Blue smoke on startup?
MadRiver
Bronze
Howdy MG people:
I'm thinking of finally diving in and buying an MGC tourer, and there's blue smoke at startup, which dissipates quickly as the engine warms up. Should I be seriously concerned?
Thanks!
LarryK
Blue smoke on startup is usually vindictive of worn valve guides. Clears up after start and may appear on heavy acceleration. If you know how to remove head, take to machine shop and replace guides, but then rings could be next with full compression up from new guides and gaskets.
It's a how bad you want the car and how you dicker price to overcome the faults. Owner must know and will dicker. I would also do compression test in front of him and show him the figures.
MadRiver
MadRiver
Bronze
Thanks Larry. The seller says that the valve guides are new, which could point to rings. Having never done a ring job on an LBC, what does that sort of thing usually cost?
Steve_S
An MGC is much more expensive to rebuild than an MGB. Parts cost more and there are more of them. I know someone who paid nearly $10K for a performance rebuild on his C engine, but you can get it done for less of course.
tony barnhill
Great Pumpkin - R.I.P
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]The seller says that the valve guides are new, which could point to rings.[/QUOTE]
Not necessarily. New valve guides doesn't rule out smoke from valves on startup....if they didn't properly install (or forgot to install) new valve seals, you'll get that little blue puff on startup.
& if it were rings, it probably wouldn't stop when the engine got hot as the oil thins out & would continue to sneak past bad rings - it just wouldn't be so visible.....get it hot & stand behind the car while a friend races the engine...look, feel at the tailpipe, & smell for oily smoke.....if its rings, there'll be a telltale presence.
Before I did anything, however, I'd do both a wet & a dry compression check to see if there's a problem & where its located.
Plus, what's the oil pressure both cold & hot?
Edited: I believe the car's telling you something different than the owner (https://www.theautoist.com/buying_an_MG1.htm)
zahnej
Tony is right on. I would still suspect guides and or seals. Although a compression test probably would not show guide or seal problems it's still the best test for the overall condition of rings and valve seating.
tony barnhill
Having said all that: would I let it stand between me & a solid MGC? NOOOOOOOOOOOOOOOOOOO...........
LarryK
I did not mention seals as some of the early British cars used a valve to guide tolerance. Eg:GT6 no seals in parts manuals and not available. Some used Chevrolet umbrella seals.
PAUL161 T-Series Puff of blue smoke on startup MG 17
NutmegCT blue/gray exhaust smoke Other Cars 13
Keith_M Now the smoke is blue/gray Spridgets 10
2wrench TR6 TR6 Water in the oil; blue/gray smoke. Triumph 5
A TR6 TR6 With the very occasional blue smoke puff. Triumph 8
Mark_Gibson TR6 Blue Smoke and Bulletproof TR-6 Engine Triumph 2
Mark_Gibson TR6 Fresh TR-6 Engine Rebuild, Blue Smoke....... Triumph 17
C For Sale Rover Mini Blue Star Tribute Other British Classifieds 0
Eeffoc TR4/4A Out of the blue - started to loose power Triumph 17
vpanza Wanted Salvado blue paint sample Triumph Classifieds 8
S Baby Blue gets a Shout Out from BaT Spridgets 4
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
BoyRacer Rattle can Healey Blue paint Austin Healey 2
BoyRacer Blue Vinyl Dash Material Austin Healey 3
A Color Matching Austin CU 50 "Dominican Blue" British Motor Corp 3
J Opalescent Silver Blue paint code Jaguar 0
B TR4/4A Midnight blue interior Triumph 6
boxofparts TR2/3/3A TR3 Spotted Petoskey Michigan Red and Wedgewood or Powder Blue Triumph 1
BJ8Healeys For Sale BJ8 blue full tonneau cover Austin Healey Classifieds 2
R TR6 Sapphire Blue color Match? Restoration & Tools 3
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
Mickey Richaud TR2/3/3A From Out of the Blue! Triumph 12
A Modern paint codes for Speedwell and Iris Blue for my Bugeye Spridgets 7
M TR2/3/3A Red or Blue Loctite Triumph 1
HealeyRick Healey Blue Austin Healey 12
glemon Iris Blue Spridgets 11
M Modern Paint Code Needed for Honolulu Blue Restoration & Tools 1
M TR2/3/3A For those with blue/white/black TR3 badges Triumph 7
L Ice Blue [BU2] touch up pen Austin Healey 5
Mickey Richaud Blue Healey on the Blue Ridge Parkway Spotted 0
K Healey Blue Paint Source Austin Healey 30
wangdango BJ8 gauge blue jumper? Austin Healey 2
A Iris Blue vs Speedwell Blue Spridgets 10
Scotsman TR4/4A Triumph Royal Blue paint code and formula Triumph 3
R TR4/4A Where can I get Triumph Midnight Blue carpet? Triumph 0
S Baby Blue to the Rescue...again Spridgets 8
DerekJ Healey Blue Paint - suggestions Austin Healey 23
K 1980 Jaguar paint colour.... Quartz Blue? Jaguar 2
S A Playmate for Baby Blue? Spridgets 19
bighealeysource My Healey at a Blue Angels Air Show in Beaufort,SC Austin Healey 0
J Pacific Blue paint code needed Jaguar 6
HealeyRick Blue Bristleflex? Austin Healey 3
B Recommendation for Healey Blue and Old English White Paint Austin Healey 15
S Happy Birthday, Baby Blue! Spridgets 6
Rut Iris Blue interiors Spridgets 15
simon1966 Armacord in the trunk, Healey Blue BN1 Austin Healey 5
S Were Valve Covers Ever Painted Blue? Austin Healey 8
weewillie baby blue Spotted 1
KVH TR4/4A Baby Blue TR4 Triumph 2
