Spitfire My first Spitfire
sbrmalott
An elderly neighbor had this in his barn for 20+ years. Needs lots of work.
dklawson
Welcome. May you get the car on the road without emptying your wallet.
PAUL161
Is that a 74? Looks like an excellent project! I always like the Spits. One of our former friends had a new one, SHE loved it! PJ
Rhodyspit75
Do I detect an inference that the Spitfire is a girls car?
LarryK
Looks like a good cleaning and sorting will make it a good driver. Congrats and happy motoring.
S
sbrmalott
Thanks. Its going to need a lot of work on the engine. From what i can tell from pic's on the net the previous owner installed Dual SU HS-4s but never hooked them up. As well as other wonderful half done things that i have no idea where to start. But at least it will keep me busy.
PAUL161
Not really, but she looked pretty sharp behind the wheel, even not behind the wheel! :jester:
BillyB62
I drove a Jeep Liberty for years, also considered a "girls" vehicle. Had a blast driving over things.....as for the Spit, you're in the game - let others think whatever they want! Congrats!!!
S
sbrmalott
So Question No. 1. Where does the vacuum line go from the distributor if there is no Thermostatic Vacuum (TSV) Switch that i can see?
dklawson
For now... plug the vacuum line. Worry about it later.
At this point focus only on checking the engine and getting it ready to be started. Since it sounds like the engine has not run in 20+ years, start with mechanical things.
Mark and remove the spark plugs.
Make sure the engine is not seized from years of sitting. Find a very large wrench and put it on the front pulley nut. With the gearbox in neutral, turn the engine clockwise (looking at the pulley).
If the engine turns over with the big wrench, change the oil and antifreeze. If it does not turn over with the wrench post back here and let us know.
With fresh oil and a charged battery, remove the spark plugs so there is no compression and turn the engine over on the starter until you see the engine has developed oil pressure.
Once you have gotten to that point post back. You will need to go through the ignition system, set the static timing, and do some basic carb checks and adjustments.
With a car that has been off the road for 20+ years, plan on rebuilding the brakes and replacing several brake components.
tdskip
Welcome, these are fun cars. Enjoy the process of get her sorted out, and as you have already found lots of good people here.
Mickey Richaud
S
sbrmalott
Thanks for the advise dklawson. I made sure the engine turned over before i bought it so we know that is good. The last owner put on Dual SU HS-4s but never hooked them up. No fuel line from the pump to them. No wire going to the distributor or vacuum. Keys were lost a long time ago so his son cut the lock off and got keys made but never put it back on. I need to drill out whats left of the screws and find some more. Im sure there's more but that's all i can think of right now. Lots to do before i get to start her. :(
dklawson
There are basic settings for SUs that will get things close enough to get the engine started. Since the carbs sat for a long time, you will need to go through them making at least a cursory cleaning and to make sure all the parts move freely. Be sure to open up the float bowls, clean out the crud, and inspect/set the float valves.
There were a couple of different distributors used over the years and you mentioned that your engine is not original to the car. Post back with which distributor you have and I am sure one of us here can advise you on basic connections to get it wired up. Also mark and remove the wires from the coil long enough to measure the resistance across the coil terminals and let us know what it measures. Pictures help also.
So is the lock on the steering column, half on the column? The locking steering columns used a lock that is secured using shear-off tamper-proof bolts. The easiest thing to do is take a thin cut off wheel and cut a screwdriver slot in what's left of the bolt heads. Use a screwdriver or impact driver to remove them. When putting the lock back on the column, do not bother with the tamper-proof bolts. Buy regular 5/16-18 (UNC) socket head cap screws. They will thread right in and you will be able to install and remove the lock as many times as you want. The tamper-proof screws were probably a great idea at one time but are really annoying when working on these cars. If the lock is off and not on the column, connect it electrically and just use it as is until you are ready to start driving he car. Some owners buy an earlier dash-mounted switch and move the wiring there to do away with the steering column mounted lock altogether.
S
sbrmalott
Some Photos of the mess I'm in :smile:
Just changed the oil and it looked new and didn't smell burnt which i guess is a good thing.
trrdster2000
sbrmalott. You have lots of fun in the future, but get a metal pipe for the fuel hose that goes from the pump to the carbs, not a good idea on the rubber. Have a look at some photos of the Spite's and you will see the routing, along with a clamp that goes to the top of the thermostat housing.
Wayne
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K TR2/3/3A Mystery Clutch MC? Spitfire....TR4....69-70 TR6??? Triumph 2
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Spitfire Spitfire 1500 Triumph 3
T Spitfire Spitfire lights Triumph 7
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
glemon Spitfire Spitfire Questions Triumph 7
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
T General Tech Spitfire overdrive, the sequel Triumph 3
