Clip question with pic
RestoreThemAll
Hello!
For health reasons I haven't worked on my BJ7 for many months. I must have ordered the clips in the pic during a hazy moment because I don't recall where they go. I've looked for the invoice but can't seem to match things up. There are six of each, and have different screws. Does anyone recognize them?
They look like (either/both) fuel pipe or wiring harness straps to me. Sheetmetal screws to the chassis underneath the car, and some of the ones in the engine compartment use threaded inserts.
R
RestoreThemAll
Hi Randy,
I think that we've identified p clips for the frame rails;gas and brake pipes, battery cable, and wiring harness. We've found some clips that are v shaped where the lower part of the v passes through the metal and the brake line passes through and is held by the top of the v. I don't like those as they allow moisture to pass through, into the frame for instance. I should also mention that I have a Jule frame so that we've been using pics of other cars to identify the locations for the p clips. It could be that the straps in the pic could be used in place of the v clips?
I don't have any good pics of the top of the fire wall where the clutch line (I think) passes, or pics of under the dash where the wiring may be mounted. Are there clips or straps in those places?
Thanks for you assist!
Dale
Johnny
There never was a strap used on a Healey. If by strap you mean plastic ties. Use the metal clips. In certain places I used the rubber sleeved type to prevent electrical shorts. Their were some metal straps from the factory, just about 1/2" wide by varying thicknesses that were spot welded in to hold the wiring harness in place under the dash. Also in the trunk you'll find some. On these I used shrink wrap to completely insulate the bendable strap.
Good luck with your restoration.
Patrick67BJ8
RestoreThemAll said:
Hi Randy,
Dale
There's "V" clips for the clutch line on tp of the firewall. I have a Jule frame too and instead of the original Brake, Fuel and Wiring Harness P-clips I used aircraft style clamps shown in the photos. I left the "V" clips for the clutch line where it routes near the top of the shroud "original" for now.
R
RestoreThemAll
Thanks Johnny. When I mentioned straps I was refering to the clamps or clips in the above pic. After reading your post I looked for and found all of the straps that you listed. I really like the shrink wrap idea. I'll do the same.
Hello Patrick.
It's always good to hear from another Jule frame owner. I'll use the p clips, and bobby pin clips "V" as you have. You see I've learned a new term today. The clips that I called v are bobby pin clips. We're also using the nut serts in the Jule frame to hold the p clips.(thank you Randy Forbes for turning me on to nut serts a couple of years ago).
Here's some good news...my son is home for a visit and has me working on the car again! He lives in florida and has been restoring 1950's and 60's Corvettes with his buddies for the last few years.
Thanks all for your input.
Dale
Patrick67BJ8
Hello Patrick.
Dale
Hi Dale,
I drilled holes in my frame and tapped them for 10-32 screws. I decided on 10-32's because that's what most of the screws are in a Healey. I did make a change to the brake line mounting on top of the front cross-member in front of the engine. Instead of 4 holes as original, I used two holes(pics attached). It was easier for me to just drill and tap instead of nut-inserts and I like "simple" and good looks.
I also used a really simple way to attach the insulation panels to the sheet metal too and make them look "original".
R
RestoreThemAll
Hi Patrick,
I'll use your idea on the cross member. Much better than the bobby pin clips.
I'm not clear on insulation panels. Are you saying that you use the same method as the cross member, tap and thread?
Thanks, Dale
Patrick67BJ8
Hi Patrick,
Thanks, Dale
Here's a link to my article on John Simms website that will explain what and how I did it. The hole I drilled was a real tight fit for the T-nuts and I actually had to use a hammer and tap them in. Let me know if you need more info?
https://www.healey6.com/Technical/Captive.pdf
R
RestoreThemAll
Thanks for the link Patrick. I understand now. Great idea!
Dale
tony barnhill Midget Moulding Clip Question Spridgets 15
R Window Seal Clip Question Austin Healey 6
F TR2/3/3A Headlight bucket clip Triumph 2
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
J Wanted 1969 MGB Roadster sun visor clip MG Classifieds 4
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
K TR2/3/3A "Clip on" style side mirror? Triumph 9
F Wanted TR3A rear seat peg and clip Triumph Classifieds 2
J TR4/4A TR4A seat retaining clip Triumph 5
J TR4/4A Seat install, Spring clip Triumph 0
steveg TR6 Source for fuel line P-clip Triumph 17
F TR2/3/3A continuing repairs to front clip Triumph 16
Bruce Bowker For Sale MG Tie Clip MG Classifieds 1
Bob_Spidell Clip and ferrule for manifold drain pipes Austin Healey 4
J TR4/4A Horn clip position. Triumph 6
Gerard Bugeye bonnet and entire rear clip Spridgets 4
M Morris Minor Spring Clip Rubber Other British Cars 0
Rob Glasgow Extra clip - Austin Healey 5
K TR2/3/3A Leaf Spring "rebound clip" thickness .... Triumph 16
Tinkerman TR2/3/3A Front clip order of bolt tightning Triumph 9
Simmo MGB Have you ever tried removing the spring clip on the Keylock from inside the door MG 0
6 Speedometer Light Clip Spridgets 3
B 79 Midget Visor Clip replacements...mine are riveted..is this correct? Spridgets 7
vette Battery Cable Clip Location Austin Healey 19
F Looking for the retaining clip/brace... Triumph 1
J clip on back of battery box Triumph 4
luke44 Clip - Brake Line to Firewall Triumph 3
Tinkerman TR2/3/3A 60 TR3A FRONT CLIP ORDER OF ASSEMBLY ? Triumph 10
RickB Donated for Peter's car - front clip Spridgets 13
9 Spitfire Spitfire front clip on a TR4 Triumph 17
B rear wheel cylinder C clip install?? ugh Spridgets 24
I TR6 TR6 fuzzy seal clip help please Triumph 16
Stinger TR4/4A TR4A Door Check Strap Spring Clip Replacement Triumph 4
Jim_Gruber Complete Spridget Front Clip Spridgets 1
K TR4/4A TR4A Master Brake Cyl Internal Spring Clip? Triumph 6
B Rear Clip weight Triumph 2
M Clip on hardtops for a Bugeye Spridgets 6
R HELP! Wheel brake cylinder clip MG 9
M Link for clip on top Spridgets 3
Johnny Do you have this video clip of an AH? Austin Healey 6
ekamm TR2/3/3A Movie clip of TR3 Triumph 14
M Help "ID" this clip on hardtop please Spridgets 7
T Wedge TR7/8 doing it's thing in this clip Triumph 3
Tinkerman TR2/3/3A Radiator overflow pipe clip TR 3A [pics added] Triumph 9
M Rear Brake Cylinder Retainer Clip Installation Triumph 14
N Rear clip Austin Healey 3
Paulus Clip art Triumph 19
zimmy old clip out...new clip in Spridgets 8
B Window Seal Clip Tool Spridgets 5
B Front Clip Back Together Spridgets 12
