germanmichel
Hello @ all,
in my first introduce post I told you my first challenge with my 6 weeks before bought healey.
My healey has some good sides: basicly a relative good body,running engine and absolutly orginal complete interieur. But one bad side... see the pictures.
It is a bad in the US repaired accident. I think the main beam was bent up (direction motor)before it would "repaired" . To straigtening the crumbeld main beam they cut the main beam from the top side and welded it to close the gaps after straithening.(one picture from the inner side and one picture from the outside) To stiff it, they weld a stiffener plate over the weldseam on the outside..... The weldseam on the inner side is not covered. The main beam is relative straigth in the length axis,but the front end is turned, see the pictures.
Has someone an idea how I can repair the frame /chassis <span style="font-weight: bold">professional</span>, without changing the whole frame ?
The biggest challenge in my opinion is I dont know does the "bodyshop" use heat to straigth the main beam. I think so, because of the surface rust (no paint,no grease). I hope the frame is not soft.....
Here one hopefully picture
Thank you for your opinions in advance.
Michel-who live in the country side near Frankfurt
If you found an mistake in my english , you can have it for a present :thumbsup:
Whithout joking please correct me, for better learning english.
