GT6 Chassis color
Bob Buxbaum
After using Google, I still want input on underbody, firewall, and chassis colors. My GT6 was originally white, and will be again. The majority of search results had the firewall in body color as well as the chassis from the firewall forward.
I will not be building a concourse car, but a "correct" stock carr as a driver. What color should the underbody be (although I plan on covering it in "rockchip" versus actual undercoating as there will be seam sealer at all welded areas) as well as the frame itself?
dklawson
My '67 is also white. It is white everywhere including the frame. Welcome back!
B
Bob Buxbaum
Still original paint or restored? Since my frame will be media blasted I will be free to apply whatever I want. Powder coat is a matter of how competent the person is, and sometimes can be too glossy. POR 15 is available in gloss white, but will be a bit more white than the original color, but done right is indestructible.
dklawson
Our car has been repainted several times since new and has always been in the family. When I made a similar inquiry to yours I was told the frame was body colored, not black.
I have mixed feelings about POR. It sticks well to rough surfaces (sandblasted, heavily etched, or rust converted). However, it easily peals off of smooth surfaces like those left by bare, sound sheet metal. Painting over POR can also be tricky. I have tried a couple of their primers to apply over POR and had mixed results. To each his own.
Were I undertaking another project today, I would consider sandblasting the frame followed by epoxy primer and a topcoat to match the body. Again... to each his own.
B
Bob Buxbaum
Understood on all points. The chassis will go back to bare metal again. I did not neutralize the soda (at the time, I didn't know) so the self etching primer is not holding. Plus, surface rust has reoccurred. No surprise there. If bare metal scuffed with 200 grit and fully prepped with the POR treatments, the 15 will hold. Since it is available in white, if use POR 15 it will go on the frame. The interior panels (the original non-visible surfaces) will be cleaned, and then I have to decide on spray on rust neutralizer of POR-15. The POR 15 will certainly stick to old sheet metal because there is plenty of surface "texture" due to aging and will stick to it. If I use spray neutralize, it is porous to humidity so must be painted with non water based paint. So, that means rattle can primer, sealer, and paint. The welded surfaces will be handled with weld through primer.
BoyRacer Silver Healey - Chassis Color? Austin Healey 17
T TR2/3/3A Chassis paint color Triumph 10
B Chassis color Austin Healey 11
A BN2 Chassis Alignment Austin Healey 8
RJS TR4/4A Chassis Buffeting(?) Triumph 10
apbos The next rabbit hole. Help ID the chassis. Racing 27
apbos Help Identify this car chassis Racing 20
5 MGA Body and Chassis Separation? MG 2
HealeyPassion Finally, paint on chassis Austin Healey 17
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
Pep Daimler SP250 A-spec vs B-spec chassis Other British Cars 9
M TR6 TR5/6 Engine Mount/Chassis Brackets Assistance Please. Triumph 2
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
Guido36 Chassis Number Issue Austin Healey 11
Editor_Reid Healey 100 Chassis Dimensions Austin Healey 5
F TR2/3/3A back half to chassis questions Triumph 105
M Mounting BJ8 Chassis on Rotisserie Austin Healey 8
J Wanted WTB Triumph TR6 Body/ Rolling Chassis Triumph Classifieds 0
lbcspinners BJ8 chassis number ending with suffix "G" [??] on BaT Austin Healey 11
B Chassis Suppliers Austin Healey 0
J Wanted MK VII/VIII/IX rolling chassis with or without drivetrain Jaguar Classifieds 2
J Wanted Jag MK VII/VIII/IX rolling chassis with or without drivetrain Other British Classifieds 1
J Wanted TR3/4 rolling chassis Triumph Classifieds 2
J Wanted TR3 or TR4 rolling chassis Other British Classifieds 3
C TR2/3/3A TR2 Chassis Clips Triumph 4
B MGA Mystery MGA chassis part MG 3
V TR2/3/3A TR3A Chassis restoration Triumph 8
BoyRacer Rig for storing chassis on its side Austin Healey 8
M TR4/4A Reducing rear chassis flex. Triumph 3
red57 Metal prep of chassis after repairs and shot blasting Austin Healey 5
B General Tech Prime over Chassis Saver? MG 3
TomMull Numbers re Chassis project Lotus 4
crya Current go-to source for VIN/Chassis Repro Plates? Austin Healey 8
TomMull CHASSIS SHIPPING Lotus Elan Plus 2 Lotus 22
P TR2/3/3A Chassis paint questions Triumph 8
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
M TR4/4A Reducing Chassis Flex on TR4A IRS Triumph 2
C Chassis plate screwsize Austin Healey 6
aero3113 BN2 Front Chassis Rail Austin Healey 6
Jake For Sale FS: BN1/BN2 Kilmartin Chassis Repair Parts, New Austin Healey Classifieds 2
K How would a new-chassis car be registered? Austin Healey 15
PeterK TR2/3/3A Ebay rolling Devin body moded chassis - with O/D Triumph 1
P BN1 Rear Chassis-to-Shroud Extensions Austin Healey 1
Brinkerhoff TR4/4A Straightening a TR4A IRS chassis Triumph 15
BoyRacer weight of bare Healey chassis Austin Healey 8
I Chassis rotisserie..? Austin Healey 10
A Chassis front 'H-section' Mk1 Spridgets 5
S Austin Healey 3000 BT7 1960 VIN chassis STAMP location Austin Healey 9
madhouse need new chassis Austin Healey 15
