TR6 75 TR6 Speedometer bouncing
irishcasey
Hi, my TR has sat idle from some time. Back on the road and the speedometer needle is somewhat steady but bounces up and then back down frequently. Also sounds like a clicking from under the dash. Any ideas on how to trouble shoot this would be appreciated. I believe the trip odometer is working and I also think the regular odometer is working.
Thanks !!
TR3driver
Great Pumpkin - R.I.P
You can remove and inspect the inner cable for damage, but my guess is that the problem is inside the speedo head itself. On my "barn find" TR3, the trip and odometer mechanisms were so stiff that the speedo cable would wind up every time the little ratchet tried to turn the wheel, then unwind while the ratchet was resetting. When I disconnected the trip & odo, the waver went away. Took a couple of iterations, but I finally got them cleaned, polished and lubricated to where the needle doesn't waver today. Of course I also cleaned and lubricated the speedo mechanism.
If you do decide to pull it apart yourself, be very careful when removing the needle. I got a little carried away with one speedo (fortunately one I was just robbing parts from) and the spindle snapped before the needle came loose. Now I twist the needle rather than just pry it up.
M
Member 10617
I had the same problem with my speedometer. It jumped around, made increasingly loud noises, and finally stopped working altogether. I sent it off to be rebuilt, and in about ten days had it back in brand new condition.
But if you try to fix it yourself, be sure to heed Randall's warning, and you might want to look at Anthony Rhodes, Repairing Jaeger & Smiths Speedometers. You'll find it on the web at https://mywebpages.comcast.net/rhodes
Remember: All your gauges are mechanical (at lease on the early Triumphs), except the fuel gauge, which is electrical.
I
irishcasey
Hi,
LexTR3, can you tell me where you sent the speedo to to be reconditioned please.
I disconnected the cable at the speedometer and then also disconnected the other end at the small yellow box just on the engine side of the fire wall. This section of the cable is only about 2-3 feet long. The square inner cable moved freely and could be easily twisted in my fingers. Also appeared to have light lubricant at both ends.
Reconnected both ends and the bouncing continues. One thing I noticed after getting the nut on and tightening the cable to the speedo it seems the threaded stem of the speedo is slightly loose. In other words, after tightening the nut to the speedo if I moved the cable a little bit it seemed the threaded stem also moved.
Any thoughts appreciated!
M
Member 10617
Hi, Irishcasey,
One way to check the cable part of the speedometer is to disconnect the cable from the speedometer, hold the end of the square inner cable in your fingers (lightly) and drive a little bit. If the cable turns smoothly, then things at that end are probably OK.
But I don't think you need to do that because it sounds to me like the problem is with one of the gears inside the speedometer itself.
I didn't send my speedometer directly to the person who rebuilt it. I sent it to a shop in Waynesboro, Virginia, and they sent it on to the person who does work for them. I don't know who that is.
I am sure there are people on this forum who can recommend specific reliable shops where you can send your speedometer. Or, you can email the author of the article, Anthony Rhodes, at Rhodes@comcast.net. He would surely have the names of some shops in your vicinity.
Gliderman8
If you're looking for another source, these are the people who did my speedo and tach resto....
edit: there are also others who do repairs
Margaret Lucas
Mo Ma Manufacturing - instrument repair
13211 Second Street. NW
Albuquerque, NM 87102
Ph (505) 766-6661 - Fax (505) 766-5419
momanm@aol.com
M
Member 10617
By the way... one word of warning.
When you screw the cable into the speedometer, make it snug but not too tight. If you overtighten the cable, you can sometimes jam the square inner cable into the speedometer and damage it.
hondo402000
Nossonger did mine and both the Tach and speedo are steady as a rock now where they use to jump around like kangaroos!
Hond
2wrench TR6 Need help with '74 TR6 speedometer. Triumph 12
R TR6 tr6 speedometer Triumph 0
2wrench TR6 '74 TR6 Route of speedometer cable from overdrive. Triumph 7
P TR6 '76 tr6 speedometer problems Triumph 3
A TR6 Speedometer recalibration ?? TR6 Triumph 6
I TR6 TR6 speedometer cable Triumph 3
Paulus TR6 TR6 Speedometer problem in transmission housing Triumph 5
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
AngliaGT ANOTHER TR6,& an MGB Spotted 0
A For Sale 1974 TR6 Triumph Classifieds 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
