Color coating almost completed, clear is next
Brosky
As of about 4:00, George, our Paint Master, was getting ready for the final coat of Mimosa and I got these while he was loading up the gun. After drying a scuffing, cleaning and tack and then the clear.
By Monday the paper will be coming off after a nice weekend in the booth setting up. Then the grille area and rear panel will get new matte black finishes and reassembly starts.
Sorry the views aren't better but these paint booths are not what one would call huge.
G
Boy that looks great. Nice panel fittings. What did you ever decide to do for the scuttle draining hoses?
DNK
BobbyD said:
... So what winter projects do you have planned?
How bout just kickin back and resting for a change. :laugh:
Brosky
Brosky
Gauge cleaning (which I have the all of the cases to swap into painted) and new dash panel and that's it.
Brosky
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]What did you ever decide to do for the scuttle draining hoses?[/QUOTE]
Sorry Stirkle, I almost missed your question.
I got the 65-66 Mustang 1/4 panel drain vents which I forgot to take a picture of, but will give the link below. Alan ran a hose from the main drain on each side which will pipe into these drain covers that he will install in the front inner fender shields. He left those off and will install them after the paint work is completed.
I'll post pictures next week after the panels are cut and the plugs are fit in place to show how he did it.
There is two coats of POR15 inside each fender now, so I don't think that I'll worry much for the next 34 years.
Mustang 1/4 panel drain plugs
A Paint Color Codes Austin Healey 0
B Cove Paint Color Ideas Austin Healey 10
F TR2/3/3A Headlight bucket color Triumph 22
P General TR What color is original for engine parts? Triumph 7
BoyRacer Silver Healey - Chassis Color? Austin Healey 17
B TR6 Help with color and color code / paint recommendation Triumph 4
S 1958 100/6 Bumper Brackets Color Austin Healey 2
R Cooling Fan Color Austin Healey 6
B TR4/4A Dash Color? Triumph 3
B TR4/4A Gas Tank color? Triumph 4
A Color Matching Austin CU 50 "Dominican Blue" British Motor Corp 3
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
D TR2/3/3A center panel indicator light color Triumph 10
R TR2/3/3A OEM Paint color Number for 54 TR-2 british Racing Green Triumph 5
R Speedo High Beam Warning Light Color Austin Healey 14
Rut TR4/4A Dash color Triumph 9
G Opinion on spark plug color Austin Healey 15
R TR6 Sapphire Blue color Match? Restoration & Tools 3
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
B Longbridge 100-6 Windshield Posts - Body Color or Silver? Austin Healey 16
Jim_Stevens TR2/3/3A Finally- the color coat! Triumph 12
Jim_Stevens TR2/3/3A Rear fender stays: black or body color? Triumph 8
M Rear ended pumpkin color Austin Healey 6
T TR2/3/3A Chassis paint color Triumph 10
B Dashboard color Austin A40 Devon 1948 Restoration & Tools 2
Marvin Gruber Most popular color for A/H 3000 Austin Healey 56
Johnny AH BJ7 Trafficator Color? Austin Healey 7
N Bumper bracket and fan shroud color Austin Healey 5
P TR2/3/3A TR2 color questions Triumph 23
HealeyRick Color Match Misconception Austin Healey 15
R TR2/3/3A Color Wiring Diagram-1954 TR-2 Triumph 1
I TR6 Gauge/color wire ? Triumph 9
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
B GT6 Chassis color Triumph 4
D TR6 What Color is This? Triumph 11
T BN7 wiring diagram in color Austin Healey 7
busybrit TR4/4A Steel dashboard color Triumph 1
T Austin Healey 100 engine color Austin Healey 10
Rut Bugeye generator color Spridgets 22
simon1966 100 X Brace Color? Austin Healey 16
F TR2/3/3A Wheel Color Triumph 2
brgrmyster GT6 67-68 GT6 Mk1 exposed pushrod tube color? Triumph 5
J TR6 Paint color Triumph 22
simon1966 Eclipse Day Photos, back to her old color! Austin Healey 2
CJD TR2/3/3A Grease Gun Color Triumph 9
maxwedge5281 engine compartment color Austin Healey 2
R BT7 Brake Drum Color Austin Healey 7
busybrit TR4/4A TR4 Steel dashboard color Triumph 8
Jim_Gruber Paint Color - Black Satin or Black Glossy for Suspension components Spridgets 9
