaded holes and screw in some short "grub" screws (no idea how that will translate!!). That way you can get the length just right. Once this is done I would either fill the gap with solder to take up any play or use resin.
The joint does not take a lot of load or torque as the box is bolted to the chassis and the tube is bolted to the bulkhead under the steering wheel.
Good luck and let us know how you get on.
Tchau
Dougal from new and hot NZ
Dougal
"Grub screw" my translation: not an insect but a short length of threaded steel without a bolt or screw head. They sometimes just have a slot in one end for a screwdriver.
vette
Yeh, them little itty, bitty grubs sure can get lost easy.
Michael, Just a thought for sealing, a cold weld or epoxy type substance might be just the ticket. Another posibility might be to use one of the "new" BONDING ADHESIVES. Found at most auto body supplies. There are different formulas for different applications, ex: metal to metal, metal to fibre glass, etc. I have used one that is a General Purpose composition. It is 2-part, with two tubes applied with one chaulk gun and both tubes in the gun together. I have used it on applying body panels. It is very strong. When set up it is very hard. This stuff is so strong you literally could glue a car together and never use metal welding.
Dave C.
zblu
This pic shows the original rivets in my early BN1 box
germanmichel
germanmichel
Hello,
thank you all for answering and thank you for posting a picture. I check my BT7 steering housing and did not find rivets. There was no time a rivet there. I think the rivets was a solution for the earlier cars. Also you have a different housing design. For me it should be the best solution, to expand the tube and realise a press fit connection.
Bye-Michel who fight currently with a frame challenge...and I will win... ;-)
Richard3000
Michel,
I've got a 1960 BT7 unit which you are welcome to have if you want. I replaced it because of wear in the peg and scroll bits, but you could rebuild it with your innards.
Where are you? North or South Germany? I'm in an even colder Switzerland, so it may not be too far.
Richard
germanmichel
germanmichel
Hello Richard,
thank you for your offer. But my steering is principal easy to fix. The reason why I ask here how to proceed was I dont know the original solution.
Bye Michel-who live near Frankfurt( in the heart of germany ;-)
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
steveg TR6 Fixing the intake manifold Triumph 8
steveg TR6 Fixing Twisted Sway Bar Bracket Triumph 2
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
Got_All_4 TR6 Is this head toast or worth fixing Triumph 3
S TR4/4A Fixing dash support Triumph 11
T 100 4 Seat Base Fixing Hole Centers? Austin Healey 0
BN6_2197 Fixing the Hood of my BN6 Austin Healey 5
M BJ7 back panel fixing method Austin Healey 5
Tinkerman TR2/3/3A Rear wing fixing clamp Stan Part # 602167 Triumph 5
Jeepster Seat belt fixing Austin Healey 4
P BJ8 wing and panel fixing help? Austin Healey 3
Jeepster Front wing flash fixing holes Austin Healey 5
JamesWilson Fixing Fiberglass Flaws?? Restoration & Tools 9
T ideas on fixing - one carb keeps "rusting" Triumph 4
Hap Waldrop TR6 Fixing a TR6 engine Triumph 6
T Tips for locating/fixing foam rings under gas tank Triumph 4
T Ideas on fixing this? Triumph 19
regularman Found one problem while fixing another Spridgets 9
B Fixing crack in rubber bumper MG 1
bcliff Fixing a bad spot in the paint MG 3
G I my engine fixing to blow........................ Triumph 9
glemon "Fixing" Zenith Stromberg Emission Control Carbs MG 4
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
roscoe I'm fixing my overdrive with a saws-all Austin Healey 10
jhorton3 Fixing Things Spridgets 27
drooartz Leaking hubs, parts for fixing Spridgets 11
T Fixing Rust Triumph 16
bluemiata90 Fixing turn signals at head Triumph 3
69MGC Any tips for fixing a bent boot lid MG 7
cjm lightened flywheel,best fixing? Triumph 3
sparkydave Fixing Zenith-Stromberg needle adjuster Spridgets 5
S Fixing Dime sized chip Triumph 3
M Wedge tr7 turn signal switch fixing? Triumph 1
Slider748 TR6 Need help on fixing TR6 odometer Triumph 5
B Will fixing Healey Shake negatively affect Resale? Austin Healey 6
SNClocks Gap between inner and outer fenders Spridgets 0
newmexTR3 TR2/3/3A TR3 outer wishbone bushing removal Triumph 5
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
B TR4/4A Outer tie rods Triumph 8
69MGC MGC Replacing an Outer Wheel Well panel MG 3
dbenichou289 TR2/3/3A Headlight outer trim ring Triumph 6
red57 What is correct wire harness outer wrap Austin Healey 17
AUSMHLY BJ7-BJ8 outer weather strip for door window Austin Healey 4
F TR2/3/3A KAS-Kilmartin outer sills with bow to match door Triumph 4
Csarneson How do the outer sills [rockers] drain water? Austin Healey 7
J TR2/3/3A Outer Front Wheel Bearing Triumph 22
Lukens Outer rocker showing "rust" Restoration & Tools 11
D TR2/3/3A 7.68, outer tie rod Triumph 4
B Outer steering column connection to the steering box Austin Healey 6
