XJS Fuel Injector, Air Temp Sensor, Water Temp Sensor Harness Connector Replacement
Michael J.
At a NAPA Parts store the part number 2-17427 "Wired Housing" connectors that fit the injector electrical connection and the coolant and air temp sensors can still be purchased. List is $11.58 ea and Napa sells them for $8.49 each. So anyone needing to replace broken connectors, here is a cost effective way to repair the harness. Each comes with 3" pigtail wires. The boots are not available. I'm going to try heat scrink tubing.
Keep your spring clips! They are available from NAPA under p/n 2-17417, but Napa charges $1.49 net and $2.02 EACH!!!
