Elf-Buick-Cooper S
aeronca65t
Last week I went to an exective board meeting for my club (EMRA) in Staten Island. We like to car pool since it's about a 1.5 hour drive, so I met up with my friends Mike and Pete. I show up at Pete's repair business about 15 minutes early and he is still finishing up a client's car. Pete does Brit-car repair, so I'm used to seeing some "odd-ducks", but this one was pretty rare: a Riley Elf (based on the classic Mini chassis). The Elf was right-hand drive and steel grey...very nice in an odd sort of way. These cars have a little trunk jutting out (with Sprite tailights) and a grill that reminds me of an old 3.4 Jag sedan.
After the Elf was done we hopped into Mike's Buick and the 3 of us drove about an hour to pick up Pete's girlfriend (our club treasurer). Then, on to Staten Island.
The meeting went well with lots of good "car-talk", plus we spent about $30,000 on upcoming events (track rentals).
On the way home, I commented about how much the Buick was swaying about as we kept up with local traffic (which means about 20 MPH over the speed limit)....little did I know! This Buick was a well-kept car, about 6 years old. As we slow down to pull off the main freeway (to drop off our treasurer) the right rear suspension fails, locking up the right rear wheel! We discover that the ball-joint has come apart on the right-rear suspension. Mike calls a tow truck so he can be towed home (about 65 miles...lucky he has insurance). But Pete and I can't ride in the truck (no room).
So Pete's girlfirend lends us one of her Minis to get home. She has a '65 and a '68. She has documentation to prove that her '68 is the last Cooper "S" imported by BMC to the US (there are lots of Coopers brought over later...but not by BMC).
We take the '65. It has a full roll-cage and harnesses. The engine is a 1400 cc offset-bore with Vizard cam, big carbs, ported head, hi-comp pistons, alum flywheel, trick distributor, close-ratio gears...you name it. It has nice aluminum 10" wheels and tires and Konis. This is a dry-suspension car (the newer one is wet-suspension). Honestly, she is a little-old-lady school teacher and drives this thing to work most days.
What a riot this Mini was! I have owned several Minis and driven lots of them. But this was the fastest Mini I've even been in. We didn't get home until about 1:00 AM but it was sort of worth it after being in that Mini.
dklawson
I'm glad the Buick made it safely off the road. Suspension failures can be very dramatic!
My Mini is near stock and I drive like a little old lady on Prozac... and I still love my car.
theinferno
sounds like what happened to my buick recently, except mine had the left front ball joint go... boy did that look catastrofic!
Brian_James New 67 Elf British Motor Corp 10
K Elf Brakes British Motor Corp 4
Steve Riley Elf on eBay British Motor Corp 2
bcliff Elf Explosion! British Motor Corp 8
Sherlock Riley Elf [2.2 Honda, RWD] British Motor Corp 2
huck6 Elf? British Motor Corp 6
I Riley Elf? British Motor Corp 10
BoyRacer Rover 3.5L (Buick 215 c.i.) Engine Swap Austin Healey 15
S MGB Buick or Olds MG 5
PAUL161 215 Aluminum Block Buick MG 65
RickB I've got that Buick hood removed from my Sprite. Spridgets 10
J Rover engine that started as Buick? Rover / Land Rover 9
DanNagy Wedge TR7 Buick Conversion Triumph 23
W 1996 Buick Other Cars 3
rick_ingram MGB-GT Project Roadmaster - The Big Block Buick MGB/GT MG 4
philman six buick 215's for sale on PDX Craig's list Restoration & Tools 0
G Buick engines Other Cars 3
R 215 Buick into 79 "B" MG 5
W buick v6 Triumph 15
69MGC Buick V8 pricing question MG 2
KLUTZ Clear Coat flaking off my Buick Restoration & Tools 3
78Z Buick 3.8L swap MG 9
BobHaskell Mini Cooper rear subframe replacement British Motor Corp 3
K MK1 Cooper S? British Motor Corp 3
tahoe healey Cooper Air Filters Austin Healey 7
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
Sherlock Mini Cooper patina Spotted 0
J 2006 Mini Cooper S British Motor Corp 6
M Cooper's Air Filter on H1 Carbs Spridgets 5
tahoe healey Cooper decal on air filter Austin Healey 2
Jim_Gruber Shift Points for Bugsys 948 w Cooper S Head Spridgets 3
T TR4/4A Composite vs cooper head gasket with Randall's "trick" Triumph 6
David Townsend MK I, MK II, Cooper S Limited Edition Fine Art Prints British Motor Corp 0
G help with a part Id. cooper air cleaner? Other British Cars 1
R Tyres for Mini Cooper British Motor Corp 7
U Mini Cooper S Roadster ! British Motor Corp 1
S TR2/3/3A cooper head gaskets packaged improperly Triumph 6
T Cooper S block needed British Motor Corp 2
C Car of the Week [Mini Cooper S MkII] Racing 2
Brooklands Mini Cooper Pick Up Truck British Motor Corp 2
tr6nitjulius Cooper-S @Dyno British Motor Corp 0
Aggudabbu convert cooper engien for spridget? Spridgets 23
69MGC B with Mini Cooper Headlights MG 9
bgbassplyr Cooper project on ebay British Motor Corp 0
theleisure twin-engined-4x4-1966-twini-cooper-s British Motor Corp 1
HealeyPilot Starter motor replacement - Mini Cooper S British Motor Corp 3
HealeyPilot 1275 Cooper S starter British Motor Corp 5
S 2005 Mini Cooper British Motor Corp 20
Tom Rynne Cooper Decal Spridgets 6
