Took the Legacy to the Eager Beaver Car Wash - best in the area. When the car was finished, the wiper boss called me over and showed me a small bulge in the right rear sidewall. Said it could be a problem if the tire blows. I called my local shop and ordered an exact replacement Goodyear Eagle LS2. I then Googled Subaru and AWD tires and found out that if more than 1/4" difference in tire circumference in even one tire, the center differential (actually a group of clutches) will definitely be ruined and have to be replaced at BIG cost. The other 3 have about 28K miles on them and the left rear has slightly less tread. Ironically, the same thing happened to my daughter's Crosstrek and she had to replace all 4. (Her lease is up in April). Since I have no way to measure the tires and no one down here shaves tires, plus my lease is ending May 11th, it looks like I'll be on the hook for 3 more Eagles at around $150 each. Since they measure the tires at the end of the lease anyway, and since I don't want it on my conscience if someone buys the car and has a bad crash due to the problem, I'm taking the car to the local dealer - I have to change the oil anyway - and have him measure the tires. I'm not optimistic. LBC owners be glad you don't have this problem, although you should not mix tires for handling purposes, but had I known of this before opting for an AWD car, I might have chosen differently. The only leverage I might have is if I choose to lease another Legacy and they might waive the cost of the new tires (or just ignore the problem and fob the car off on some unsuspecting buyer). Has any other AWD or 4WD owner here had a similar problem?
