2500M sun visors
TRclassic3
One of my visors is missing and the other....well, not pretty. Has anyone found a source, or an alternative that could be used?
ralph_s
Ed,
Good to see your working on the top side of the car. And Sun visors, sounds like you're getting ready to drive!!!
aztvr
Member
Grantura_MKI said:
I do have visor's to suit 2500's. You will need to see if they are the same?
Cheers,
D.
Ps. Hi Jim!
David, Seeing your post prompted a thought. PM sent.
Jim
TRclassic3
TRclassic3
Forgive my ignorance, but how do I determine if they are the same as you have, etc. etc. Are you the link that aztvr referened?
Thanks
TRclassic3
TRclassic3
Hi Ralph,
Things are coming together pretty well. The car is very driveable...and a blast to do so. The interior was pretty ratty, with chunks of carpet missing or totally worn out, drivers seat collapsed, and so on. Had a local guy here that specializes in collectables and hot rods redo some things. Made some nice changes that a pureist might not go for, but made a lot of sense to me.
Are you by any chance coming down to british car day in MD? We will plan to have it there. It would be great to compare notes again.
https://www.chesapeakechaptermgtclub.com/OBCD_main.htm
ralph_s
Haven't been there in years, but would be nice to attend. I'll plan to be there. Maybe I'll figure out how to get fresh air into the car by then since the PO covered everything w/ carpet. Gave new meaning to wall to wall!!!!
aztvr
Member
Thanks
No, the link that I posted is just one I had saved after seeing a reference on a forum.
David ( Grantura_Mk1 ) is a TVR restorer of some repute. I'm sure that he will be back around to let you know a little more about what he could supply.
TRclassic3
TRclassic3
Hopefully no offense was taken by David, as certainly none was intended.
Thanks
TRclassic3
TRclassic3
That sounds great Ralph. I must tell you, that although my vents are there, and I can feel some air movement through them, it can still be very warm, particularly in the foot wells. The way mine is right now, hot engine compartment air is being pulled in, Due to the custom made radiater the hose cannot be routed in the usual manner. I'm trying to work out a way. Fun stuff.
TRclassic3
TRclassic3
Re:Grantura_MKI 2500M sun visors
David,
Still in need of visor assistance. Can I send a photo or provide info that would allow you to determine if you have something?
Thanks
Ed
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
C My 2500M progress/questions thread TVR 5
bravenrace WTB - TVR 2500M TVR 0
bravenrace For Sale 1974 TRV 2500M FOR SALE Other British Classifieds 2
A 1974 2500M Spring Rates TVR 6
J Looking for a 2500M TVR 0
S 2500M or Vixen wanted TVR 0
B 77 2500M Shocks TVR 0
O TVR 2500m weatherstrip source needed TVR 2
J 1973 2500M ignition issue TVR 8
Z Just Restored 1973 TVR 2500M, Barn Find TVR 25
T Tvr 2500m For Sale, Nice Original Solid Example. TVR 1
M TVR 2500M Triple Weber 40 DCOEs TVR 130
R 2500M Carb Conversion TVR 5
Jastx TVR 2500M tires - what are you running TVR 7
TRclassic3 2500M Heater cable TVR 1
TRclassic3 Flasher units 2500M TVR 3
Kirk_Fisher 74 2500M prices TVR 9
TRclassic3 2500M rear suspension TVR 5
R 2500M Overdrive options TVR 13
Kirk_Fisher 2500M V8 on Ebay TVR 2
R 2500M Vents TVR 3
TRclassic3 2500M carpet kit TVR 1
R Windshield for a 2500M TVR 3
TRclassic3 Tranny removal 2500M TVR 10
R A fan of 2500M's!!! TVR 3
B 2500M chassis tube question TVR 2
R 2500M Cooling TVR 1
B 2500M search TVR 5
R 2500M Battery TVR 0
M TVR 2500M Model TVR 4
R Ignition Circuit - 2500M TVR 0
G Parting out a 2500M - Should I do it? TVR 18
Mickey Richaud 2500M on Ebay TVR 4
J TVR 2500M Shop Manual TVR 9
G 2500M hood TVR 3
G Gas tank for a 2500M TVR 5
H How to Remove Sunroof on 2500M? TVR 0
H How to Remove Sunroof on 2500M? Restoration & Tools 5
H Door Panel Removal on 2500M? TVR 4
H Photos of My 2500M's Engine and Radiator TVR 9
H Steering Column Binding in 2500M TVR 5
H 2500M Features and Stuff to Fix TVR 2
H Owners Manual for 2500M? TVR 3
H 2500M Came Originally With Electric Cooling Fans? TVR 19
H Bad Tach in 2500M TVR 0
AngliaGT 2500M on craigslist TVR 4
bravenrace Ebay 2500M race car and TR-6 Engine TVR 9
bravenrace 2500M Header Info Needed TVR 1
bravenrace 2500M on Ebay TVR 5
